Question about Kenmore 62602 Electric Dryer
My kenmore 70 series dryer isn't drying - changed the heating element, changed the thermal fuse, and the high limit thermostat. Lint is cleaned and the motor is running.
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Have you checked the voltage at the wall receptacle? You should read 220-240VAC across the two hot leads (left and right slots). If you're not reading the correct voltage (i.e., missing one leg of your service), the dryer will still run, but the heating circuits will not operate.
    Scholar:
  • 85 Answers
Are you getting any heat at all? Did you change the thermal cut-off which is mounted near the top of the heater box? This is the only other piece in the heating circuit. If you changed it already you could have problem in the timer or in motor. There is a switch in the motor that controls heat also.
Posted on May 27, 2009
Won't heat up
I don't know for sure but have you checked out you exhaust sometimes it can get full of lint and your lint filter take a dry dryer sheet and wipe it down you hope this helps Merry Christmas
Dec 09, 2017 | Kenmore Dryers
No heat from tumble dryer
Hi.
If dryer is electric check for lint obstructions, check ventilation, test thermal fuse, thermistor, cycling thermostat and high limit, element and fan.
If dryer is gas check for lint obstructions, check ventilation, test thermal fuse, thermistor, cycling thermostat and high limit, igniter, coils, burner, flame sensor and fan.
Dec 14, 2011 | Washing Machines
I have a Kenmore Series 70 Dryer and I changed the thermal fuse got hot for a few minutes the model #110.74722400
The cycling thermostat must also be replaced when replacing the thermal fuse. The cycling thermostat's failure to cycle off the heating element results in overheating of the dryer which consequently blows the thermal fuse open.
Replacing only the thermal fuse should the dryer stops running and fails to start will result in its premature blowing or even the thermal cut-out (cut-off) located on the heater duct. Like the cycling thermostat, the high-limit thermostat must also be replaced once the thermal cut-out blows open. Refer to the parts diagram in the link below and look for item numbers 31(thermal cut-off), 34(hi-limit thermostat), 39(thermal fuse), and 41(cycling thermostat.
Kenmore Series 70 Electric Dryer (110.74722400) Bulkhead Parts
Aug 21, 2011 | Dryers
No a kenmore 80 series dryer will not heat . if the heating elment is good & fuse is good what else could be the problem
The heating circuit is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The problem is very likely in the thermal cut-off and the high-limit thermostat located on the blower housing. The thermal cut-off blows when the high-limit thermostat fails and cuts power to the heating element. Both the thermal cut-off and the high-limit thermostat need to be replaced if the former is blown open. Click on the link below for the detailed instructions in troubleshooting this kind of problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
Mar 09, 2011 | Kenmore Elite HE3 Steam 8676 Dryer
Kenmore elec dryer series 80 not heating up
The problem is in the thermal cut-off (cut-out) and the high-limit thermostat located on the heating element housing. Verify this condition by bypassing the said components. Disconnect power then access the thermal cut-off (cut-out) and the high-limit thermostat. Disconnect the wires of each component then connect them together and insulate it properly. Reconnect the power then start the dryer. The problem is indeed in the thermal cut-off (cut-out) and the high-limit thermostat if the dryer heats up. Replace both parts and it should solve the problem. It is an easy and cheap repair to make. Indicate the exact model number of the dryer should you need further assistance.
Dryers with lint filter on the front.
Dryers with lint filter on the top.
Dec 18, 2010 | Kenmore Dryers
My kenmore 70 series dryer is not heating up. At first it just took longer and longer to dry, but now it isn't drying at all. This happened after the dryer was moved in order for the washing machine to be...
Not funny at all, I suspect. It sounds like the problem originated due to a faulty high limit thermostat or a partially burnt heating element. I would replace the thermal fuse and the high limit thermostat. These two components can be purchased as a set. Also check the heating element. It can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a bad component. The thermal fuse is normally attached to or near the exhaust duct and the high limit thermostat is attached to the internal ductwork. The thermal fuse can be tested in the same manner. I will attach a photo of a high limit thermostat and thermal fuse for reference. Sorry for your trouble and I hope this helped. Best wishes.
Sep 01, 2009 | Kenmore Dryers
Kenmore 90 series electric dryer. Buzzez when you press the start. Sometimes it runs for a couple minutes then shuts off. is this the motor or a start capacitor?
Thermostat controls heat. There is also a motor centrifulgal switch, in the element circuit, that the motor closes to insure the motor is turning. Try another heat setting. There is more than one thermostat. You may have blown the 'thermal fuse' too, which requires replacement.
Tripped high limit. Must clean the lint filter and the exhaust vent tube and all the way in to the dryer. Hot air exit is restricted.
Jul 07, 2009 | Kenmore 659 Electric Dryer
Kenmore electric dryer heats but does not dry the
Hi, Here are the obvious parts to check: Heater, High limit, Thermal fuse or thermostats...these are all generally located in the back but some models you access them from front. the most common cause is either heater or thermal fuse, I will include a picture of the thermal fuse. If you test these parts and find they all work you may be looking at a centrifiacal switch problem.
Here is a picture of the thermal fuse check this part first:
http://www.partselect.com/repair.aspx?appliance=dryer&part=replace-thermal-fuse
Please feel free to contact again if you have any other problems.
Hope this helps.
Jun 23, 2009 | Kenmore 63942 Dryer
Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Apr 06, 2009 | Kenmore 64742 Electric Dryer
Kenmore 62602 Electric Dryer Logo
222 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
