Question about Samsung Eternity Cell Phone
Camera scratch i seemed to have some how scratch the glass/or plastic piece thats over the camera, so now the pics are jacked up, i just got the eternity, and i have no phone insurance
    President:
  • 2,004 Answers
Consider taking it for some repairs. i wont cost up to $5.
Posted on May 26, 2009
My camera doesn't see SD 16GB anymore. Worked fine until a few days ago. SD works fine on PC
Try inspecting the memory card slot, eventually with a magnifying glass. Sometimes just a little bit of dust, a small paper or other debris, can block data transfer. Be sure al contacts on the card, but also in the camera are clean and shining. Never use sharp tools in or around a camera. Don't scratch the contact points.
And to make sure you can put pictures on a memory card, there must be space. If possible try to format the card in the camera. Just to make sure the camera sees the correct file system on the memory card.
Dec 15, 2013 | Panasonic Lumix DMC-FZ28 Digital Camera
I have a Sony DSC-W370 and the outermost glass lens has been scratched (by a piece of sand, I think). It's ruining every shot I take, really, but everything else on the camera works fine. I can't seem to...
You cannot replace the lens assembly. This must be done by a Sony repair service center. You cannot "polish" the lens without completely ruining it. Replacement is going to be expensive. Get an estimate and then decide if it's worth it.
Dec 18, 2010 | Sony Cybershot DSCW370 Digital Camera
There is a cracked viewing lense.
What kind of camera is it? on most canon cameras you can remove the viewing lens and replace it. Some just snap off and some have a rubber outer piece that you can pull off and 2 philips screws to remove the hard plastic piece and glass. you can get a new one cheap off amazon.
Aug 10, 2010 | Canon Cameras
Is the lense platic or glass on the Logitech QuickCam for Notebook? I read that the C250 has a plastic lense and the C500 is glass. Does it really make a lot of difference?
not much difference other than the glass is probably going to last longer and not be scratched as easily. and it is probably more precise than a plastic lens
Jan 15, 2010 | Logitech QuickCam for Notebooks Pro...
The lens cracked. The camera still works but the picture shows cracks. Is it possible to repair it?
The same thing happened to mine. Customer support was useless, telling me I voided my (expired) warranty by breaking it, and that it is not a replaceable part.
Here's the fix that worked for me:
If you look closely at the metal bezel around the lens, you will see a seam between two metallic parts, near the front surface of the lens.Take a knife and gently work it around that seam until you separate the two pieces. They are held together with doublestick tape, so they come apart easily. That will expose the lens which is actually not a lens at all, it's a window; a flat glass disk. Take the tip of a pointy knife and gently pry the glass piece(s) off. Again, this is held on with double-stick tape so it will come off easily. If you can find a glass disc that is the same diameter and thickness, you can place that in. The disc is a 20mm diameter by 1mm thick. You can probably order a replacement watch crystal from somewhere like this place:
http://www.esslinger.com/roundmineralglasscrystalx1mmthick.aspx
They cost less than a dollar (not including minimum orders, shipping, etc), and they are probably more scratch/crack resistant.
If you don't want to bother replacing it, your camera is still fixed, just a bit uglier and vulnerable to dust. The front lens has no optical significance, it's just a dust cover and/or a design element.
The metallic bit you took off is little more than a piece of tin foil.
Had they used a more substantial part that could divert shock instead of directly transferring it to the glass, there would be far fewer cracked lenses out there. But that would probably hurt their "go buy a new one" repair policy.
Jul 12, 2009 | Pure Digital Flip Video Ultra Camcorder
Yukon yd-100 lens removal for camera fitting seems like thred is broken
When you say lens, did you unscrew the eye piece or the actual lense? because the eyepiece is meant to fit your adaptor for 35mm cameras etc. but the actual front lense should be tightly sealed and thread locked to make your glass (scope) waterproof to some extent and to protect the alignment of the other lenses within your scope. If it is possible your local camera shop may have the ability to re-align and seal your scope, but if not do you have a warranty? and if not even that, if i were you i would align and accraglass your piece back together, it's a last ditch solution that should last for years.
Apr 27, 2008 | Yukon 100X (6-100x100) (6-100x100 mm)
Card cover open error, but I have pics on the camera!!
Look on ebay for a replacement door. shoundly be too expensive
Sep 25, 2007 | Olympus FE-130 Digital Camera
Soldering 'Card Cover Open' Switch Closed
I had the same problem after a little plastic trigger thing fell out of the hole above where it says push to eject. After poking around for a while I took the camera apart (remove 7 screws) which made it much easier to see, with a magnifying glass and lamp, what the problem was. A damaged wire that needed to be connected to something. Only the very end of the wire was visible, inside a small white plastic box thing. The plastic box thing eventually fell apart with my attempts to put in bits of wire of varying shapes. When it came loose I was left with a short stiff bit of wire. I took a strand of copper wire (from an old piece of electrical wire), twisted it so I had a small loop at one end, looped it over the end of the stiff bit of wire, and then curved the rest of the wire (about 3 - 4 cm long) so it was resting on a silver piece of metal just below where the white plastic box had been. Put the cover back on and the camera worked. Needless to say, it won't let me know if I've left the cover off, but then it won't work unless the cover is on, so it doesn't seem to matter. Saved about $100.
Aug 13, 2007 | Olympus FE-130 Digital Camera
Connection
the jack that is affixed to the board has already been damaged beyond repair, which means that if it were ripped out the odds of micro soldering those connections are not likely, (I've tried similar on cell phones they us a chemical soldering method and precision heating to make the connection, bet bet is to find a camera connection for the camera and transfer pics to the cam to print on the dock. Good Luck
Mar 17, 2007 | Kodak EASYSHARE Plus Series 3 Thermal...
Samsung Eternity  Cell Phone Logo
42 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
