Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Ice Maker Not Working
I recently disrupted the water supply to our ice maker during the installation of a new osmosis system. After reestablishing water flow to the ice maker, it was discovered that the water is not refilling the ice resevoir. I disconnected the waterline at the rear of the ice maker and attempted to draw water up the line. It seems that the electronic solenoid that opens the water value at the base of the refrigerator, to allow flow is not functioning. Is this valve bad or is there something I can do to reset it.
    Novelist:
  • 103 Answers
Hi: A lot of reverse osmosis systems don't supply enough water pressure to the ice maker to fill. Contact your manufactrue of your reverse osmosis system and see if it works with icemakers. I thind usually the require at least 20-30psi. Or hook your refrigerator to city pressure to see if it works. Also I don't know if you have just an ice maker or a water dispensing side by side, or your water quality. If you just have an icemaker, most chlorine will evaporate before the ice is frozen, any odors in the water will still be there. Good Luck, Jeff
Posted on May 31, 2009
How do I "Prime the Water Supply System" refereed to in use and care guide that came with my new Kenmore French Door Bottom Freezer, #253.70413411. Cannot find instructions in the manual only reference to...
Assuming you followed the water line installation directions and you have water available to your new refrigerator/freezer here is the rest of the "priming" info you requested. (basically it tells you how to run a bunch of water through the system by filling cups or glasses to remove any debris and/or air...
Automatic Ice & Water Dispenser
Priming the Water Supply System
1. Begin filling the tank by pressing and holding a drinking glass against the water dispenser paddle. 2. Keep the glass in this position until water comes out of the dispenser. It may take about 1½ minutes. 3. Continue dispensing water for about three minutes to flush the system and plumbing connections of any impurities (stopping to empty the glass as necessary).
Ice Maker Operation & Care After the refrigerator is installed properly and has cooled for several hours, the ice maker can produce ice within 24 hours. The ice maker will fill the ice bin from the rear. You must dispense some ice to force the ice forward in the bin. This will allow the bin to fill completely.
Turning the Fresh Food Ice Maker On and Off Ice production is controlled by the ice maker's On/Off icon on the control panel. Press and hold the "Ice Off" icon for three seconds to turn the ice maker "ON" or "OFF". The ice maker is turned off when the LED above the "Ice Off" icon is illuminated.
Using the Ice Maker after Installation Before making ice for the first time, be sure to prime the water supply system. Air in new plumbing lines can result in two or three empty ice maker cycles. Furthermore, if the system is not flushed, the first ice cubes may be discolored or have an odd flavor.
CAUTION
For proper dispenser operation, recommended water supply pressure should fall between 30 psi and 100 psi. Excessive pressure may cause water filter to malfunction.
NOTE The water dispenser has a built-in device that shuts off the water flow after three minutes of continuous use. To reset this shutoff device, simply release the dispenser paddle.
IMPORTANT On occasion, unusually small ice cubes may be noticed in the bucket or in dispensed ice. This could occur in normal operation of the ice maker. If you start seeing these more frequently, it may be an indication of low water pressure or the water filter needs to be replaced. As the water filter nears the end of its useful life and becomes clogged with particles, less water is delivered to the ice maker during each cycle. Remember, if it's been six months or longer since you last changed your water filter, replace the water filter with a new one. Poor quality household water may require the filter to be changed more frequently.
IMPORTANT Your ice maker is turned on at the factory so it can work as soon as you install your refrigerator. If you cannot connect a water supply, set the ice maker's On/Off icon to Off and turn off the water supply valve; otherwise, the ice maker's fill valve may make a loud chattering noise when it attempts to operate without water.
Hope this helps. Randy
Mar 02, 2015 | Kenmore Refrigerators
Ice maker mal-formed ice
no "slug" is available however you could just use a reverse osmosis diaphram pressure tank to boost the water pressure. you can also use a water supply tube to bypass the in-refrigerator completely.
Jul 22, 2010 | KitchenAid Superba Architect KSCS25IN Side...
Ice maker quit working
For starters, the freezer temp must be a least 14 degrees or colder. Ice maker locks out above 14 degrees.
So.
1. The water valve on the bottom back of the fridge has failed (common problem).
2. Water supply from source to the water valve isn't supplying water or enough water pressure (common problem).
3. Fill tube that fills the back of the ice maker is iced up. If thats the case, you will need to defost it slowly USING NO HEAT. Heat will melt components and leave you with a real mess. If this is the case, you'll still have to replace the water valve because it is leaking slowly during the of cycle.
