Commercial speed queen won't agitate
Waher fills with water but does not agitate
  • HARYE STAVROPOULOS May 27, 2009
    me and my husband took it apart lastnight and the tub does speen but when it comes time to agitate it hums and i do smell something electrical. also the agitator on the other washer has a little play when you move it with your hand but the problem one is stiff and will not move, if this is a transmission problem would it be better to just buy a new washer?I have 2 commercial whirlpools for about 5 years and no problems, these speed queens are about the same age and we are constantly fixing them (dryers also).
  • 351 Answers
Sounds like it is in the gearbox, possible broken gear
Posted on May 27, 2009
  • Harry Goodwin
    Harry Goodwin May 28, 2009
    Yes I would advise you to buy a new washer and a different brand as well, it is very expensive to have the gearbox repaired as you basically have to strip the whole machine down to get to the gearbox and the hourly charges these days are just a rip off.
    If you go to the auctions when they are auctioning white goods you will most probably get a new machine with a couple of dints or scratches on it for around half the price.
    hope this has helped you decide.
    all the best with your new machine.
Kleensmaid heavy duty washer by speed queen, washes but shuts down on what seems to be overspeed on the spin cycle
Amazon.com: Customer Reviews: Speed Queen 3.3 Cu. Ft ...
www.amazon.com/Speed-Queen...Washer/.../B004ZO...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Speed Queen 3.3 Cu. ... If you need more water in the tub you can hold down the reset switch until the machine ... I tried the delicate wash and spin cycle, but the clothes retain too much water and ..... It takes time to correlate the number of turns and the direction to turn it.Missing: overspeed
Commercial Washer and Dryer Problems
www.affordablelaundry.com/commercial-washer-and-dryer-problems
The water should shut off once it reaches wash level, if it doesn't, and water level hasn't... (these are the glass type fuses) be sure to turn power off before checking them. ... If you have the voltage in, but not out, it's the contactor. .... We repair: Speed Queenwasher, IPSO washer, Milnor washer, UniMac washing machines.Missing: overspeed
[PDF]View document in PDF
Dec 19, 2015 | Speed Queen Washing Machines
Speed queen washing machine fills water but does not agitate but all other cycles spin and rinse working perfect. i took out the belt and started the cycle and the motor was moving fine.
the motor spins with out the belt , makes me tend to discount the capacitor
I would be looking for a tub brake that is not being opened to allow the tub to agitate
there are solenoid activated brake under the machine the applies a brake when you lift the lid during wash, when the program is finished
have a technician check it out
Nov 10, 2015 | Speed Queen AWS44NW Top Load Washer
Fix agitator on a speed queen awm290
Is the drive belt in good condition?
Does the machine spin dry?
Is there water leaking from the bottom?
I suggest the gearbox needs to be replaced. Another sign is if the machine is noisy when it is washing (agitating)
Jul 04, 2014 | Speed Queen AWS45NW Top Load Washer
How do I remove the agitator on my Speed Queen AA4211WE? There's no cap! It all appears to be one piece.
I just did that. Just pull up really hard. Now.. how to get that other thing off to pull the tub, I can't figure out, all bolts are removed.
Jul 27, 2010 | Speed Queen AWS45NW Top Load Washer
Hello. I have a commercial Speed Queen top load washer and while filling with water, it does not stop without opening the lid. I have replaced the pressure valve and checked the hoses and still no fix. Any...
try checking the where the water hoses connect that water valve is where the water is shut off, turn off the water facuet undue the hoses and look inside the valve does it have calcium buildup? or sand in it? if it does you will have to pull the water valve to clean it in order to get it to work correctly. Let me know if you need more help and thanks for using fix-ya.
Jul 01, 2010 | Speed Queen AWS44NW Top Load Washer
Will not start washing process
Is the belt broke?
If not, will it spin it you put it in spin mode?
If it spins, but not agitates, the transmission is locked up in agitation and needs replaced. This is a major undertaking.
Dec 12, 2009 | Speed Queen AWS51NW Top Load Washer
#awm693w,removing agitator to replace seals
Unscew the cap on the top of the agitator, then hit it back and forth with your hand and it will break loose. I just did it to mine today and it has not been of for twenty years.
Feb 02, 2009 | Speed Queen AWS75NW Top Load Washer
Washing Machines Logo
238 people viewed this question
Top Washing Machines Experts
