Question about Polaroid DRM-2001G DVD Recorder/HDD Recorder
I have no video after accidentally making video output changes
I accidentally changed my video output from interlaced to progressive. Now the left side of screen is black and the right is white. I can hear the audio when playing DVD's only. What do I need to do to reset it to factory defaults. I can not see the menu to make any changes. Please help me.
  • 1 more comment
  • John Jackson Jan 18, 2008
    My DRM-2001G came from The Polaroid remote was replaced by a Philips Universal that doesn't seem to have an PS/IS button. There is documentation included that sasy the PS/IS key is mapped to the 'Exit' button on the Philips but no such key exists on the included remote. Any other way to get the Polaroid to reset?
  • MikeyB311 Feb 11, 2008
    I did the same thing, and I need the factory default back. How do I do it?
  • Anonymous Feb 15, 2008
    I have no video after accidentally making video output changes problem, and notify you when a new solution is offered.
I had the same problem. Thought the unit was trashed. But the solution was so simple. There is a button on the remote PS/IS. Just press this button and the problem is solved.
Posted on Nov 09, 2007
How do I turn off pscan on a rca dro2oon DVD player
If you don't have a Progressive Scan TV or you don't have the DVD player connected to the correct Input Jacks, and you activate Progressive Scan in the DVD player you won't see a picture! Don't panic-try the following:
First, press the PREV/VIDEO button on the front of the DVD player (it will go to the next video output option, which is an interlace output so a picture should appear on the TV screen). If that doesn't work, press and hold PREV/VIDEO button on the front of the DVD player for 3 seconds. Now, press the PREV/VIDEO button again (it will go to the next video output option, which is an interlace output so a picture should appear on the TV screen). If you still don't see a picture on your TV screen, make sure the yellow cable (provided) that is attached to white and red cable (called audio/video cables) is connected to the DVD player's PREV/VIDEO jack and the TV's Video Input jack. Change your TV channel to your TV's Video Input
channel that activates the TV's VIdeo Input jack where you have connected the yellow cable (page 9 of your manual has more information).This PREV/VIDEO jack on the DVD player always outputs interlace video, so you should see a picture on the TV screen.
As a last resort, you can reset the DVD player to the factory default settings:
Press and hold the STOP button on the remote control and the NEXT button on the front of the player at the same time - wait at least 5 seconds before you release both buttons
Sep 25, 2016 | RCA Televison & Video
Hi, I've a small problem cocerning this dv-363 player. I accidentally set it to 'progressive'. Now I cannot undo. I tried holding the buttons on remote and on machine itself, still not working, can you...
Progressive Scan is a menu option relating to video output of this player. Assuming you have the original DVD remote, this should be easy.
* From the user manual (pages 50-51 of the pdf document):
About progressive scan video
Compared to interlace video, progressive
scan video effectively doubles the scanning
rate of the picture, resulting in a very stable,
flicker-free image. Progressive scan video is
available only from the component video
If you connect a TV that is not compatible
with a progressive scan signal and switch
the player to progressive, you will not be
able to see any picture at all. In this case,
switch everything off and reconnect using
the supplied video cable (see Easy
connections on page 14), then switch
back to Interlace. Switch the player to
standby then, using the front panel
controls, press STANDBY/ON while
pressing 'back to Interlace.
Hold these 2 buttons together for about 10-15 seconds or so, but only while the player is in standby mode. *
If you have lost the manual, you may be able to download the user guide (as an adobe reader (pdf) document) from:
(it will ask you for an email address prior to downloading - use a blank address if possible and enter the security code in the fields then save the document)
If the above suggestion does not switch it back to interlace, you will need a TV with progressive scan function to enable you to access the player's on-screen menu and in 'Initial Settings' 'Video Output' 'Component Out' section, select 'Interlace'. and press OK from remote as required.
Either way, it should NOT require a workshop service, and is simple enough to do at consumer level with the right TV type.
Mar 05, 2011 | Pioneer DV-363 DVD Player
Hello. I switch an option, i switch to progressiv option and i dont see anithing how can i reset the DVD player? It is a piooner DV-300-K DVD player. Thanks for help.
According to the Pioneer FAQ for this item :
"You can reset all models of DVD Players with the following method:
1) Switch the player into standby and empty the disc tray.
2) Using the front panel buttons, hold down the STOP button and press STANDBY/ON to switch the player back on."
Mar 03, 2011 | Pioneer DV-300-K Player
I am stuck in the Progressive Scan Mode on my DVD player & cant get it out of the blue screen. I have tried reseting it & even unplugging the player.
