Question about Network Associates Oil Change 1.0 Full Version for PC
Trying to change the oil on my toyota camry
I want to change the oil on my 1995 toyota camry but i dont know what size hex key to buy so i can take out the bolt at the bottom of the oil pan, do you know what size hex key does the oil pan bolt uses?
    Problem Solver:
  • 14 Answers
Hex key is the transmission --engine oil i 17mm hex head bolt
Posted on May 27, 2009
How do you measure banjo fittings
There are these things specified, length, thread size, hex head size (SW).
https://www.landefeld.de/gruppe/en/banjo-bolts-1-way-metric-din-7643-version-a/8910300
That one is of course a metric fitting, but you really only need to order new metal seal washers for them unless the fittings are lost or damaged.
Mar 21, 2017 | 1995 Toyota Camry
Tip
How To Replace Change Headlight and Bulb 1995-96 Toyota Camry 1AAuto.com
on Apr 26, 2012 | 1995 Toyota Camry
How many quarts of oil for an oil change
Depend on the size of engine.
4 cylinder engine 4 quarts.
6 cylinder engine 5 quarts.
Oct 06, 2010 | 1995 Toyota Camry
How do i fix a bent rod in my 1995 toyota camry.... i recently just drove through a flood and my camry died i got it running then a few weeks later it started to knock... a friend of mine knows a lot about...
If he knows a lot about cars, he should know that you dont/cant fix a Bent Rod. Unless its a real nice car (flooded?) its not any more, its not worth fixing the engine. You need a new engine, or a used engine. .
Sep 02, 2010 | 1995 Toyota Camry
How much oil does it take
how much oil does my 1995 toyota camry 4 cylinder engine take?
Feb 15, 2010 | 2001 Toyota Camry
What is the size of the allen wrench needed to fit the oil pan drain plug in a 1995 toyota celica
The oil pan drain plug should require a 14mm hex head wrench to remove. The transmission pan requires a 10mm allen head socket, or wrench to remove. Are you sure you're trying to remove the correct drain? The oil drain should be on the passenger side and on the rear corner of the pan.
Dec 12, 2009 | 1995 Toyota Celica
98 toyota camry transmission service.
You can drain and fill your trans. It will take 2.5 -3.0 quarts of DEX III trans fluid....goes in the fill tube. Or you can get said transmission flushed which changes all fluid including torque converter.....about 15 quarts. Way more thorough.
Jul 12, 2009 | 2002 Toyota Camry
Tranmisson dran plug wranch size
The Toyota guide says that a 14mm hex head wrench fits "most" Toyotas from 1986 to current.
May 09, 2009 | 1994 Toyota Camry
Network Associates Oil Change 1.0 Full Version for PC Logo
131 people viewed this question
Top Network Associates Computers & Internet Experts
micky dee
kamal dev  jhalli
kamal dev jhalli
1860ph
Level 1 Expert
Are you a Network Associates Computer and Internet Expert? Answer questions, earn points and help others
