Question about Whirlpool Washing Machines
Water doesnt completely drain or spin during last cycle
Whirlpool gold ultmate care 2 washing machine suddenly stopped spinning and draining during the last of the cycle.
  • angie_dickma Jun 02, 2009
    Lid strike is ok. Put a screwdriver in the switch and ran it through a wash cycle with the lid up and it seemed to work ok. Ran a few more loads and had the same problem with the high speed spin not working????? Smelled like something was hot????? Please advise.
  • 5,911 Answers
A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. This is the most common cause of this symptom on Whirlpool manufactured washers. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price. If you still need assistance, please contact me and let me know. If my diagnosis is not correct, please post back and elaborate a bit more so I can assist you further. If your washer is not configured this way, or if you still have questions, please let me know.
Posted on May 27, 2009
Washer does not spin cycle, why?
In top load washers, if the machine goes through the cycles and then just stops at the spin cycle and leaves you with no noise and a tub full of water more than likely the lid switch is bad and not completing the circuit for cycle to continue. This is a safety precaution to prevent injury by reaching in the machine while at high speed spin. If the machine is getting to the spin cycle and still turning slowly but not draining the water, the pump is probably the culprit, either being locked up or in most cases something like a sock, etc. is stuck in it preventing it from turning. This is usually indicated by a humming sound during the spin/drain section with no water draining.
Apr 30, 2012 | Whirlpool Washing Machines
Stops during rinse cycle and won't pump the water out
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 10, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
My whirlpool machine does not spin properly and there is always water left after the spin cycle, when its turned on it will stop after spin cycle like its finished but there is still a lot of water left in...
hi, it sounds like one of two possibilties, will try and help out. The first thing to check is whether the water/drain pump is actually working fine, i think it blocked. Secondly the pump may also be overheating and malfunctioning during the cyle, run it without clothes and check the flow of the drain during the drain/spin cycle and take it from there.
Jun 14, 2011 | Whirlpool Washing Machines
Washer is not completing the spin/drain cycle. Stops spinning and draining.
does it drain out all the water? after it stops or is there still water sitting in the tub?
Mar 22, 2011 | Kenmore Elite 45986 Front Load Washer
Whirlpool washer wont spin during spin cycle everything else appears ok.
Machine not spinning....check]
1..all water gone clean pump trap and check blocked drain
2....somehting stopping drum spin drum freely by hand.
3....too much soap use low suds soap and very little of it.
4....motor brushes wearing out...call for service for this one.
Good luck
T
Aug 07, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
Our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
Jan 21, 2009 | Hoover UltraCare HC6 130M Front Load...
Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Jul 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultmate Care II won't drain
You will have to remove pumps hoses and make sure they are not clogged.
May 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
159 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
