Question about Hampton Bay 92650 Stand (Pedestal) Fan
Pedestal fan motor
I have a pedestal fan that I used in my construction business drying out carpets, moving stagnant air out of work areas etc and it finally gave up the ghost and quit working (burned out) and I would like to find out where I can get a replacement motor for it. The housing and blades are NOT damaged and I would like to use it this summer in my work shop but I need a new motor for this Hampton Bay Pedestal fan hpv 20b part # ? Thanks Diamond Dave Fan has stopped working can i get a replacement motor in the philadelphia area
    Champion:
  • 248 Answers
You may be able to get a replacement motor in your area,but it will most likely cost as much as a completley new fan.these type motors in my area usually run around 100.00
Posted on Oct 06, 2010
Blades moving but cant feel no air
if it is a newly installed overhead fan check the fan direction switch just above the motor
Jun 30, 2016 | Dryers
Tip
Dyson Cool AM08 Air Multiplier pedestal fan - Getting started
How to assemble and use your new Dyson Cool AM08 Air Multiplier pedestal fan: adjust the power and oscillation, set the sleep timer and store the remote. The sleep timer can be set between 15 minutes and nine hours.
on Mar 07, 2014 | Dyson Dryers
NEED NEW MOTOR OR FIX MOTOR ON A 20" PEDESTAL FAN
It would probably be cheaper to just buy a new fan.
Jun 19, 2013 | Lasko 1820 Stand (Pedestal) Fan
Motor replacement
Sorry. That's what happens when you buy a store brand.
May 09, 2013 | Hampton Bay 92650 Stand (Pedestal) Fan
I have a 30" pedestal fan that is missing the blades. I want to get replacements.
i would google the model number and/or the brand name "pro standard" and see what comes up, find out who the manufacture is and then contact them, just replacing the blade with another that might fit can lead to death of the motor, the pitch of the blade is the critical factor too much and you will overload the motor, causing it to go out on overload or just burn it out. not enough pitch it will work but will be less efficient ie... not move as much air as the original
Jul 09, 2012 | Dryers
Have an expensive Hunter indoor/outdoor pedestal Fan that stopped working. It just "hums" and does not turn. Please help.
With the fan UNPLUGGED, try to spin the fan blade with a pencil or something that will fit through the blade cage.
If the blade spins easily, there is an electronic problem (control or motor) that must be serviced.
If the fan blade is stuck or very hard to move, the shaft and bearing are probably dirty and need to be cleaned. You can temporarily fix this with a tiny amount (a drop) of WD-40 applied to the shaft where it enters the motor. Spin the blade manually to work the oil into the bearing. If the motor spins freely, the dirty bearing condition is verified. To properly clean the shaft and bearings, the motor must be disassembled.
Jun 11, 2011 | Hunter Floor Stand Fan Stand (Pedestal)
Fan is making squeeling noise when running.
After reading dozens of similar problems on here about the Vornado fans squealing (and rattling) it seems they are in need of some 3-in-1 oil for the bearings and any moving parts in and around the motor area.
Also good to keep the fan clean by wiping down and removing front grill and the fan blade...A high pressure duster or spray air canister for the motor body etc. should get out any dust inside the unit.
good luck!
Oct 19, 2010 | Vornado 785 Stand (Pedestal) Fan
LG washer vibration
My wife and I originally had the same problem, and it didn't help that the washroom was a slick tile floor. First add as much weight as possible to your pedestal. We have ours full of detergents, bleach, fabric softener, etc., and have several of each so that the pedestal is completely full. When mounted on the pedestal, the washer is quite top-heavy, and the added weight in the bottom helped immensely. Second, make sure your washer is level, both the feet resting on the pedestal and the feet of the pedestal itself, and tighten the secondary rings so the feet don't vibrate out of place. Last, I purchased some thin rubber padding (approximately the thickness of leather) from Home Depot in the carpet aisle. Cut some small squares and place one under each foot of the pedestal. This gives the feet some additional "grabbing power" on slick floors.
Feb 16, 2009 | LG WM-2277HW Front Load Washer
Wiring
12,000-BTU Portable Air Conditioner with Manual ... 3135 30-Inch Oscillating Industrial-Grade Pedestal Fan ~ Lasko ... 42.62 : Soleus Air FCM-30 12-Inch Convertible Stand/Table Fan ...
Aug 25, 2008 | Lasko 1820 Stand (Pedestal) Fan
Pedestal fan motor
Go to this link and find the dealer local to you; http://hamptonbayinfo.com/Product.aspx?pid=9eb435cd-4f97-4074-bdf3-630f1efd7a83&cid=791075 They should be able to either supply parts or tell you where to get them. Hope this helps, sorry for the delay but there are more problems than experts available at the minute :)
Mar 18, 2007 | Hampton Bay 92650 Stand (Pedestal) Fan
Hampton Bay 92650 Stand (Pedestal) Fan Logo
838 people viewed this question
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