4. The ice maker failed. You can test to see if it will cycle, by pouring water into the cavity, and checking it in a few hours to see if it dumps. Be aware there is a switch in the ice maker which tells the water valve to fill. If that's the problem, you'll still need to replace the ice maker and installing a new valve at the same time is the smart way to go.
Oct 24, 2009 | Whirlpool Refrigerators
WP side-side freezer appears to be overflowing the
You just need a new water valve for this unit. Call us with your midel number and we'll be sure to get the right part out to you right away! We look forward to hearing from you soon.
Oct 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My whirlpool ed27dqx refridgerator quit making ice immediately after I had my reverse osmosis drinking water system upgraded. I replaced the ice maker unit and the dual water valve. I have always had water...
The pressure from a reverse osmosis system is not sufficient to operate the ice maker water valve. A water valve requires a minimum of 20 pounds of pressure without a refrigerator water filter, and 35 pounds of pounds of pressure with a refrigerator water filter. Manufactures do dot recommend installing an R/O system on the water supply to a refrigerator. The pressure may have been higher from your old system.
Apr 28, 2009 | Refrigerators
I have a Whirlpool Model EC3JHAXRL00. The ice
Is the ice maker wire shutoff arm or switch (depending on
models) in the OFF position?
 Is the water line shutoff valve to the refrigerator turned on?
 Has the ice maker just been installed? Is the freezer
temperature cold enough to produce ice? Wait 24 hours
after ice maker hookup for ice production to begin. Allow
3 days after ice production begins to completely fill ice
container.
 Does the ice maker mold have water in it or has no ice
been produced? Make sure your refrigerator has been
connected to a water supply and the supply shutoff valve is
turned on.
 Has a large amount of ice just been removed? Allow
24 hours for ice maker to produce more ice.
 Is there a water filter installed on the refrigerator? The filter
may be clogged or installed incorrectly.
 Is an ice cube jammed in the ice maker ejector arm?
For models with an interior ice bin, remove the ice from the
ejector arm with a plastic utensil.
 Is a reverse osmosis water filtration system connected to
your cold water supply? Make sue your connections are secure.
Feb 19, 2009 | Refrigerators
The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
Hello jitkagardner,
Welcome
You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
How old is the fridge?
When have you last changed the water filter.
Should be down below at the front grille!
Try these tasks!
If the ice maker is not producing ice or not enough ice
Refrigerator connected to a water supply and the supply
shutoff valve turned on? Connect refrigerator to water
supply and turn water shutoff valve fully open.
• Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
• Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
• New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
• Freezer door closed completely? Firmly close the freezer
compartment door. If the freezer compartment door will not
close all the way, see "The doors will not close completely."
• Large amount of ice recently removed? Allow 24 hours for
• Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
• Water filter installed on the refrigerator? Remove filter and
operate ice maker. If ice volume improves, then the filter may
be clogged or incorrectly installed. Replace filter or reinstall it
correctly.
• Reverse osmosis water filtration system connected to
your cold water supply? This can decrease water pressure.
Let me know how it goes!
Huuum
Please remember to leave a rating!
Oct 21, 2008 | Refrigerators
ICE MAKER NOT WORKING CORRECTLY
Hello deloreslovat
welcome,
You said ,your ice maker makes the ice but does not drop it into the bucket. It just leave it in the upright position in the ice maker device. It also seems to not be making all of the ice cubes only a portion of them.
Here are somethings to check that may cause this
The ice cubes are hollow or small
NOTE: This is an indication of low water pressure.
Water shutoff valve not fully open? Turn the water shutoff
valve fully open.
See “Water Supply Requirements.”
 Questions remain regarding water pressure? Call a
licensed, qualified plumber.
Let me know if this helps.
Huuum
Oct 13, 2008 | Whirlpool GS6NBEXR Side by Side...
Side by side refrigerator
The ice maker is not producing ice or not enough ice
production.
OR
The water dispenser will not operate properly
 Freezer door closed completely? Close the door firmly. If it
does not close completely, see “The doors will not close
completely.”
 Is the water pressure at least 30 psi? The water pressure to
the home determines the flow from the dispenser. See “Water
 Kink in the home water source line? Straighten the water
source line.
 New installation? Flush and fill the water system.
 Water filter installed on the refrigerator? The filter may be
GOOD LUCK TO YOU!!! LET ME KNOW IF THIS SOLVED YOUR PROBLEM
Jan 31, 2008 | Whirlpool ED2FHEXN Side by Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
287 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
