Apple iPod classic 120GB - Black MP3 Player
Problem for Apple iPod classic 120GB - Black MP3 Player
IPod won't show up in iTunes
By ramar567 on May 26, 2009
Hi, My iPod just stopped showing up in iTunes about a month ago and I need help fixing it immediately, because not only am I running my own iPod but I am also in charge of a daycare's iPod and I really don't want to break that....HELP My ipod doesnt show up when I plug it in to the computer
Best Solution
posted on Jun 02, 2009
Helpful)
mneilsen2084
Rank: Guru  Apple Expert
Rating: 91%, 168 votes
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Putting ipod into disc mode http://support.apple.com/kb/HT1363 Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
How to restore iPod (ARTICLE NUMBER HT1339)
Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
After a few moments, your iPod will appear in the Source panel in iTunes.
Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software.
The 4 possible restore options are: Restore Option
1: Restore - Restores with same iPod Software version already on iPod. Restore Option
2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option
3: Use Newest Version - Restores with the latest iPod Software available. Restore Option
4: Restore and Update - Restores with the latest iPod Software available.
If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Comments:
Jun 24, 2009
- Attempt to force the iPod into disc mode then connect it to your computer. If it shows up at this point, you will need to restore the iPod using the latest version of iTunes. Below is a step by step on this recommended solution just in case you are in need of the information. :)
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Nov 25, 2009
Not Rated)
Rushaugust
Rank: Guru
Rating: 90%, 19 votes
okey ! i guess there are two reasons for this possibly:
1.the itunes u're using now is not compatible with ur ipod, u may need download a suitable edition for ur ipod from apple official website;
2.there may be some vices about connector plugs of ur ipod,replace it and have a try again.
If still not work, Free download Daniusoft iPod transfer, you can easily transfer songs/videos from iPod to computer or import media files to iPod without iTunes with this iPod Music Transfer.
Was this helpful?
Yes
No
Solution #3
posted on Jul 07, 2009
Not Rated)
fixtesting5
Rank: Guru
Rating: 87%, 29 votes
test test test 17:48
please do not answer
Was this helpful?
Yes
No
Popular Solutions for Apple iPod classic 120GB -
Questions and Unsolved Problems for Apple iPod classic 120GB -
Do you recommend Apple iPod classic 120GB - Black MP3 Player?
Answer
Answer
when i connect my iPod Classic to my laptop there is no appearance for any program, itune or... (More)
Answer
i cant hear my music but i can here when i turn up the volume??
Answer
i fornget my password on my ipod can your find it for me please
Answer
my ipod got a little wet because it was raining and now it wont work
Answer
red cross on ipod 120gb even after updating itunes softwareitunes does not pick ipod
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top MP3 and... Experts
Top Audio & Video Equipment Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
