Question about Carrier Heating & Cooling
The thermostat says EH where it should have the cool temp. it will not run the air
The thermostat does not have a cool option it says EH where it should have the cool temp? Samantha
  • moto2402 May 27, 2009
    it is a totalline thermostat. it is digital and was put in two years ago when the house was built.
  • Your an idot May 11, 2010
    emergency heat is eh or em heat, what type of tstat do you have, who set it up? digital or mecanical, need more data.
  • 148 Answers
That is emergency heat they may be a wiring problem or bad thermostat
Posted on May 26, 2009
The unit does not run and the display indicates "EH"....What does this mean?
EH is emergency heat. It could be the thermostat is not set of configured properly. Find the instructions and wiring diagrams for both the thermostat and the air-con to double check wiring of the thermostat to the air-con
Oct 10, 2015 | Heating & Cooling
Vegetables in crisper are frozen, as well as liquids in bottom 1/2 of fridge door. The fridge & freezer temp controls won't adjust to our settings. Also, we're getting ice, but no water will dispense.
The freezer cools the refrigerator, so you actually get very cold air passing from the freezer to the refrig. The air from the freezer enters the refrig on the top and falls to the bottom where it is drawn back into the freezer. The temperature of the refrig is regulated by a thermostat and a fan that runs when the thermostat calls for cooling. If the refrig thermostat is faulty and causes the fan to run more than it should, there will be a freezing problem in the refrig at the bottom because cold air falls and warm air rises. If the refrig is thermostat is calling for cooling constantly, this will take more cold air from the freezer than is normal. Your freezer temp might be higher than normal and the refrig will be colder then desired. If the fan from the freezer is running constantly I would suspect a bad refrig thermostat.
May 06, 2015 | Refrigerators
My Dometic digital thermostat wont go up past 32 degrees. What could be wrong?
indicates inside sensor defective or not communicating resulting in a/c being locked out.
Sep 16, 2014 | Dometic 3313192.000 White Single Zone LCD...
04 durango when on heat temp goes cold than back to warm
you could have air in the cooling system . did you do any cooling system repairs like a water pump or thermostat cause after the repair the cooling system has to be bled of any air in the system or you will get overheating issues also you should check for a stuck thermostat. hope this was helpful
Feb 28, 2014 | 2004 Dodge Durango
Where the a/c temp. should show, the letters"EH" appear. Heat pump is wqorking good but can't adjust the a/c part
My guess is that the EH stands for electric heat which is a mode that the thermostat is in. Change your mode to AC if you want it in air conditioning mode.
Feb 26, 2013 | Bryant T6-PRH EDGE Thermidistat Thermostat
Furnace blower runs after temp is reached
Is your tstat fan selector in auto?? Does the fan ever shut off?
Jul 18, 2017 | Heating & Cooling
EH code where cool temp should be
It seems to be like your thermostat is stuck in EMERGENCY HEAT mode programming. To Exit,
Press the FAN button. While holding the FAN button, press the UP button for 2 seconds.
If you need further assistance go with this site:
http://www.totaline.com/dl/P474-10101ForAllProgrammableDigitalThermostat.pdf
Is it helpful?
Jan 01, 2011 | Heating & Cooling
My honeywell Thermostat reaches the heating temp. but the fan will not stop running.And yes the fan is set to auto.It just keeps running and running and running.It stays the same temp but will not shut off...
I want to give a simple explanation before I go any further. On the heating side of a unit even though tthe temp has satisfied the thermostat, the fan will run until it cools down the plenum where the air flows from the air handler. There is a bimetal switch called a fan limit that operates the blower when the plenum reaches the temp set on the fan limit switch. Now if your fan keeps running even after the plenum chamber has cooled down, then you could have a fan limit switch that is stuck in the run position and must be replaced in order to correct the problem.
Dec 07, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
Honeywell Thermostat RTH 7500
Assumed all the wiring are correct,
to change from manual switching from heat to cool, press [system] button ( left ) to go into system setting.
then press and hold the [fan] middle button untill option display 120
use up down button to select option 300 ( Manual/Autochangeover) ,
select 0 for manual, 1 for automatic. ( read caution in page 22 of installation manual )
Good luck
Sep 30, 2008 | Heating & Cooling
Heating & Cooling Logo
279 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
