Question about Kenmore Dryers
Heat kick on then off
Dryer heat for a short time, heat kick on for 10-12 minutes then kick off, I hear a click noise, sound like on and off switch
  • 89 Answers
These are heat cycles,
the click you are hearing is the thermostat turning the element on or off, most dryers try to acheive a temp of 160 - 180 degrees, when reached the element shuts off for a bit to cool down and not scorch your clothes
you do not have to worry about this
Posted on May 27, 2009
Why is my gas dryer making a fluttering noise
you better be careful if you are smelling gas then you have a gas leak somewhere.
May 31, 2014 | GE Adora Dryer. Gas Dryer. 7 cu. ft. in...
It's run but there's no heat
The gas dryer has a spark ignitor that starts the burner to heat up. Upon switching on the dryer you should hear the ignitor clicking to light the burner. If you do not hear the clicking noise the ignitor needs to ne replaced
Mar 27, 2010 | Whirlpool LGR5636L Gas Dryer
My Kenmore Dryer stops before the time I set is up.
Sounds like the operating thermastat may be bad letting it get too hot and causing the motor breaker to kick out . When it cools it will start again. Check all thermastats.
Mar 12, 2010 | Kenmore Dryers
Dryer makes a clicking/scraping noise when operating in the heated settings. The noise does not occur when using air only setting. I disconected the gas and ran the dryer and the noise remained. It is only...
since it not happening in the non heated cycls and with out being able to realy diagnose
the clicking is your gas turning on and off
the scapring could be a couple things,,, the tub getting hot and expandin g just a bit,, or your hearing the scream of the flame
many time speopl have complaind that the heat sounds like something is scraping
Oct 26, 2009 | Dryers
Dryer burner does not kick on every time that I use the dryer. If I hear the heat kick on, the clothes will dry, but if the heat does not come on, the clothes will tumble on just a cold air dry and the...
Replace both coils on the burner valve . After heating up , they will not open to let gas thru again until cooled down for a short period of time . With no heat , timer will not cut off unless set for timed dry .
Aug 09, 2009 | Maytag Dryers
Kenmore Dryer won't turn on
Hi...
This are the tipe on how to Troubleshot dryer follow the steps below
IF the dryer is noisy
Level the dryer
Check the drum belt
Check the drum support rollers
Check the idler pulley
Check the glides
Check drum bearings
Check the blower
Check the baffles
If the dryer tumbles, but there is no heat
Check for proper air flow
Test the safety fuse
Test the thermostats
Test the centrifugal switch
Test the timer motor
Test the heating element
Good luck !!!!
Regards
PCmania
Jul 03, 2009 | Kenmore 63942 Dryer
Check the thermostats. They work when cold but will not reset once warmed up.
Eric
May 27, 2009 | Kenmore Dryers
After a few heating cycles the burner does not ignite
The problem you are describing is usually associated with a bad gas valve coil. The dryer runs normally until it gets hot, then starts making a strange clicking noise. After it cools down, the dryer runs normally again. The gas valve coils (there are two of them) usually run about $20 a piece. I recommend replacing both of them at the same time just to be sure. I hope this helps.
Apr 15, 2007 | Maytag MDG3600BW Gas Dryer
Dryers Logo
103 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
