Question about RCA R52WM24 52" HDTV Projection Television
Convergence menu not available on my RCA HDTV. Model R52WH74YX58 I have installed all 3 new fuses as well as DL231 and CP230 and resoldered the pins on the flyback and IC, but I still have not got an option for the auto convergence and ideas?
  • RCA Master
  • 8,617 Answers
The only fuse that will govern the convergence option is FL231 along with the two other components that you mentioned. If that didnt fix the issue the deflection board or the convergence power supply is defective. The deflection board is most suspect.
Posted on May 27, 2009
WERE CAN I BUY AND HOW MUCH IS A FL231 FUSE FOR RCA HD52W59
If you replace just the fl231 it will blow again. You will need to replace the FL231,DL231 and CP230. You can get the parts at the following link with free instructions with pictures total cost is about 26.00. Its listed under the RCA repair kits as the ITC222 & ITC222A convergence option missing repair kit. Its available at www.tvrepairworld.com
Dec 29, 2011 | RCA HD52W59 HDTV Projection Television
Convergency has gone out of sync, went to try to realign but the convergeny setting was not listed in the tools menu.
Thats usually caused by a blown FL231 Fuse and a blown DL231 diode that blow when the flyback transformer develops solder cracks around the pins. The repair is to first resolder the flyback then replace the FL231 fuse and DL231 diode. You can get the RCA / GE convergence option missing repair kit which has the parts and repair instructions from www.tvrepairworld.com
Jul 09, 2011 | RCA HD61W66 61" Projection HDTV
My convergence keep going out, I replaced the convergence twice. I have a rca hd52w59 modle
When you say replaced the convergence twice, are you refering to the convergence boards or the FL231 fuse? If its the FL231 fuse unless you replaced the DL231 and CL230 plus reflowed the solder on the flyback it will continue to keep blowing untill the 3 parts are replaced together and the flyback gets resoldered. If you replaced the convergence boards then try resoldering the flyback.
Nov 27, 2009 | RCA HD52W59 HDTV Projection Television
On going Convergence Issue RCA R52WH73 Television
did you reflow the solder on the flyback and the vertical output IC?
Jun 12, 2009 | RCA R52WH73 Projection Television
Rca hd52w59 3d screen colors are seroperated no convergence
If you replace just the fl231 it will blow again. You will need to replace the FL231,DL231 and CP230. You can get the parts at the following link with free instructions with pictures total cost is about 12.00 shipping is free. the parts are all listed under the RCA parts category.
http://servicemanuals.vstore.ca/
May 28, 2009 | RCA HD52W59 HDTV Projection Television
Itsalmost that simple, But you will need to replace the FL231, DL231 and CP230 and that should take care of your problem. You can get the replacement parts at the following link under their RCA Parts category. The total cost is around 13.00 and shipping is free and they even send detailed instructions with pictures that show how to do the repair which is very easy.
May 28, 2009 | RCA R52WM24 52" HDTV Projection Television
Picture looks 3-D
Yes its an easy repair if the auto convergence is missing in the on screen menu , you can fix it for about 10.00 at the following link . You would need one of the following 3 items all listed under the RCA parts category.
(1) FL231, (1) DL231 and (1) CP230
They supply instructions with pictures on how to do the repair.
Apr 26, 2009 | Televison & Video
I have a RCA HD52w59, when i use to got to setup there was a configure item and I was able to go to auto convergence, now this item is not listed. how can i rest the menu to show this item so i can run...
You will need to replace FL231, DL231 and CP230 which you can get at the following link for about 10.00 total which includes shipping and free instructions on how to do the repair. Heres the link look under the RCA parts category.
Apr 25, 2009 | RCA HD52W59 HDTV Projection Television
So the set is completley without convergence? bowed and the 3d effect.]
There is a small brown rectangular fuse fl231> it is common for this to blow due to poor solder conections on what is known as the flyback. IF this is your problem then it not a difficult repair. i do them all the time at the shop in about 15 min. Getting the fuse is the most difficult thing.
Mar 03, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA R52WM24 52" HDTV Projection Television Logo
372 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
