Question about Olympus Camedia Stylus 300 Digital Camera
Flas stopped working
The flash on olympus 300/400 has stopped working, and now the camera only operates when the flash is turned off. If any of the other flash settings are used the rest of the cameras other functions do not work.
    President:
  • 919 Answers
The problem you are describing is a problem with the flash charging indicator switch inside the camera. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $83 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Posted on May 29, 2009
The flas has stopped working on mycamera. It is
did you find out how to get it on because i cant and need help
Nov 19, 2009 | Sony Cybershot DSC-T200 Digital Camera
How do I get my camera flas to work
Without knowing what kind of camera you have there is a couple of options:
1. Press the lightning bolt lookin button.
2. Turn the program dial to a program which uses flash.
3. Check the manual.
Oct 25, 2009 | Canon Cameras
Flas not working, wrong info on displa
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
4.Set the flash to iconfillflash.gif.
If issue persists, call 1.800.235.6325 for repair.
Thanks.
Neerak21
Jul 21, 2009 | Kodak EasyShare Z740 Digital Camera
Flas on camera stopped working?
This is a common problem with this Model. In order to get this replaced you will need to send your camera to the fujifilm repair centre. They shall replace all of the part you require. Please browse to the following web address http://www.fujifilm.co.uk/technical/camera_repair/
Jan 16, 2009 | Fuji Rod Repair Kit
Olympus e500 internal flash not working
try resetting the camera back to factory defaults by putting camera in P mode, menu, custom reset
Jun 08, 2008 | Olympus EVOLT E-500 Digital Camera
Non-syncing Olympus FL-36
Hey I have an E510 and an fl 36 flash unit and no problems for a year now.
And no problems at all {knock wood]!
Have you checked to see if all the flash pins are making contact?
Normally I only turn my flash on after I put it on the camera and then turn the camera off and then on again to see if everything is ok. I remember the flash would not communicate with the camera on a shoot and after a while I realized that the flash was not all the way in the hot shoe. Fool around with the flash off the camera first and see the flash have modes that you have to set up if the mode is set in full manual that might be a problem. There is a button that you have to hold down for three seconds to get in the menu. My buttons are fine and have not faded any at all. I realize that the power button an the flash is hard to press on, I do hope I was of help .GOOD LUCK
From Chris
May 12, 2008 | Olympus FL-36 TTL Flash
My Olympus Stylus 500, doesn't work the flash
hi
have you tried using lithium batteries? alkaline batteries. just try out different batteries. if it is still the same, have your camera checked in a service center for maybe it needs a replacement or there is something loose inside.
hope this helps.
Jan 28, 2008 | Olympus ? Stylus 500 Digital Camera
SB800
When you attach the flas to the camera can exidentli fire. This is normal, and manufacturer recomendation, turn off the flas unit before attach or deattach, prevent this fireing. Fireing when you turn the flashead is not normal. Probably the mounting foot of the flash unit can move in the hotshoe, breaking connections between the connector pins, causing exidental fiering. Always lock the locking lever of the flas, wich can prevent this unwanted movement. Also chek the hotshoe on the camera, wich should to have a "leaf spring" keeping the flash unit steady.
Dec 07, 2007 | Nikon Speedlight SB-800 TTL Flash
Don`t turned on after missed reflashing.
Only Olympus Tech support can help you there.
May 22, 2007 | Olympus SP-500 UZ Digital Camera
Olympus Camedia Stylus 300 Digital Camera Logo
159 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
