Question about Asko D1796FI Built-in Dishwasher
Door will not close to start unit
Asko dishwasher model #1796FI, door latch will not catch metal latch on unit
    President:
  • 2,923 Answers
Thelatch on a dishwasher door is opened and closed repeatedly, and thishard use can lead to mechanical problems. The latch may be loose, or itmay have slipped out of position, throwing the alignment off andpreventing the door from closing properly. When this happens, the latchdoes not engage properly, and the dishwasher will not start.
Inmany cases, you may be able to solve the problem by adjusting theposition of the latch. Move the latch slightly by loosening the screwsthat hold it. Slide the latch with your fingers or pliers; the screwslots are made especially for this purpose. Close and open the door tosee whether the latch is properly aligned. Tighten the screws to holdit in the correct position.
Afterrepositioning the latch, check to see if it's working properly. Closeand latch the door and turn the control knob to the ON position. If thedishwasher doesn't start, the latch is faulty. Replace it with a newlatch, connecting it the same way the old one was connected. You mayhave to move the new latch back and forth several times before it worksproperly.
Here, check these links to see which door latch is compatible with your dishwasher if in case you need to replace it:
http://cgi.ebay.co.uk/-Iveco-3510-breaking-for-spares.-Side-door-latch-_W0QQitemZ260401436793QQcmdZViewItemQQimsxZ20090429?IMSfp=TL090429126001r15905
http://www.google.com.ph/firefox?client=firefox-a&rls=org.mozilla:en-US:official
Have a great day!
Posted on May 27, 2009
Why does my dishwasher not close
Sounds like my daughter and her kids sitting on the door when its down. When lifted into position the latch no longer matches the"catch" It might require a little ingenuity to bend the door hinges back. it definitely sounds mechanical. Even a pro wouldn't let you watch how he bends that back. worse case scenario bite the bullet, call service tech, pay for labor AND parts (hinges or latch/catch) thinking again some of the older models (like cars) the latch is engaged and is waiting/depending on the opening of the door to change it's position. trying to shut it and a hard metal on metal clunck! might indicate a closed latch and not bent hinges... Good luck and give Fixya a bit of feed back~~~hope this helps---> S
Jul 29, 2014 | Dishwashers
Asko d3251 randomly stopping during cycle.
The thing that immediately comes to mind is a faulty door switch or latch. The door switch can be replaced and you might be ok. But the latch would be more tricky to check. Sometimes if dishwasher is not level or if the door springs are misalinged the door tends to slip and release the latch due to pressure. It works when you open and shut. But not sure about the night time cycle. That sounds a bit creepy if it starts again by itself. Why not put a tape around the door and then start. That will help eliminate the obvious ones. The other thing that exends dishwasher cycle time is the lack of adequate water temperature. Could be heater or thermostat or both.
You should be able to stroll through the parts by selecting categories on this site.
http://www.repairclinic.com/Shop-For-Parts/a9b126d867701/Model-D3251White-Asko-Dishwasher-Parts
May 01, 2014 | Asko 24 in. D3250 Built-in Dishwasher
My Bosch Dishwasher door sticks shut at the end of the cycle. I can open and close it with ease during the cycle, but once it finishes I have to pull really hard to open it.
see all this steps and fix it. God bless you
Door or Lid Latch Assembly
If the door won't latch, the latch assembly might be defective. Inspect the latch assembly to see if it is cracked or worn out. The latch assembly is normally replaced all as one part.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Hinge
If the door won't latch, one or more of the door hinges might be bent or broken. If the door hinges are not working properly the door won't close squarely and then the door won't latch.
Door Catch
If the door won't latch, the door catch might be out of alignment or broken. If it appears to be OK, reposition it as needed. If appears broken it should be replaced.
Door Lock
If the door won't latch, the door lock assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door lock is broken, replace it.
Door Latch
If the door won't latch, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Door Strike
If the door won't latch, the door strike might be defective. These are normally made of plastic or metal and cannot be repaired. If the door won't latch and the door strike is broken, replace it.
Apr 05, 2013 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Door wont shut
Door Hinge
Door Catch
Door Lock
Door Latch
Door Strike
Apr 05, 2013 | Miele Dishwashers
Asko washer door won't close. Worked it manually fine with screw driver flicking latch switch but door wont connect with latch. How do you get behind switch panel to replace switch or see whats going on??...
you would start at the top back by losening the screws that hold the upper cover on the machine and when you remove these screws you would then slide the panel to the rear of the machine. nest you will see the rubber gaskey along the door has a metal ring simply use a screw driver without ripping the rubber boot to remove the ring. After this then u can remove the screws which hold the front panel which also has the door on it the part you are describing sounds like the door hasp or the catch the holds the door closed. because it is an asko your probably better off going to manufacturer to order your parts because this is a foreign model. please remember to rank how this opinion has helped in your appliance situation and if i can answer anything further please message me back
Thanks again
Rick
Nov 28, 2010 | Asko W6021 Front Load Washer
Asko 1385: 13 year old dishwasher stops during cycle. If you push on the middle of the door it starts again. It is like the latch is not working properly but by all appearances the latch works fine....
when you latch the door it closes the circuit.
you may have to open the casing of the door to access the switch. it may be stuck or defective.
May 15, 2010 | Asko 1385 Dishwasher
Dishwasher runs even tho the door is open
The door interlock switch is jammed in the closed position.
There is a metal tab on the inside top of the DW frame that engages a lock just behind the handle on the inside of the unit. The lock tells the machine the door is closed and it is OK to run. If that jams the unit thinks the door is closed.
Open the door.
Look for the latch inside the door behind the handle.
Try to release it with a screwdriver.
If you need to you can remove the handle and repair from inside. It is usually a simple jam that requires you to gently pry the latch open.
REMEMBER TO TURN THE POWER OFF FIRST.
Hope this helps. Please rate this if it helps you.
Thanks,
Adrian
May 03, 2010 | Asko 24 in. D3530FI Built-in Dishwasher
Asko D3250 not working
If the first start button is blinking then there is a door error...the door switch is not closing... to repair
1) turn off the power at the breaker...
2 ) remove screws in the door T20
3) remove contol panel (slide up)
4) place wire tie behind micro switch on door latch...
5) replace door latch and door.
Hope it helps....If NOT let me know more about your problem ... I will Help
Nov 25, 2008 | Asko 24 in. D3250 Built-in Dishwasher
Asko dishwasher d3250 door not closing
the door latch is faulty or needs to be rolled open
Jul 08, 2008 | Asko 24 in. D3250 Built-in Dishwasher
Dishwasher does not "pause" (hault) when I open the door
it's the door switch gone bad or the wire going to it has fallen off.
Mar 01, 2007 | Asko D1776 Built-in Dishwasher
Asko D1796FI Built-in Dishwasher Logo
150 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
