Question about RIM BlackBerry Pearl 8100
Replace lithium battery
How can i replace the back up battery on the ipaq 1900 series
  • 2 more comments
  • Anonymous Nov 19, 2007
    how to replace battery in a tungsten E
  • Jl17 Dec 22, 2007
    I have a fairly new blackjack and recently I dropped it and the battery won't charge. I was going to buy a new battery and install it. Can you tell me how to open the back battery cover so I can do that. It would be greatly appreciated. Thanks.
  • Anonymous Feb 16, 2008
    were do you put in the sim card and battery
  • Anonymous Aug 20, 2008
    hoe do i instal the battery
    Problem Solver:
  • 12 Answers
The question was how to replace the internal battery. I'm curious to know if that battery has died or if you suspect, by replacing that battery, that other problems will be solved. I'm having troubles with my phone cutting out and am trying to understand if it's related to the battery.
Posted on Dec 14, 2007
Cost of new battery for IMATE tm JAM
Posted on Dec 12, 2007
I have the IPAQ pocket pc 3765 and I was replacing battery but when I opened I saw the battery door out of its place but I do not know where is located then I can not to finish my work. Can you describe...
Welcome to Fixya
As far as i can remember, there are no battery door for ipaq. Once the device opens, gently pry out the original battery. This one should come right off (it is only stuck using some double sided tape). All you need to do is to replace the double adhesive tape if you are going to replace the battery then close the unit. Tip: Use an old credit card or something that won't damage the case to gently lift the battery out.
Thank you for using Fixya!
Jul 04, 2011 | Computers & Internet
I have purchased three milwaukee screw guns in the past year and a half and all four of my batteries will not charge. when my first set stopped working i had to purchased another screw gun and within six...
The same thing happened to me. There is normally a 2 year warranty on the batteries from Milwaukee. You can't return them to the Home Depot, you have to send them back via a local repair center.
You won't be able to exchange the batteries at the repair center. The repair center sends them back to Milwaukee and Milwaukee will send replacement batteries. You will probably be able to find the closest repair center on line.
Sep 15, 2010 | Milwaukee Tool Garden
I tried using 3 AA NiMH batteries (total DC V=4.2, 1600mA) as a backup/charger for my HP Ipaq 612c battery. I inserted a resistor (4.7 ohms) in the circuit to reduce the current. The red light charging...
You built one of these too, eh?
Yes, there can be a problem doing this. First off, 3 AA batteries does not equal 4.2 volts, they are 1.2volt nominal so 3 * 1.2 = 3.6volts. When they are just off the charger, terminal voltage will be closer to 1.5v, so 1.5*3 = 4.5 volts.
Using ohms law, E=I * R, we can find your current as I = E / R or I = 4.5v / 4r7 as .95Amps (almost a full amp) that you would see worst case. The resistor is doing nothing for you.
The reason that the charge light blinks intermittently is because the charge controller (lithium battery, right?) is pulsing due to low voltage.
Try this: Take *6*, yes, 6, AA batteries, your choice of chemistry, and put them in series. That will give you a nominal (alkaline) voltage of 9v. Connect a low dropout 5v regulator such as an LT1117-5. Then you will be able to use your battery backup much more effectively.
On a different note, I used 4xAA (NiMH) and powered my ipaq 3650 directly. Worked great. Your mileage may vary though.
Aug 27, 2010 | Cell Phones
How do I replace the battery on my Compaq iPAQ H3635? Do I have to take the back off? If so it appears to have special screws.
You can get a replacement rechargeable Ipaq battery from batterytrader, click the link, IPAQ H3635 BATTERY , they also have extended versions just search within the site
Mar 14, 2009 | Compaq iPAQ H3635 Pocket PC
HP-iPaq 2215 battery replacement
Hi, Jim--
When you take the battery out of an IPAQ you're performing a hard reset. I've got 4 different IPAQs and it does the same thing on all of them.
My solution was to back the IPAQ up using the internal backup program (back up to IPAQ storage) and then replace the battery, then restore the last backup.
Saved me a heck of a lot of time. It's been hard to remember to back up everytime I add a program or change data majorly, but it's probably the best thing to do.
Nov 22, 2008 | HP iPAQ H2210 Pocket PC
IPAQ 3700 Series - Battery not holding charge
In this model of ipaq the battery come inbuilt which means it is not enduser replaceable so cannot place an order to the battery so call HP and send the unit in for service. All the best :-)
Sep 12, 2005 | HP iPAQ RX3700 Pocket PC
IPaq 1910 backup battery replacement
Sep 07, 2005 | HP iPAQ H1910 Pocket PC
RIM BlackBerry  Pearl  8100 Logo
180 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
