Question about Samsung SC-X205L Mini DV Digital Camcorder
No suggestions but we are also having the same problem with the samsung sc-x205l. Samsung states they do not have any post waranty service available. SOL. At least Sony and Canon have their own service depots or partner with someone. Last samsung product for me.
Posted on Dec 17, 2007
Canon G5 Powershot LCD screen is black and will not show images in any setting.
Are you sure the battery is ok? Did you press the button display (bottom right nest to the display) several times? Next, how long did you not use this camera? If it was for long, something inside could be corroded. Did you recently drop the camera? Something more serious could be wrong. I'm not sure you can make any picture, because you don't need the screen to make a picture. You then could look is a proper picture is on the memory card. If the rest of the camera is working ok the viewing must work also. Check is the off button is moving correct. (And not blocked) Resetting could be an option, but you need the display to answer the question. This is in the user manual.
Oct 23, 2013 | Canon PowerShot G5 Digital Camera
What is wrong with my camera?
The display being black can be due to failure of the LCD or the CCD which is the optical sensor of the camera. So to confirm check the older picture to be seen on the display. Confirm this by checking the card on your PC. If the images/picture is seen to be of good quality, then the LCD can be faulty, fault on the linking cable or the control board.
However if the older images are seen well then the LCD is working correctly and the fault can be failure of the CCD- charge coupled device in the camera. If you have accidently exposed the camera directly to high intensity light / sunlight, then it is possible that it is damaged. Remove the battery and keep the camera aside to reset and try as a last resort. Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Nov 21, 2011 | FUJIFILM FinePix AV100 Digital Camera
Nikon Coolpix L110 Digital Camera (Black) Blurry images
that means there is something wrong with your camera lcd screen. when we are taking photo in the outer door,we should pay attention to the cleaness of the screen. sometimes the lcd screen display not clear due to impurity,or some black shot. if you want the clear picture,you can change for another lcd screen.
Oct 01, 2011 | Nikon Coolpix L110 Digital Camera
Nikon L110, LCD does not display anything some cracks are showing on Lcd, though glass is O.K
when the lcd screen does not display well, it maybe something wrong with the screen such as the screen leakage,black spot,or edge chipping.there is 2links for you,wish it can do a little favor to you if you want a clear and clean lcd screen.
Aug 17, 2011 | Nikon Coolpix L110 Digital Camera
Everything works on my camera, but the screen is black all the time...Like the lcd has gone out or something...
Most likely you have a problem with the LCD display. The displays are very susceptible to breaking if the camera has been dropped. The backlight could be defective too. I have replaced many of these displays in cameras. try to get an estimate to have the display replaced. You'll probably find that the estimate will be fairly high. The displays are not too hard to replace. You might try contacting the parts department at Canon and see if you can purchase the LCD display and repair the unit yourself. I wrote and posted an article on this site on how to replace the displays in Kodak cameras. The prodedure will be fairly similar on most any type of digital camera.
- Jim
Jul 03, 2008 | Canon Cameras
Blank screen
Usually it's an lcd burn out where the screen needs replacement. Check the display button if it's just blank then press it to see if it comes on. As far as your friends white screen it not feasible to repair. A good thing to get on any digital equipment is an extended warranty. It does save you in the end when something goes wrong. The limited manufacture warranties are a joke. You should never rely on them.
May 28, 2008 | Sony Cyber-shot DSC-T9 Digital Camera
Images with lines. Canon says NOT bad CCD
This really does sound like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status.
Which Canon facility did you send it to before (California or Illinois)? Also check the following two links for more info on how specifically to submit your camera for this issue. Think it's worth another try:
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Feb 17, 2008 | Canon PowerShot A300 Digital Camera
Camera repair
Time for a new Camera. It is about 150.00 to replace the LCD. it is cheaper to replace it unless you can just use the viewfinder alone!!
Nov 13, 2007 | Kodak EasyShare Z612 Digital Camera
My camera's LCD screen goes black every so often. What is wrong?
No. All Lumix® Digital Cameras have a built-in feature to conserve battery power. After a certain amount of inactivity, the LCD will power down to preserve the battery. Simply hit the SHTR button, and the LCD will turn ON.
Aug 30, 2005 | Panasonic Lumix DMC-FX2 Digital Camera
Samsung SC-X205L Mini DV Digital Camcorder Logo
50 people viewed this question
Top Samsung Video Cameras Experts
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