If your TV does not support progressive scan, you won't be able to get out of the blue screen. The only way to solve this issue is to connect the unit to a multistandard TV which has this capability, then in the player's on screen menu, look for anything that would allow you to select either progressive or interlace as its video output (or has progressive on and off feature) - and switch progressive 'off'. This should revert the output back to interlace. Then unplug the combo, reconnect it to your original set, and it should work fine after that.
Not impossible to correct, but a real pain if progressive is selected in a DVD player's output and the TV does not have that feature. Some DVD players have progressive output as a default option in their setup. Reverting it to interlace or turning it off so it matches the TV it is connected to should solve this problem.
Feb 16, 2011 | Goldstar GBV241 DVD Player/VCR
I accidently hit progressive button. Since the screen on my television is now black, I cannot see the menu to change to interlace. What do I do?
Hook your TV up to the yellow composite output, which is usually always interlaced on most DVD players. You should then be able to see the DVD output and can go in and change the component output back to interlaced. Then hook it up normally.
Alternately, you can take your DVD player to a progressive TV, either at a friend's house or even a home theater store to "test" it in progressive mode and then change it back to interlaced.
Nov 30, 2010 | Samsung Televison & Video
I want to set up my dav-fr10w to 'interlace' option so i can play the dvd's on my tv, but it's set to 'progressive' right now and the instruction manual doesn't give the specific information to change it....
To cancel Progressive scan output or to change output to interlace signal format, follow these steps..
1- Select DVD by pressing Function button on unit.
2- While holding down |<< (review) button, press Function button on unit.
This will change output signal to interlace/ composite video output from yellow pin/ S-Video.
Hope this info will help you.
Feb 05, 2010 | Sony DAV-FR10W System
Split Screen
Go into SETUP
Go to VIDEO OUTPUT (can't see through error message, but it is the second one down - If you are on the right one, you will see S-Video, YUV Interlace and YUV Progress. as choices)
Change setting from YUV Progress to YUV Interlace
Mine was set on YUV Progress. and when I changed it, the problem disappeared.
Mar 06, 2008 | RCA DRC200N
Progressive scan
Approach 1: Try unplugging the DVD player from the wall for an hour, then plug it back in. It may or may not reset to the factory default settings, which might put it back to "interlaced" output.
Approach 2: When a DVD player is switched to progressive scan, it uses outputs different from the coax cable "TV out" and the COMPOSITE outputs (often yellow, white and red RCA jacks. If you have the proper cables, you can connect them to both the DVD player and the TV, then cycle through the AKAI TV's "source" settings to switch the TV to the new cable input location.
For example, if the DVD player has "component" outputs (marked Y, Pb, and Pr) hook up RCA plug cables between those jacks and the AKAI TV's Y, Pb, and Pr jacks. Connect the Y to Y, the Pb to Pb, and the Pr to Pr, of course. The LCT3285TA has two sets of these jacks. Either will do, but note if you use YPbPr1 or YPbPr2. Once this is done, push the source button on the side of the TV (or on the TV's original remote) until it shows YPbPr1 or (...2 if that's what you connected). If the DVD player is on, you should now see the DVD menu or the picture from the DVD. Now you can use the DVD remote to switch back from progressive to interlaced video. The picture may go blank at this step.
Now push the TV's source button again until you see "3" or whatever channel you had been using in the upper left of the TV screen. You should see the DVD output picture (menu) again. Back to normal.
If your DVD player doesn't have YPbPr connections, it may have a HDMI or DVI jack.
The AKAI TV also has a HDMI input, you *could* get and HDMI cable (or DVI to HDMI cable if the DVD player doesn't have HDMI), hook it up, then cycle through the TV's source inputs until you see the HDMI in the upper left... in the manner I've just described.
Final Note: The progressive scan output of your DVD will actually give you a much better picture on your AKAI TV than its interlaced output. To take advantage of that, you'll have to hook up YPbPr or HDMI cables between player and TV and switch sources when you want to watch DVDs instead of TV programs. You may need additional cables to send the stereo audio output from the player to the TV for the progressive source hookup.
Jan 05, 2008 | Akai LCT3285TA 32 in. LCD Television
DVD recorder: Changed the settings, now
we could go through the setting like, you can see the monitor. using the remote do the following steps:
Step 1. press set up button.
Step 2. press down arrow once. ( playback)
Step 3. press OK.
Step 4. press down arrow once. (video (selection))
Step 5. press OK. (progressive scan)
Step 6. press OK, again.
Step 7. press down arrow once. (progressive scan off)
Step 8. press OK
you have now turned progressive scan off.
Dec 19, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Progressive Scan Mode Resetting
Hi, Open the CD and press return on the remote to reset it back to Interlace mode. Thanks Annarr
Jan 14, 2006 | GPX DV7500 System
Polaroid DRM-2001G DVD Recorder/HDD Recorder Logo
152 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
