Question about Microsoft Xbox 360 Console
Xbox 360 Wont Stay Fully Powered On
My Xbox 360 won't fully power on... OK!, so I had the 3rrod and I was finishing up and I was on the last part of the fix which was to overheat it(or bake as they call it). But to my suprise my console turned on with its usual 3rrod and the fan was running higher than usual(well im pretty sure because it was giving off ALOT of air) then it went super power for like 2 seconds and cut off and 2rrod occured(overheat) which I wanted but the fan shouldve stayed on stuff. It stayed basically not running except for the rings so i couldnt even over heat it. It's acting like their is like a safety feature or that it knows somthing is wrong. Do you know how to fix this???
  • xxxdrum3rxxx May 27, 2009
    Well It thinks its overheating within seconds? Btw I dont Think They Would repair because i broke seal!
  • 3 Answers
The real problem could just be a failed sensor in the Xbox telling your fan it needs to work its hardest to cool things down. My computer for example is a defective model that shuts down randomly because the sensor tells it it is overheating when is actually doing just fine.
Best solution? If you have one of the earlier generations, give Microsoft a call and tell them what's going on. They'll have you go through the repair request process but simply talk to them and they should cover it for free.
If the warranty is no longer "valid" tell them that you would have gladly had it repaired during that time but you can't fix what's not broken. Now that it IS broken, you would like them to send you a refurbished one free of charge. They will usually get on your side because they know the cooling fan and its system is somewhat of a faulty design.
The other option is don't try and bargain with them and cough up the $100 for them to "repair" it for you (which to me is absurd).
Posted on May 27, 2009
Why wont my xbox 360 stay powered up
There is a lot of reasons this may happen.
Overheating
Insufficient power supply (Are you running an intercooler?)
Bad update (Corrupted OS)
Jul 14, 2014 | Microsoft Xbox 360 Console
Why wont my xbox 360 stay powered on the indicator light on the power supply brick is green but when i touch the power sensor it lights up green and then goes immedatly back to red
Check your connections. Make sure your A/V connections are secure. The 360 has a feature that if it doesn't detect the connection, it powers down.
When i go into halo 3 it says please connect xbox 360 controller and it wont work i have tried resetting everything
Do you have a battery powered controller? Try replacing the batteries.
Corded one? Make sure it is fully plugged in and the cord is not frayed in any places.
Nov 27, 2010 | Microsoft Halo 3 for Xbox 360
X box wont turn on
are all plugs connected from power outlet to Consel?
Nov 11, 2009 | Microsoft Xbox 360 Console
My xbox 360 wont turn on al all(not rrod)
Have you fully unplugged it and as in the mains from the adaptor, adaptor from the 360 etc? then re-plugged it?
If this does not help then i think you may need to visit http://www.xbox.com/en-GB/support
Oct 29, 2009 | Microsoft Xbox 360 Console
It just shut off and wont load.
This is a common fault with the 360, it says that its a "general hardware failure" which could mean anything
really. In truth its the lead free solder that cracks with so much heat and as a result the Xbox 360 fails
causing the 3rrod (3 red rings of death) or e74 etc
You will need to get a 3rrod repair kit or get someone to fix it for you, there are guides available on the
internet.
Sep 27, 2009 | Microsoft Xbox 360 Console
My red death three ring light is not working on my xbox 360
3rrod is a common fault with the 360, it says that its a "general hardware failure" which could mean anything
causing the 3rrod (3 red rings of death).
internet. Im in the middle of producing one right now that i will make available free of charge for all fixya
members.
www.xboxrepairkit.co.uk
Sep 26, 2009 | Microsoft Xbox 360 Console
The power light blinks, reads open tray/close tray . . .
it sounds like your dvd drive is dead if its still under warranty you should just send it back to microsoft the only other thing you could do is buy a replacement dvd drive and put it in yourself but only do that if microsoft wont take it or you'll void your warranty
Aug 25, 2009 | Microsoft Xbox 360 Console
XBOX 360 SOMETING DOES NOT SWITCH OFF AND PRESS THE POWER SWITCH
if your xbox 360 is one of the older ones or the first released xboxes then it could be the start of the 3rrod problem this type of error can occur when the motherboard starts warping and the solder joints are broken which can cause similar problems such as this. i would also try getting the very latest game you can and doing an update to see if this helps. you may also be able to download the update from www.xbox.com. burn the update to a dvd and then place the dvd inside your 360 and when asked if you want to update select yes and see if this helps.
Dec 11, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
158 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
