Question about Jensen Car Audio & Video
The red light on jensen 850watt amp wont turn off
I tried putting a difrrent fuse but it wont shut off and i tried putting a thiker wire put it wont turn on properly
    Problem Solver:
  • 18 Answers
Jensen sucks dude. just sell it and upgrade. red light could be anytihng. chekc your speaker wires and make sure nothing is touching. from the remote start wire(blue) to the amps and subs. chekc and make sure there is nothing touching.
Posted on May 27, 2009
I have the dual amp xpa 2500 and i ran all the wires and everything but the indicator light wont turn red nor green what can cause that problem?
Check all the wiring again. If you can use a multimeter, make sure your power wire is getting power at the amp. Also, check to make sure your ground is good. Also, check the remote wire for 0.5 amps when the radio is on. This will make sure it sends the signal to turn the amp on. Also, check all your fuses. Make sure to put the fuse in your power wire. Hope this helps.
Aug 22, 2011 | Car Audio & Video
Jensen VM9312 Stopped working
MAKE SURE U CHECK THE FUSES UNDER THE HOOD.
Mar 31, 2009 | Jensen's VM9312 Car DVD Player
Jensen uv8 and amp hook up
Remote wire from Jensen is blue or blue/white. Use Blu/white if there is one. . RCA's, for subs, use the rear if no subwoofer pre-outs are available. If unit has sub pre-uts, use them as the head ubit (stereo) would have a level that can be raised or lowered thus giving you more control over the input to the sub amp.
Jan 28, 2009 | Jensen VM9510 Car DVD Player
Wont turn on
check your fuses and all connections, make sure you have a good ground to the stereo and make sure the yellow and red positive wires are not loose!
Jul 19, 2008 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Jensen Amp and Sub
If you followed the instructions correctly, then the amp must be defective. This is sort of simple.
My generic suggestions:
You have the power, the ground, the outputs to the speakers, and then the input.
Make sure that none of the speaker wires are somehow being grounded. Make sure that nothing is shorted that feeds the speakers.
Jerry G.
Apr 27, 2008 | Jensen A300HLX Car Audio Amplifier
Jensen VM9311/ UV7i wont turn on!!?
Yo, I've got the perfect solution to your problem. Pull out the head unit from your dash. Then, remove the wiring harness carefully from the unit. Now, push in the yellow power wire (even jiggle it a little) making sure it's tightly snug the small port of the wiring harness. Then, plug the harness back into the unit and try turning it on. I've found that the wires come lose easily on this unit. hit me back up at Darkintel74@aol.com.
Mar 03, 2008 | Jensen VM9510 Car DVD Player
Both green and red ligt or on my jensen ka3 i dont know what it means i had it working b4 i swaped my subs for some new ones and the amp dosent work now.i dont know if is because of the red light but i...
Generally, the power light is green and the protect light is red. If the protect light is on there could be a short in the wiring or there could be an internal fault in the amp.
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down (goes into protection), the amp likely has blown output transistors.
Dec 28, 2007 | Jensen KA3 Car Audio Amplifier
I really need help!!
Don't think you'll find a solution, from what I've been reading this is a problem that alot of jensen products have. I ended up replaceing mine with the 6112 but could not hook up the CD Changer so I got the 4610 which right now is working fine, so I tried putting the 6112 in another car but now it wont power on, whats up with jensen ?? I think their more trouble than their worth.
Nov 16, 2007 | Jensen CD3610 CD Player
Concept CC-2502 Car Audio Amplifier
The amps are probably going into protection mode. The wires are most likely not hooked up correctly. Make sure you have a good ground, good power source, and the remote wire is run correctly. Also make sure the speaker output wires aren't touching each other, and you have the correct ohm load for the amp. What kind of speakers/subs are hooked up and how are they wired?
Sep 20, 2007 | Concept CC-2502 Car Audio Amplifier
I need help! jensen 3610
Hmm, did you hook up the red ignition wire?
Oct 20, 2006 | Jensen CD3610 CD Player
Car Audio & Video Logo
115 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
