Question about Delphi Roady XT XM Radio Receiver
Antenna not working
I can it says antenna on screen and the antenna ishooked up can you help with prob Delphi Roady XT unit says "antenna" in my vehicle docking station and in my boombox at home. Works ok in my office boombox. No frayed wires on either antenna, and my bf's roady works just fine in any of the docking stations. A small brass(?) cylindrical metal piece on the bottom of the unit (where it plugs into the antenna jack) came out of the unit. I put it back in and thats when it stopped working. Any suggestions? Thanks!!
SOURCE: Delphi Roady XT Quit Working
This sounds like the problem I posted about the a/c adapter. The radio doesn't get enough power because the scr in the a/c adapter is failing.
Posted on May 14, 2007
SOURCE: URGENT Belkin F5X007*****Please Read!!!******
same thing happened to me and I had to take the radio back to Walmart...
Posted on Sep 06, 2007
Slinteriors
  • 8617 Answers
Here is a link where you can download a user manual for free that may give you the info that you need to reboot/ rset it. Let me know if you need any further assistance.
Posted on Jan 24, 2008
Puterwiz82
  • 60 Answers
SOURCE: unit displays xm sat radio but will not tune to
Did you try reseating it in the cradle? Check the connections to the cable too
Posted on Jun 06, 2009
dmftrucker
  • 1922 Answers
SOURCE: Roady XT "Antenna" problem
one of 3 things, either your antenna is not insight of a skies view to receive the signal, or its wire is broken at the antenna, but if you remove the antenna connection frequently it pulls the center wire out of the connection on the end that fits into the radio when its plugged in push on the conductor at the back of the plug and see if this helps,alos if connection is loose take a safety pin and carefully between the outer plug case ans the ground fingers around the center pin push these in so you get a better ground, and lastly try another substitute antenna, I have re-soldered my connections numerous times to fix this issue, delphi doesn't make a very rugged product, good luck
Posted on Nov 17, 2009
How to repair antenna connection on delphi roady
Copper czge? You mean the plug that goes into the base unit? Or just the antenna connection on the roady?
May 17, 2014 | Delphi Roady XT XM Radio Receiver
Nov 17, 2009 | Delphi Roady XT XM Radio Receiver
My Delphi Roady XT will not maintain signal
if you plug and unplug your antenna connection to the receiver a lot it loses the ground(shielded) line connection, if your lucky you can take a safety pin and CAREFULLY bend the radios 4 outer shell antenna contacts inward to make contact with the antenna connector, if its the plug on the antenna,try pushing wire in toward plug connection to the radio...delphi never had much for life on any external products that fit their XM radios but when you need repl parts boy are they waiting for you, and they got them
Aug 30, 2009 | Delphi Roady XT XM Radio Receiver
My Delphi Roady XT receiver will not maintain the signal. Does not work even I replaced the antenna. Works for a about 5 minutes before losing the signal
I had the same problem with my xt two years ago. I had two other roadys' at the time and they both worked with that antenna so I called xm customer service explained what was happening and they sent me a new receiver for $10. They told me that those units aren't worth trying to repair. Maybe you'll have the same luck I did. Give em a shout. Good luck.
Aug 19, 2009 | Delphi Roady XT XM Radio Receiver
Roady xt Antenna Problems
when it reads antenna it means there something wrong with either the connection or the antenna itself, it could be the location of the antenna or the antenna is going bad. if there is no obstructions on the car blocking the antenna i would advise purchasing a new antenna. you can get one at http://shopdelphi.com/consumers/satradio/xpressrc/
Feb 07, 2009 | Delphi Roady XT XM Radio Receiver
Antenna not working
Did you try to wiggle or remove and reinstall the antenna by the connection? sometimes that works. Are there any frayed or exposed wires on the antenna cable. You may have a short.
Jan 04, 2008 | Delphi Roady XT XM Radio Receiver
Delphi Roady XT Radio won't turn on
You need to replace the transformer that plugs into the wall.
Dec 17, 2007 | Delphi Roady XT XM Radio Receiver
Roady XT periodic errors
The pins get easily damaged when switching from the car dock to the Belkin boom box. I have to constintly squeeze very ******* the top of the xt in order for it to make contact. Belkin will send you a plastic alignment fixture but it is too late. It still does the same thing.
Jun 18, 2007 | Delphi Roady XT XM Radio Receiver
Chances are it's not picking up the XM signal. First, contact XM to resend your setup. if that doesn't work check your antenna connections.
Oct 31, 2006 | Delphi Roady XT XM Radio Receiver
Delphi Roady XT XM Radio Receiver Logo
187 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
