Question about Philips DVDR3320 DVD Recorder/VCR
Dvd drive dose not recognise any dvds i put in it keeps saying unknown disc
The dvd recorder in my philips dvd3320v/05 dose not recognise any dvds that i put in not even bought ones.billy
    Habit-Forming:
  • 108 Answers
If your unit is older the optical pick up lens may be dirty or has gone bad. Most Philips units are exchange items only, meaning they replace it under warranty instead of fixing it, if its out of warranty there usually are no parts or service information on them. Philips was bought be Funai and is not the company it used to be. Check if the unit will play a audio CD, if it does the pickup assembly is bad, some will play a CD but not a DVD. You may be able to clean the p/u lens with alcohol and a Q-tip. The lens is under the clamp that holds the disc while spinning.
Posted on May 26, 2009
When i put a dvd in my hitachi htdk185uk it says unknown disc what does this mean
Either a DVD with the wrong region code has been loaded, and your player doesn't recognise it, or you have inserted a disc which is either rewritable (or an incompatible format for your player), a blank DVD or CD, or the disc has not been finalised in a DVD recorder. It depends on the disc(s) you have, whether they are region coded or those using a compatible playback format (finalised DVD-Rs are the best as far as burned copies go).
Examples of incompatible formats for your player may include;
DVD-ROMs
DVD-RAMs (which are the wrong version/speed for your unit)
Mini-DVDs/CDs
CD-RWs
DVDs with a different region code to your player or rewritable discs
* When using shop-bought DVDs, including those purchased online, make sure their region code matches your player.
May 25, 2011 | Hitachi DV-P315U DVD Player
I have dubbed vcr tape to a Sony DVD-RW disc and tried playing it back through a toshiba player and it keeps coming up Bad Disk. My PC won't even recognise it. When started dubbing the screen displayed 1hr...
Did you say you used a DVD-RW disc to transfer a videotape onto? The reason your PC won't recognise that disc is because the data format on it is a different language to what PCs understand - plus an unfinalised DVD-RW won't play in other DVD players - it is usually an incompatible format.
(DVD+RW discs with titles/top menus created in video mode CAN be played on a PC DVD drive or a normal DVD player as can finalised DVD-R discs (DVD-R discs MUST be recorded and finalised in the same recorder for compatible playback). DVD-RW discs can only be viewed on the unit they were written/recorded on.
The other reason for the 'remaining space' on the disc you describe showing less than 120 minutes is due to a title recently being recorded or erased - unless you format it - the 120 minute / 4.7GB DVD-RW will not show full available space. Erasing titles on re-writable DVDs does not increase space. The same rule applies to unfinalised +R / -R discs (you cannot re-format these to get the space back once recorded - they are 'once only' writables)
I recommend you invest in some DVD-R discs and re-copy your VHS tape to that - then if you are satisfied with the result, title etc., finalise the DVD-R - it will play on any DVD player or PC with DVD support (or it should). These discs are relatively inexpensive to buy just about anywhere.
Final note: do NOT finalise the DVD-RW you recorded (I hope you haven't already done this) - simply format/erase it - re-use it for something else or keep it until you need it.
You can use any brand of DVD, just take note of the format before recording/playing.
Mar 21, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I have a Philips Home Theatre System, model HTS7200 which showed 'unknown disc' when I put discs inside.
hi I have a Philips dvd touch screen HTS7200 the lights on top for volume and play are not working ,the try is not opening ,there s no sound coming out thanks
Dec 17, 2010 | Philips DVDR3380/05 DVD Recorder
I have a dvdr3380 lately when i put in disc it says disc unrecord
Test the created DVD with TMPGEnc v4.0 Xpress here is the free trial link It has a read source function that will fail if the DVDR has not been authored correctly.
If this works and scans in the full DVDR then I suggested that you buy a branded DVD+R like Philips who created the format, if this still fails I think you DVDR 3380 will need a service.
LOL
Mar 15, 2009 | Philips DVDR3380/05 DVD Recorder
Recorded discs wont play on an other dvd player
you have to finalise the disc when finished recording then it plays on any dvd player
Feb 15, 2009 | Philips DVDR3380/05 DVD Recorder
Does not recognise discs
If this disc that you are trying to use is a DVD+/-RW and it has been used a few times for DVD-Video or DivX then you can try to do a FULL ERASE using the excellent ImageBurn by lightining now at v2.5.0.0 it takes about 20 mins to erase a full single sided DVD
Hope this helps.
Jan 03, 2009 | Philips DVDR3380/05 DVD Recorder
When trying to play DVDs the words unknown disc title appears. Even after several attempts with various DVDs we havent had any success.
have u tried cleaning the hea of ur dvd player?after using a dvd player or cd player for long times of continous play say 6 months or if u play too many scratched discs and u dont clean the head of the player it starts skipping the disc or many a times dosnt recognise the disc so it'll give u errors like "Unknown Disc", "Disk Error" etc so i would really recommend u to clean its head using a dvd head cleaner cd.. its easily available in the video stores or malls.. u can purchase any dvd head cleaner cuz there are number of manufatcures for this. im sure this would solve ur issue.
PLEASE DO RATE ME,WOULD REALLY APPRECIATE IT
THANX
Oct 06, 2008 | Philips Televison & Video
UNKNOWn disc type
Me too - I've had a DVR3305/05 for just over a year and yesterday after using a lens cleaning disc it refuses to play anything !!! My advise is to stay away from Philips !!!
Nov 13, 2007 | Philips DVDR3380/05 DVD Recorder
Unknown disc error message
OKAY GUYS TRY USING THIS VERY COMPATIBLE MEDIA
(MEMOREX BRAND DVD-R) THIS WILL SOLVE A LOT OF YOUR PROBLEMS
Aug 27, 2007 | Televison & Video
Philips DVDR3320 DVD Recorder/VCR Logo
317 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
