Question about ASUS Computers & Internet
No signal to moitor, good graphics bd and cable
Monitor error mesage:check pc no signal. the pci graphics bd is good on another pc
  • 2 more comments
  • j_shenry May 26, 2009
    tried two monitors and get the same error mesage, thats the only video i get.
  • j_shenry May 27, 2009
    the motherboard is asus (no model on board) the mp is an amd k6-2 450 mh. the video card is ATi d33053 it will support crt and dvi.
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    The video card worked in another computer. On this computer you put the video card in and you can't get any monitor to work with it.
    Sounds to me like the video card your trying to use may be incompatible with your computer that your trying to use it on.
    What video card is it and what machine are you trying to use it in?
  • Ben Wabnick
    the comptuer that you have the monitor hooked up to. Do you get video with another monitor hooked up?
    Problem Solver:
  • 17 Answers
It sounds like you have a bad motherboard on the PC where you are getting no video.
Posted on May 27, 2009
How to fix a no signal monitor ?
If you have a known-good video card and a known-good VGA cable connected, another possibility is that the monitor is defective
Jan 15, 2013 | Dell Dimension C521 PC Desktop
Emachine ET1850 model when turn on no display picture.
Check ALL monitor cables, reseat connections. Have you done any hardware or software updates? Graphics Updates? Do you get anything at boot? Just no signal? It sound like a hardware issue, Graphics. Support for your machine can be found here: http://support.gateway.com/us/en/emac/product/default.aspx?modelId=2064 You could buy a PCI e x16 Graphic Card . Better ,faster Graphics. First, check VGA connections, reseat, check for bent pins. Try another cable and monitor, to verify.
Jan 02, 2013 | E-Machines eMachines Desktop PC
Dell front panel power light abcd lights yellow
Does the monitor go out completely, no power? Or just lose a signal? Check ALL cables, AC and Monitor cables. Could be a Graphics adapter issue or Monitor , try another monitor.Your computer has a few miles on it , right? You could buy a PCI Graphics card if the monitor is OK.
Jan 01, 2013 | Dell Dimension 2400 PC Desktop
How do I fix the error no vga input signal no dvi input signal monitor going to sleep
Check if you VGA is properly settled in the PCI slot. Try to take it out, clean the slot for dust.
If that doesn't help, it is well possible that you VGA is not working any more.
Jun 10, 2012 | HP Computers & Internet
No signal screen on moitor m3641
This message you get when your computer does not send a video signal on to the monitor..If ti seams to start and the fan is working ..check the cables to be proper inserted (the vga cable ..the one with protection screws on ) ..and if all is in place than it may be the video card to blame ..
If you have a pci or agp card installed ..other than the on board video card ..use that ..cause if you plugged it in the on board card ..it will have no signal as long as the pci card is inserted..If the agp/pci one is not working ..and you do have a on-board card ..remove the one in the slot ..and use the on board one until you will get a new card
let me know what you have managed to do ..
Dec 17, 2011 | Acer Aspire M3641 Dual Core E2200 PC...
Moitor not coming on message check video cable comes up i have renewed video cable no change
It could also be you graphics card, try your monitor on a different PC, if it works ok, your graphics card probably has a fault. If it doesn't you've a monitor fault.
They're fairly cheap second hand from ebay, but check the connection is the same as yours, there are several different types VGA, VGA2 etc.
Mar 12, 2011 | Compaq Computers & Internet
Brand new Monitor blank screen says No Signal
There is nothing wrong with the monitor. The LCD is not recieving any signals from the PC. Either you are connecting the VGA cable incorrectly or your VGA card is not set from the PC BIOS. The VGA cable might also be faulty.
Recheck that all the connections are clean and secure. If you are using a PCI-E or AGP card, the computer BIOS should be set to send the video signals through the PCI-E or AGP card. Follow the procedure in your motherboard manual.
If your pc has on-board graphics then you should connect the VGA cable to the on-board VGA out connector.
Oct 19, 2009 | Acer X203H bd Monitor
Lights and Fan are working, but no beep.
First open cpu cabinet.
Then refix RAM memory.
Pull cmos cell for 10 minutes so all settings of motherbord are defaults.
Then pull porcessor fan and processor clean dust from all chip and parts.
Remove pci cards from pci slot then check.
Let me know if you need more assistanse.
Thanks.
Sep 21, 2009 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
Error message on Syncmaster- check signal cable
sounds like it might be a graphics card. if u have an old graphics or vidio card, open the case and remove your card then install the old one. if it works now youll know your card is bad. If u have an old video card and an open pci slot install it and move the monitor cable to the old video card plugin. if it works now same thing your graphics card is bad. to know which card to remove just remember which one the monitor is plugged into.
Jul 29, 2009 | Samsung SyncMaster 940B Monitor
Computers & Internet Logo
204 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
