Question about Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas
5 year old Laars 25,000 LX won't ignite.
As a test, I have installed this used pool heater on our pool with a 1.5 hp pool pump. I get no LED problem read out, but the gas won't ignite. The blower comes on for about 30 seconds, then goes off completely, at which time the screen says "Low Pressure". This heater sat unused for about 3 years, and had only a summer's jacuzzi use prior to that. Good shape.
Is there a pressure problem? What is the problem?
I am intending to use this as an external heater to heat a small jacuzzi with a 1 hp motor. Will the jacuzzi pump provide enough pressure to fire the heater?
Thank you!
  • tbutz111 May 27, 2009
    The gas line is new and gas is available. How can I know if the heater gas valve is malfunctioning? Thanks!
    The LX model has an electronic igniter, not a pilot. I'm not sure I can hear if there is gas over the sound of the pump and the blower. There is a glass circular window the size of a quarter on the front wall of the heat exchanger. I'm guessing I can see flame through this. Can I also see the igniter and spark through this window? Thanks for all the helpful comments!!
    President:
  • 1,489 Answers
The low pressure indicator is for the gas pressure not the water pressure. The heater won't ignite because it's not getting gas to the igniter. Check gas supply, if okay, check gas connections, valves, etc.
The 1 HP motor should be fine on the jacuzzi.
Posted on May 26, 2009
  • 1 more comment
  • Samuel Charles Spriggs May 27, 2009
    Accurate testing would require some equipment and expertise which is best provided by a pro.
    Although the screen is reading low pressure, this may be an erroneous error msg, and the igniter may not have a hot enough spark.
    About the only thing I could reasonably suggest is to listen when the gas is turned on to see if you hear any gas moving, and watch the igniter to see if it sparks.
    If you can't do this without taking the unit apart, I would not suggest doing it -- this can be very dangerous, and needs a pro to do it safely.
    It occurred to me that instead of an (spark) igniter, you may have a pilot light -- do you know?
    Yes, I would say you should be able to see the spark through that window.
    Problem Solver:
  • 5 Answers
SOME OF THESE DO NOT USE SPARK THEY HAVE GLOW RODS REMOVE DOOR AND LOOK AT THE BOTTOM OF THE HEATER AND SEE IF THERE IS A GLOWING RED LIGHT ( IS THIS A TRUE LX OR LXI )
Posted on Aug 19, 2009
  • 15 Answers
The ignitor is a hot surface type it does not spark. If you look in the "window" during start up you will see a glow best done when it is dark.
The problem sounds like the air flow switch You said the fan comes on for 30 seconds and stops. You are not going any further into the start cycle becaues it is not sensing fan air flow and shutting down.
Look for the air tube clear or white about 1/2 wide make sure it is connected and does not have any holes in it. Mice/rats chew trough it all the time. Don't blow in the tube this will damage the air switch
Posted on Jun 23, 2009
Laars LX Heater not starting
blower gets 120 vac. ensure proper voltage to blower to start
Jun 20, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Laars lx won't ignite
hot surface igniter may not be hot enough to ignite the burners
Jan 09, 2013 | Teledyne Laars Laars Lx Pool Heater /...
How do you replace a pool heater pressure sensor?
check pressure switch to see if voltage both sides if not see if copper tube is plugged make sure filters are clean
Sep 22, 2012 | Jandy Laars LX Pool Heater / 400,000 BTU /...
My Laars LX pool heater would shut off soon after it fires up
This error is Automatic Gas Shutdown. Here is what you can do:
  1. Check for fluctuating pump pressure (air in strainer, pressure guage bounce)
  2. Check all wiring connections
  3. Replace ignitor/flame sensor assembly
Depending on your expertise, it could also be the gas valve or ignition control (aka the IID).
Since the burners do fire briefly, I would suspect the flame sense rod first. Attached is a link to the owners manual in PDF.
Lo Nox heaters can be a little tough so follow the directions exactly.
Jul 24, 2010 | Teledyne Laars Laars Lx Pool Heater /...
My laars lx pool heater is blinking LOW PRESSURE. How do I fix?
The heater needs good water flow or it will overheat. You probally have a full basket in your pump or your filter is dirty.
Jan 20, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Describe your Jandy Laars Lite2 Pool & Spa Heater - Electronic Dual Ignition - 125,000 BT Problem FL 4 code and have changed igniter and still getting the FL4 code its the lite 2 model...
A. Check fuses on igniter wires. Identify and correct loose connections or broken wires. B. Measure room temperature resistance and ensure value is in the correct range. See manual for details. C. Replace igniter.
Jul 04, 2009 | Jandy Laars Lite2 Pool & Spa Heater -...
Laars Teledyne Pool heater flames on for 2 seconds, shuts off
You have no flame rectification.....LLD series heaters check for a signal through the flame to ground; if the module does not detect this signal, it go through two more trials for ignition and then lock out the module. There should be a flame rod and it may need cleaning. I use steel wool.
May 30, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
pull out flame sensor and clean with sand paper or emmoring cloth then try again should work (small black wire with sensor sitting above burners)
May 05, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas Logo
717 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
