Question about Homelite Garden
Housing removal outside the Homelite clutch
More specifically how do you remove the circular housing outside the Homelite trimmer clutch?
  • 420 Answers
You must first remove the rear housing, then the shaft to access the clutch area.
Posted on May 27, 2009
Cant remove pull rope housing from homelite gas hedge trimmer
there is a screw in the hole of the clutch housing bell torx bit i think its a #20
Jun 04, 2012 | Garden
Removing bell housing
hello sir, ryobi trimmers and other models removal of the bell housing,removal of the metal bell housing,or clutch drum, on models 780R & 790R, here is what you do. after removing the trimmer & shaft assembly.remove the spark plug insert a screwdriver in the cylinder to keep piston from moveing. to remove the bell housing twist off the spring and using a T20 TORX screwdriver unscrew the retaining screw in the center of the bell housing (normal r/h thread) . push down firmely try not to strip screw head . you should be able to remove clutch housing.remove clutch using a pair of channel locks,works for me, (normal r/h thread) you should be able to remove front engine cover to repair what you need to.coil,pull stsrt, hope this works,. this solution applies to all trimmers with clutch removal~~~hope this helps,,any comments welcome,thank you. ``
Feb 10, 2012 | Daihatsu Rocky Cars & Trucks
Homelite hlt25cs, pull starter cord, wont engage starter clutch, cant find how to access it
Feb 02, 2012 | Homelite Garden
Change pull cord
hello sir, ryobi trimmers and other models removal of the bell housing,removal of the metal bell housing,or clutch drum, on models 780R & 790R, here is what you do. after removing the trimmer & shaft assembly.remove the spark plug insert a screwdriver in the cylinder to keep piston from moveing. to remove the bell housing twist off the spring and using a T20 TORX screwdriver unscrew the retaining screw in the center of the bell housing (normal r/h thread) . push down firmely try not to strip screw head . you should be able to remove clutch housing.remove clutch using a pair of channel locks,works for me, (normal r/h thread) you should be able to remove front engine cover to repair what you need to.coil,pull stsrt, hope this works,. this solution applies to all trimmers with clutch removal~~~hope this helps,,any comments welcome,thank you. 11
Jan 27, 2012 | Homelite Mighty Lite Lawn Trimmer
How do you remove the clutch so that the pull cord can be replaced
Dec 31, 2011 | Garden
Need to remove flywheel ryobi RLH1100 mark2
Nov 04, 2011 | Ryobi 15" Electric Factory Reconditioned...
Homelite 25cc model UT20002A. How to repalce starter string?
Remove the shaft assembly at the motor, there should be one or two screws on the boom clamp. Remove the four screws holding the starter housing on. Inside the front of the housing is an air baffle you don't have to remove and the starter pulley. Remove it carefully, you don't want the spring to come out of its container. Remove any vestiges of the old starter rope and install the new one with no more than three or four windings depending on the thickness of the rope you bought. Install the pulley in the housing with the rope through the slot in the pulley so you can wind it a couple times to catch the spring and start the tension. It should be tight enough to just pull the string back into the housing. Feed the rope through the hole in the housing then through the t-handle and tie a knot so it won't pull back through the handle. Put the housing on the motor, no screws yet, and pull the rope out to make sure nothing is binding and the rope retracts fully into the housing. If it's too tight use the slot in the pulley to take one winding out. If the t-handle dangles, add a turn to the pulley. Reassemble housing and boom and you're ready to go.
Aug 23, 2010 | Homelite Mighty Lite Lawn Trimmer
Starter rope
First, i will take that the rope is in the front. If so, you will need to remove trimmer shaft,throttle assembly, so you will be able to remove starter housing.
May 13, 2009 | Homelite Mighty Lite Lawn Trimmer
Replace a flexible curved shaft
If you go to www.homelite.comin the red area up top click on order parts then click - click to launch homelite parts catalog, then scroll down thru agreement and click agree and then you will need to know your model number and you can get a breakdown of your trimmer wich will give you a good idea of how your machine is put together.
Dec 16, 2008 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
231 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
