Question about Canon Office Equipment & Supplies
Can't auto copy odd sized pages.
On ImageRunner 4570 I want to copy a stack of credit card bills. However the copier only copies about 2/3 of each page. How can I get complete copies?
You need to turn off "auto paper select", and manually select an appropriate size /orientation, because the sheets are close enough to a particular size (based on the sensor locations) that the machine is choosing it for you.
Posted on May 28, 2009
How to fix id card fuction
first entered in SPECIALFETURES then
IMAGE COMBINATION then (Machine Ask Original Paper Size)
Select A5R (if the LTR Size Show tuch the AB botton)
Select 2 on one then select A4 paper tray
Then Screen Show Special features
DO NOT TOUCH RESET or Any botton
touch MODE MEMORY select M1 touch STORE then done then OK
Press the Additional Function Bottoan
touch Copy Setting
touch Standred key 1 setting
(in this Window show many botton)
choose modememory Select M1 Select OK
afterthat your home screen show M1 on Bottem Left corner when you touch ID CARD COPY Feature activate Scan 2 Time Front /back Print on Combind one Side Enjoy!!!!
Feb 25, 2015 | Canon ImageRunner 4570 | IR4570 |
How can I can get rid of "R" page/tray setting in copier shown on the screen
The only way I know of is to rotate the blue paper size dial on the paper cassette. The " R " is for the reduction of the copy image onto the paper when using an analog copier. With the new digital copiers the " R " is meaningless. The paper for " R " direction is paper that its length is going from right to left in the cassette and the plain paper size is paper its length is going from front to rear direction in relation to the copier.
Jun 23, 2011 | Canon imageRUNNER 4570 Copier
When I copy a document that is written from top to bottom of the page, I hit copy andI get a side to side copy of the document. How can I reset the copier?
enter additional functions; on screen, select copy settings>auto orientation>off.switch off the machine and re start.
Feb 10, 2011 | Canon imageRUNNER 4570 Copier
I am feeding a portrait fax letter size and it is being received partially - one half is cut off. please explain
It sounds as if the document feeder is not recognizing the proper size of paper. Try making a copy, is the copy correct or is the copier indicating to load a certain size of paper. The paper width guides as well as the raised tabs on the document feeder tell the copier the proper paper size. Could the problem be on the other end? I know I have several customers that have the paper size dials or indicators incorrect for the paper in their cassettes. This would be if only a single reciever of your fax is complaining. You may want to see if rotating the fax in the LTR-R direction works.
Dec 03, 2010 | Canon imageRUNNER 4570 Copier
I have a canon 4570 imagerunner,the problem i am facing is when i am printing a copy 2(sometimes 3) horizontal lines appears on the print.please sugest. Thank You
If the lines repeat in a regular fashion, with a consistent distance from each other, you need to replace the imaging drum. I would take a print out with the horizontal lines on it, then fold the paper up until two of the lines overlap each other; this will tell you the general diameter of the drum and give you an idea of what to look for inside the machine.
-David.
Nov 03, 2010 | Canon imageRUNNER 4570 Copier
When it copies, the copy comes out landscape and i can not change the paper select option to show portrait. also, it cuts off the bottom of the page as well
Kindly change the direction of the original. If at present you are keeping it horizontal way change it to vertical. You will get the correct print.
May 19, 2010 | Canon imageRUNNER 4570 Copier
The streaks are full page on both edges top to bottom and occur with printing and copying.
I suspect the drum unit might done its time.On this model you might find you can do 50000 to 90000 copies on your drum before it is done.First replace the drum.If problem sill presist the fixing unit can be the cause of the lines.
Dec 01, 2009 | Canon imageRUNNER 4570 Copier
How do i make a booklet?
Select BOOKLET function, found in SPECIAL FUNCTIONS. Select which size paper is required and then select FINISHER to select STAPLER and SADDLE-STITCH, then load your document into the document feeder. Select number of copies then press start button. All of this is only applicable if a Finisher and Auto-Doc Feeder is installed. Let me know if this helps?
Mar 14, 2008 | Canon imageRUNNER C3220 Color Copier
Canon Imagerunner 330s - Stack Bypass
you can select for tray (letter size ) as default in paper settings
the stack bypass paper sensor may be broken and is active all the time
Jan 29, 2008 | Canon ImageRUNNER 330s Copier
Legal Sized 2-sided Copies through Automatic Feed
Does the copier print correctly when copying off the glass? I suspect that the document feeder has been set up to feed other paper sizes eg A4, A4R. Because of the conflict between sizes the copier adjust the image.
Oct 05, 2007 | Canon imageRUNNER 5000 Copier
63 people viewed this question
old marine
old marine
