Question about Nextar I4-BC GPS Receiver
My nextar Pd wont read the sd card
When i click the navigation button it says '' cannot find map data files. please make sure the storage card is properly inserted'' and it is properly inserted I have a nextar P3 with a similar problem. I am going to try the battery drain and recharge advice. sam from michigan
  • 78 Answers
SOURCE: map update
You can download Tele Atlas updates at their map store here- http://navigation.teleatlas.com/en/shop/. Since the Nextar is relatively new, there is not a link for that brand on Tele Atlas's site, but for best results try their US customer service. Numbers were a bit hard to find but here are their US numbers- http://www.teleatlas.com/WhyTeleAtlas/ContactUs/TheAmericas/index.htm They should be able to tell you which update will be compatible for you, and its as simple as sending your new maps to your SD card once you download
Posted on Nov 25, 2008
  • 3 Answers
SOURCE: my nextar x3-08 wont read the sd card
I called Nextar and you have to let its battery drain completely and then plug it in to charge for 5 hours. I guess it a glitch in the system :(
Posted on Mar 27, 2009
RixsFixes
  • 2200 Answers
SOURCE: gps lost sound, the voice is gone. nextar #p3 auto navigation sys
You should first try the reset procedure to see if this resolves the sound problem for you. To do this press the "Reset" button or push the stylus into the "Reset" hole.
For technical support for your Nextar GPS see http://www.nextar.com/frontend/support.asp or you can phone them on 888-849-0846
Please remember to rate my answer. Many thanks.
Posted on Jul 07, 2009
  • 16 Answers
SOURCE: Are there any map updates for the nextar
Check the Nextar website. They did recenlty release a 2009 map update, but if your GPS is not listed as compatible, it's not going to work.
Posted on Oct 09, 2009
SOURCE: Nextar m3-04 can't find map updates.
http://www.nextar.com/frontend/proddetail.asp?pn=PART-GPS-MAP09SDC2&co=10000312,10000390,10000345,10000373,10000375,10000331,10000349,10000350,10000352
Try that out. Unfortunately, they also charge for their map updates.
Posted on Mar 22, 2010
Can you tell me where to buy a SD card for A 2008 M3 Nextar GPS. An updated USA map.
Amazon.com: Nextar M3 3.5-Inch Portable GPS Navigator ...
www.amazon.com > ... > Vehicle GPS
Amazon.com, Inc.
Rating: 3 - ‎19 reviews
Amazon.com Product Description The Nextar M3 is a great way to add GPS to your arsenal. ... The M3 includes a 2 GB SD card pre-loaded with maps of the 50 U.S. states with over 1.6 million points of ... Date First Available, July 1, 2008 ...
i have a nextar co 2008 m3-03 but how do you up ... - Askville
askville.amazon.com > Consumer Electronics > Car Electronics & GPS
Nov 17, 2011 - Similar Questions: NEXTAR 2008 M3 03 DATE MAPS ... There may be some leftover Nextar map update SD cards floating around in the retail chain. ... http://www.ehow.com/how_5901587_update-maps-nextar-gps.html ...
Nextar GPS ' eBay
www.ebay.com/bhp/nextar-gps
eBayNextar M3 Automotive SATELLITE NAVIGATION SYSTEM GPS. $18.99 ... This is for receiver- 2GB SD Card with maps on it, a fabric case and a stylus.
Nov 03, 2015 | Nextar GPS
How do I update my Nextar x3-08 gps so the new roads will show up ?
visit Nextar.com to order your desired maps update and Check the overview description to see which SD card lists your GPS model number and serial number. Order the matching card.
Remove the existing SD card. This is usually found in a thin, rectangular slot on the side of the Nextar GPS.
Insert the SD card with the maps update into the empty SD card slot. Press until it clicks into place.
Reset the unit by pressing the "Reset" or pushing a pin into the "Reset" hole.
Click the "Navigation" button to have the maps automatically update on the GPS.
May 06, 2015 | Nextar X3-08 Car GPS Receiver
Doesnt go to navigation screen nextar x3-03
If it says it can't find map data then your SD card is corrupted.
It's a fatal flaw in the WindowCE 5.0 operating system that was used for Nextar GPS builds. Basically, if you have a power glitch while it's reading your SD card (contains the maps) then your SD card get's corrupted.
Don't expect any help from Nextar. You will have to get the original data from another person's SD card with the exact same model
Sep 13, 2009 | Nextar X3 GPS Receiver
GPS CAN NOT FIND MAP DATA FILES
I had a similar problem with a nextar X4-T, which has it's maps on an SD card. If your GPS uses an SD card for it's maps, you can try this:
You will need a computer with an SD slot, and running Windows Xp. I tried the following method on a computer running Windows Vista, and it did not work. I tried again on an older Xp machine, and it worked first time.
  1. Put the SD (Map) card in the computer's SD slot.
  2. Open Windows "explore". (RIGHT click on "Start", then select "explore"
  3. Locate your disk on the file menu.
  4. RIGHT click on the map disk
  5. A menu pops up.
  6. At the bottom of the menu, select "properties"
  7. Another menu pops up, with several tabs along the top.
  8. Select the tab that says "tools".
  9. In the "error-checking" section, select "Check Now"
  10. Another menu pops up.
  11. Select the box that says 'Automatically fix file system errors".
  12. Click "Start"
The program will only take a few seconds to run. If it works, you will see the file directories of the SD card display on the "Explore' screen. You can then put the SD card back in the GPS, and see if it works.
Good luck.
Apr 17, 2009 | Nextar X3-03 Car GPS Receiver
My nextar x3-08 wont read the sd card
Jan 05, 2009 | Nextar I4-BC GPS Receiver
My nextar W3G-01 won't load the map screen any more. One time as I was trying to make it work by flicking back and forth a message stating invalid or missing data file linkinfo.bin came up, but nothing...
I HAVE A SIMILAR PROBLEM WITH MY W3G-01. THE ERROR MESSAGE READS; CANNOT FIND MAP DATAFILES. PLEASE MAKE SURE THE STORAGE CARD IS PROPERLY INSERTED. I HAVE REMOVED CARD AND REINSURTED IT AND THE MESSAGE REAPPEARS.
Jul 19, 2008 | GPS
Nextar I4-BC GPS Receiver Logo
53 people viewed this question
Top Nextar GPS Experts
Are you a Nextar GPS Expert? Answer questions, earn points and help others
