Question about Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator
Fridge door will not stay shut
When you push the door shut, it is approx 1/2 inch lower then Freezer door. So the magnet is not catching, to keep the door shut. Can't see a way to adjust the door hing to raise up the fridge door. Any suggestions.
  • dglenn542003 May 26, 2009
    There are not any screws under the cover, just two bolts.
  • dglenn542003 May 27, 2009
    ok, thanks for your help, i think we got it. I really appreciate it.
    President:
  • 331 Answers
Glenn,
Easy... The door alignment adjustment is done at the top hinge. Pull up a step-stool, then remove the hinge cover. Under there you'll see three screws, I think they're 5/16". Loosen these (since your door has dropped, they're probably already loose), then lift up on the door handle to align it with the other door... while keeping the door aligned, tighten the hinge screws (and put alot of torque on 'em to keep 'em from loosening in the future). Now just replace the hinge cover and your done!
SG
Posted on May 26, 2009
  • Tracy Farrell
    Tracy Farrell May 26, 2009
    A rose by any other name....
    Yeah, that's them. Loosen 'em up, align the door and tighten 'em up.
    SG
    New Friend:
If tightening the top screws doesn't bring the top of the door back up even with the other door, pop those 3 screws out, lift the door off and add a washer to the bottom hinge pin. Then just make sure the top is level and put those screws back in the top nice and tight again. Nylon washers are best if you have one.
Posted on Jul 03, 2013
Freezer door pops open when the Refrigerator door is being closed
My new freezer did the same thing. I contacted the company and they went into the whole leveling thing. What it has to do with is the magnetic seal. The magnets are not strong enough to keep the freezer door from popping open when closing the big fridge door. They share the same duct. I level my doors on the fridge and freezer so they swing shut by themselves after opening. Just the force of the big door when it swung closed cracked open the freezer door about a quarter of an inch and if left unnoticed created a puddle and made the fridge run overtime. I solved the problem by placing strong magnets inside the fold of the magnetic seal at the handle end of the door. This is the flap on the outside the door seal. I used six magnets on the top and six on the bottom. The magnets were from discarded Sonicare tooth brush heads. They are very flat and super strong. You can find something on ebay. My freezer door doesn't budge problem solved. I did call the company and told them I solved the problem and they still insisted it was the leveling. Good luck, Art Knapp
Jan 08, 2011 | Refrigerators
When we close the refrigerator door the freezer door pops open. It seems like a vacum problem?
Dec 24, 2010 | LG Refrigerators
Every time the refrigerator door is closed, the freezer door pops open. How can we better secure the seals?
Dec 13, 2010 | Kenmore 64802 Top Freezer Refrigerator
Whenever fridge door is shut hard/ quickly it causes the freezer door to pop open a little...and meltdown the frozen stuff. The fridge door has dropped a bit but I don't think that is it. It seems there...
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it's wore out and doesn't work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Nov 30, 2010 | Fisher and Paykel Active Smart E522B...
The fridge door will not stay shut. It is noticeably lower than the freezer-side door. We think there may have been too many condiments in the door pulling it down. Also, on the freezer door, there is a...
ON THE REFRIG DOOR LOWER HINGE, CHECK THE CONDITION OF THE CAM UPPER AND LOWER HALVES. ALSO YOU SHOULDN'T SEE ANY BLACK MAGNET ON A DOOR SEAL UNLESS IT'S BAD.
Oct 04, 2010 | Maytag MSD2756G Side by Side Refrigerator
Freezer door will not stay closed when closing refrigerator door
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
To replace it Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Sep 04, 2009 | Refrigerators
Freezer door won't stay shut
This indicates that you do not have good airflow and return airflow between your freezer and refrigerator sections. That is why the pressure from closing one door is causing the other one to pop open.
Check the drain tube on the back of the machine to make sure it is not clogged or blocked with frozen water inside. Also check any return air flow vents inside the unit for clear ice.
Jan 18, 2009 | Refrigerators
Door on Monogram ZIR36N won't pull closed and stay shut
The spring is actually a door closure , are the wheels that the bar closure mechanism goes through and attaches to the spring moving freely? It is entirely possible that a bin in the fridge is keeping the door open.
Nov 14, 2008 | GE ZICS360NMRH Monogram® 36" Built-In...
I have the exact same problem - very annoying. The only thing I found to work was to purchase one of those child safety locks. I bought the Kidco Appliance Fridge Lock S330 because it was the only one I could find that automatically relocks after you shut the door. Buy two (or more) at a time because the arm will eventually wear out and break (after several months depending on how often you use it). You can check out the product's details on eBay - that's where I purchased mine. Hope that helps.
Aug 27, 2008 | GE GTS22KBP Top Freezer Refrigerator
Could be the air pressure created from shutting the refer door is popping open the other one. There are are channels between the two so cool air from the freezer gets to the refer compartment. Try this as a test... s l o w l y close the refer door and see if that keeps the other door from popping open. If that works then it's likely an air channel is frozen up somewhere and you may need to turn the unit off for a day or so to let it thaw out. Moisture from leaking door seals, or doors that were left slightly open overnight can be sucked in and freeze up the air channels. I don't know if you are sort of slamming the door shut or not but the doors need to be shut slowly due to how air tight the new refers are.
Nov 10, 2006 | Frigidaire FRU17G4JW Refrigerator
Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator Logo
1,262 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
