Question about Ricoh Aficio CL3500N Laser Printer
Where do dispose of full toner waste bags?
What's the best way to dispose of full toner waste bags? (OCE plotter)
  • Ricoh Master
  • 4,338 Answers
It depends on where you live.
Do a Google search for " what's the best way to dispose of full toner waste bags?" And add your city,or state on the same line. It will return a list of places to recycle the toner.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 27, 2009
Moving Oce tds400 plotter
there is in fact a way to remove the cartridge. her is a link download the users hand book that has that information and more.
http://downloads.oce.com/ProductDownloads/Index/278
Oc TDS400 downloads drivers manuals software firmware and safety data...
Mar 11, 2014 | Office Equipment & Supplies
Remove toner from oce 450 plotter
it shouldn't spill if left upright. you better be VERY careful with that unit, if the drum gets damaged it will cost ALOT of money to repair it. There may be a lever to disengage the drum blade so it doesn't abrade the drum. If you are unsure of what you are doing you may want to hire someone with experience.
Our toshiba e5520c colour machine shows an error code cd81. What can i do to solve the problem? Must i reset the machine? Can anybody help please? Thanks Yolande
CD81 is an error code for full waste toner bag, or waste toner auger is being locked up, all you have do is separate the finisher from the copier(a green lever inside the finisher door or hole punch unit door), open the side door on the left side, pull the the waste toner bag out, dispose the waste toner properly, then tap the waste toner bag lightly (to make sure you clear the light sensing area is clear for waste toner full detection), reverse the procedures -please consult your user guide. Better yet, ask your dealer give you a spare waste toner bag.
Jan 30, 2013 | Toshiba T-FC55C Toner for BR E-Studio...
CanonimagerunnerE000019-0000
It seem that something is wrong with the fixing unit temperature. For reset procedure:
E000 on Canon
Dec 19, 2012 | Canon imageRUNNER 3300 All-In-One Laser...
Lexmark X543 --Getting msg Waste toner box near Full. What is required ?
very simple there is a waste toner bag that came with your Lexmark X543, so you need to remove it and dispose of the toner inside and replace exactly the same you took it and the message will message will disappear
Jan 12, 2011 | Office Equipment & Supplies
I have a c652 biz hub keeps coming up waste toner box konika minolt printer
To replace the waste toner box, open the front door above the paper drawers. The waste toner box is on the left hand side (usually). Your supplier should have supplied an extra waste toner box. Slide out the 'full' toner box. Replace with an empty one. This should register that you have installed an empty waste toner box. If not, turn off the copier and after a minute or two, turn on the coper again. [If you want to be environmental friendly, the toner box has a small slide cover approximately 1-2cm long (usually on the upper face at the rear as you remove it). Place this end in a plastic bag, slide open this 'cover' and rotate the toner box 180° so this is facing down. Care needs to be taken to prevent the 'waste toner' from flying everywhere. Gently agitate the box until all the waste toner (a grey color) has spilled out. (Approximately 600-800gms) Carefully seal the bag and dispose. An industrial vacuum cleaner can be used to remove the residual toner, clean down the waste toner box with a soft rag and it is ready to re-use.]
Sep 02, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
We get Dispose of used toner even though we empty the toner bag. any ideas
There is a sensor just behind the waste toner box that sends beam through the water toner box to see if reaches the other side. If it does not, then the sensor thinks that the box is full. So you need to clean the waste toner box with some liquid cleaner so that it looks white from outside. Once the box is dry, try again. This should work now.
Mar 11, 2010 | Toshiba e-Studio 350 Copier
Waste bottle full...can i empty it and how??
Don't be conned out of your money by Konica or any salesmen. The waste bottle can easily be emptied. There is no sensor that 'gets tripped and can't be reset' this is bull*&%t. Just take the cartridge out. Go somewhere that you can dispose of the toner (make sure it's not windy !) then turn it to the 'locked' position. This opens the port, then just shake the thing back and forth for a few minutes. You can feel getting lighter. Then turn back to unlocked. Use a vacuum to remove toner from outside of cover, then a soft cloth or wipes to get it clean. Then put it back in.
Jul 21, 2009 | Konica Minolta magicolor 5430 DL Laser...
Replace waste toner tank Does it mean that the toner is already used
Open your user manual.
Or get one - go to google or samsung.
The life of the waste toner container unit is approximately 1,250 pages for full color 5% image printing or 5,000 pages for black printing. When the life span of the waste toner container has expired, Replace/Install Waste Toner Tank appears on the display of the control panel,
indicating the waste toner container needs to be replaced. Otherwise your printer stops printing.
To replace the waste toner container:
1 Turn the machine off, then wait a few minutes for the machine to cool.
2 Open the front cover.
3 Pull the waste toner container out of the machine using its handle.
--- above from manual, following is my paraphrasing due to lack of pictures ---
4. remove the container cap from the back side and cap the opening
5. take the new waste container out of its package
6. install the new waste toner container.
___________
You may wish to TRY EMPTYING the waste toner, but you will find toner is the messiest and possibly dangerous (inhallation, etc) stuff you've worked with. it is an extremely find powder and can cause an awful mess and is best disposed of by capping and replacing the container with a new one (shop around to find them).
DO NOT attempt to vacuum up toner - just my personal opinion - I suspect many vacuums may not have fine enough "bags" to capture this intentionally very fine dust. BUT Toner vacuums do exist and some "may" work.
Jul 17, 2009 | Samsung CLX 3160fn All-In-One Printer
Panasonic DP-1810P Laser Copier
The copier has an "eye" that detects when the waste toner bottle is full. If you dump it and reuse it, the residue can build up and cause the machine to "think" the bottle is still full. I experienced the same problem. If you re-use an old bottle, after emptying, rinse our any remaining residue and dry the bottle out. Your copier should then notice the bottle being empty.
Mar 14, 2008 | Panasonic DP-1810P Laser Printer
Ricoh Aficio CL3500N Laser Printer Logo
482 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
