Question about LG Computers & Internet
HALF SCREEN IS LIGHTER THAN OTHER HALF
I HAVE JUST BOUGHT A LGW2453-pf 24 lcd MONITOR AND HALF THE SCREEN IS DARKER THAN THE OTHER HALF. HOW DO I ADJUST IT TO GET IT RIGHT?
Press the 'Engine' button that there is on the screen and select 'Normal'
Posted on Aug 23, 2010
  • Calten Nov 06, 2010
    How do I get to the engine button?
Lg flatron e2441 half screen darker
If you get half of the screen darker, remember that LCd monitor have 2 neon lamp at each extremity of the LCD, when one goes out you get this problem. it is possible to replace the LCD neon lamp, I did it many time, but you need to tear all the monitor appart and be carefull not to break any glass while doing so.
Jan 04, 2014 | LG Flatron Computers & Internet
Half of the screen is darker than the other half.
It seems like you may have a backlighting problem.
Contact the manufacturer for a warranty replacement.
Jun 03, 2011 | LG W2043S-PF 20 inch Monitor
On my monitor W1941S half of area (left side) changed all colours to darker then right side (which is o.k.), What is the problem? Thank you.
Press f-Engine button (it is on the right side of MENU button), select your desired setting, if it doesn't help, select the "X" (none) mode - the half dark screen will reset to full screen OK mode.
Jan 08, 2011 | LG W1941S-PF Monitor
Asus AL2216W top half screen got darker. Lamp problem ?
When the lamps are bad, the screen will shut down if the inverter cricuits is sensing open (lamps will not fire up and conduct, or lamps are drawing too much current). You should open it up and inspect the caps in the power supply first, lamps in this monitor are ntoeasy to replace (screnn will to be complete,ey disassembled.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Apr 24, 2010 | Acer AL2216WBD LCD Monitor
Half e HPw1907 screen is of a lighter color as compared to e rest
It seems from your discription like your lcd back light my be failing, i suggest taking th tv back to where you bought it to see if they will repair it or give you a new one, it all depends on if it is still under warranty. If not it might be worth trying to get hold of a new back light of the internet and fitting it yourself though it can be quite hard and fiddly.post me back if you need further help.
Jan 27, 2010 | HP w1907 LCD Monitor
My photos print out way darker than the monitor shows this happens with two different printers...I need tips on how to adjust it. NOT a computer person ;)
Hi this could be your printer aswell, your printer could be printing the colours in darker then it should, or if it is this Screen , then your screen is probably set too bright then it should making everything lighter and brighter
Thanks
Dec 28, 2009 | Dell 1703FPt 17" TFT LCD Flat Panel...
Upper half of the monitor is darker
I would try an auto-adjust first see if that helps any, also you could try it on another PC to make sure its not your video card on your PC. Another option is to reset the screen to its factory defaults see if that does anything.
Sep 30, 2009 | Samsung SyncMaster 932B LCD Monitor
Screen Half darker
It sounds like your backlight isn't working properly. LCD screens have backlights that illuminate the colors produced upon their surfaces, so that you can easily see the screen without an external light source. In your case, it sounds like your backlights either aren't cailbrated, are damaged, or were produced unevenly.
There is most likely not a fix for this, though most all LCD screens have some form of light distortion. My own LCD screen is slightly brighter around the edges, where the backlights are located, but this is only noticeable when displaying a completely black screen.
Jun 22, 2009 | LG 22" FLATRON LCD Monitor
LCD Monitor Half Screen Pink
sounds like a color balance issue. Check the menu, do a degauss...and then check for the color temperature (reset for default)..
Got backup?
Feb 10, 2008 | Proview PL 566s 15" Flat Panel LCD Monitor
Computers & Internet Logo
2,668 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
