Question about Canon Cameras
Battery wont stay charged for more than 15 minutes
Both batteries i have will not stay charged for more than 10 or 15 minutes in a row. do i need to buy new batteries for it?
  • Canon Master
  • 4,738 Answers
How old are the rechargeables? They really aren't meant to last more than a year or two, regardless of how much they were used. If more than a year old, recommend replacing them.
Now you didn't mention the type of rechargeables. If standard AA NiMH, just go to your local retailer such as WalMart. But if it's a battery made specifically for your camera, recommend Amazon.com as they list many generic low-cost alternatives. Just make sure to choose based on user ratings.
Posted on May 27, 2009
After fully charged battery power lasted about 20 minutes.
Since it's brand new, return it. You didn't say what type of tablet it is, but they should last for many hours on a charge.
Oct 02, 2015 | Tablets & eReaders
Why wont my HV-800 Bluetooth headphones stay charging? They charge for maybe 5-10 minutes then it stops charging and i know theres nothing wrong with the charger.
Those batteries are very small and when they wear out, you are done. Over charging is the leading cause of heat and heat destroys the battery.
May 27, 2015 | Radio Communications
Why wont my black and decker ultra bright spotlight stay on for more then 10 minutes ?
The batteries are probably no good or your charger is bad. But I say the batteries themselves are bad. All batteries will only last so long. And it also depends how often they are keep charged and discharged. Basically all batteries require some kind of maintenance (recharging / discharging).
Feb 16, 2015 | SPOT Camping, Backpacking & Hiking
Dead battery 1990 xlh sportster 1200
The voltmeter test provides a general indicatorof battery condition. Check the voltage of the battery to verify that it is in a 100% fully charged condition. If the open circuit (disconnected) voltage reading is below 12.6V, charge the battery and then recheck the voltage after the battery has set for one to two hours. If the voltage reading is 12.8V or above, perform the load test described below.
The load test measures battery performance under full current load and is the best indicator of battery condition. Load testing a battery tat is not FULLY CHARGED i.e. at 12.8 VDC can permanently damage it. Fully charge it first and then let it stand for at least an hour before the load test is done. You also need a load tester. AND you should know how to perform a load test. Often the best way to load test a battery will be to take it to a battery shop and have it done there.
VOLTAGE (OCV) STATE OF CHARGE FOR AGM BATTERIES IS:
12.8 VDC = 100%
12.6 VDC = 75%
12.3 VDC = 50%
12.0 VDC = 25%
11.8 VDC = 0%
COLD CRANKING AMPERAGE (CCA) for a DYNA battery is 270
19 AMP HOUR BATTERY =
BATTERY STATE OF CHARGE = 12.8 VDC = 100% Charge; Rate of Charge = N/A
BATTERY STATE OF CHARGE = 12.6 VDC = 75% Charge; Rate of Charge @ 3 AMP = 1.75 hours @ 6 AMP = 50 minutes @ 10 AMP = 30 minutes @ 20 AMP = 15 minutes
BATTERY STATE OF CHARGE = 12.3 VDC = 50% Charge; Rate of Charge @ 3 AMP = 3.5 hours @ 6 AMP = 1.75 hours @!10 AMP = 1 hour @ 20 AMP = 30 minutes
BATTERY STATE OF CHARGE = 12.0 VDC = 25% Charge; Rate of Charge @ 3 AMP = 5 hours @ 6 AMP = 2.5 hours @ 10 AMP = 1.5 hours @ 20 AMP = 45 minutes
BATTERY STATE OF CHARGE = 11.8 VDC = 0% Charge; Rate of Charge @ 3 AMP = 6 hours, 40 minutes @ 6 AMP = 3 hours, 20 minutes @ 10 AMP = 2 hours @ 20 AMP = 1 hour
The figures listed above assume that the battery is charging at room temperature. If warmer than room temperature, use a slightly shorter charging time. If colder, use a slightly longer charging time.
The use of constant current chargers to charge maintenance-free batteries is not recommended. Any overcharge
will cause dry-out and premature battery failure. If a constant current charger is the only type available, do not exceed the charge times listed above and do not continue charging the battery if it gets hot. When charging, never exceed 15 volts for more than 30 minutes.
If the battery gets hotter than 110 degrees F. (43 degrees C) during charging, discontinue charger and allow the battery to cool. Overheating may result in plate distortion, internal shorting, dry out and/or other damage.
Apr 22, 2014 | Harley Davidson XL 1200 S Sportster Sport...
Chaging batter
12.8 VDC = 100%
12.6 VDC = 75%
12.3 VDC = 50%
12.0 VDC = 25%
11.8 VDC = 0%
COLD CRANKING AMPERAGE (CCA) for an XLH battery is 270
COLD CRANKING AMPERAGE (CCA) for a 2001 XLH battery is 270
Peg Perego 800 Twin ATV - Only runs for 10 - 15 minutes at a time
Go ahead and charge it for 24 hrs. If it still does not run contact the repair department at http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.htmlthese guys (and gals) help me out all the time.
May 31, 2009 | Polaris 800 Twin Sportsman Ride on Toy
Batteries require several charges in order to reach fully capacity
I wont exactly call this solved but I called duracell and they think the batteries are old. They are sending me a new set of batteries.
Sep 08, 2008 | Duracell AAA NiMH Battery Charger with 4...
Minn kota turbo35 electric motor only stays on full spped for 10 minutes.
I dont know how old your battery is but they will sometimes show full charge but not last long cause of age. Try a differant battery.
Jul 26, 2008 | Boating
Cameras Logo
49 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
