Question about Hayward 116k BTU HeatPro Digital Heat Pump HP21003T
Hayward HeatPro Heat Pump for pool won't turn on
I have a three year old Hayward Heat Pro Digital heat pump for our outside pool. This past winter a mouse got into the control panel and built a nest. After I cleaned out the nest, I saw the mouse urine had eaten away the blade fuse on the control board. I replaced the fuse and didnt' notice any other damage from the mice. I verified the fuse is working with a fuse tester and that the unit is getting power. The digital control still doesn't show a power light and won't turn on. Any suggestions?
  • 78 Answers
Power to the unit but not the display + mice = bad board probably. Service call required...
Posted on Apr 22, 2010
Hayward heatpro running but not heating. The "run" light is yellow but it should be green
i have found nothing in any of my heater manuals to account for the color of the light. in every instance, the light is either lit or not. the color does not change.
as for the not heating, if the outside temperature is less than 60 degrees, your heat pump will not work well. as heat pumps do not heat water very efficiently, there may not be a noticeable difference in water temp. the best way is to measure the temperature going into the pump (outside ambient temperature) and the temperature of the air exiting the top of the heater.
if the outside temp is 70 and the air out of the heater is 65, there is a 5 degree temperature applied to the pool water. this can be diminished due to transfer of heat to system
Jun 09, 2015 | Hayward 116k BTU HeatPro Digital Heat Pump...
Swimrite pool heatpump not heating pool
heat pumps do not heat as fast or effectively as a direct heat system such as propane or ng. they are only effective when the outside air is very warm otherwise they will actually cool the pool water.
Jun 11, 2014 | Hayward Pool & Spa
HAYWARD HEAT PUMP POOL HEATER FAN WON'T SPIN
if your meaning the top mounted fan , if the compressor does run , and the top fan does not , fans do go bad there not too expensive and don't require a rocket scientist with a truck load of tools to replace them , two biggest things to look for are Height of fan away from hitting solid object (compressor) and match wires color for color (turn power off !!!) , replace capacitor as well they aren't included with motors there extra !!! new motors do say on package what size capacitor to buy (it might be different than old one?)
Jul 31, 2013 | Hayward 116k BTU HeatPro Digital Heat Pump...
Overheating hayward super pump
Superpumps have been a workhorse in the industry for decades. Your results are highly unusual. The motors that run these pumps have bee manufactured by Century/Magnetek and A.O. Smith for the past 20+ years. These same motors power the vast majority of pumps built by a wide range of pool pump manufacturers. (They are not Hayward specific)
You may want to get a second opinion from another electrician, or call out a pool pro to check out the installation to see what could be causing these frequent failures. This is WAY abnormal.
Jul 03, 2013 | Pool & Spa
Hayward HP error
check voltage coming in if ok check voltage after transformer if ok check safety circuit pressure switch voltage both leads if not replace or check for plugged copper line
May 04, 2012 | Hayward Heat - Pro 2100 Heat Pump Pool...
Panel reads lp error code
Loss of refrigerant, bad motor for the fan clean the coils and unit as described in the manual. Here is a manual from the Hayward website or here http://www.haywardnet.com/products/manuals/pdfs/Manual122.pdf.
Jun 04, 2010 | Hayward 116k BTU HeatPro Digital Heat Pump...
Hayward 116k BTU HeatPro Digital Heat Pump HP21003T Logo
979 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
Craig Butler
Craig Butler
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
