These shortcuts keys can be used when typing text in Blackberry:
If you want to type the alternate character on a key, hold the Alt key and press the character key.
For an accented or special character, hold the letter key and roll the trackball left or right. Click a selected character.
To type a symbol, press the Symbol key. To view more symbols, press the Symbol key again. Type the letter that appears below the symbol to insert the corresponding symbol.
To insert a period (.), press the Space key twice. The next letter is capitalized.
To capitalize a letter, hold the letter key until the capitalized letter appears.
To turn NUM lock on, hold the Shift key and press the Alt key.
To turn NUM lock off, press the Alt key.
To insert an at sign (@) or a period (.) in an email address field, press the Space key.
To type a number in a number field, press a number key. You do not need to press the Alt key.
In order to type a number in a password field, hold the Alt key and press the number key.
To type a letter in a number field, hold the Alt key and use the multi-tap input method to insert the letter.
If you are typing input languages, hold the Alt key and press the Enter key. Select a language, then release the Alt key.
Rosemary, Symbols are not specific to keyboards but font sets
I cant paste one in here but on a windows computer open a utility called Charmap (enter 'charmap' in the search box)
Once opened change the font name at the top to Wingdings, 2nd row down 3rd icon in is a keyboard, click it, click select at the bottom and then copy. You can then paste this in to a document and change its size as if it was a normal letter.
open the rem.control and clean the keypads for bad contacts, oxide, corrosion, and dirty. and try again. if the problem persist, go to the repair shop TV for fix it. God bless you
I can help you with your Sharp EL-531VH Scientific Calculator problem.
To access the symbols above the keys, press the '2nd' button first, then the button with the symbol you want. On my calculator the secondary functions are in orange, not green, but I suspect it is the same deal just a different color.
I have a digital copy of the manual for this unit - I will update this solution with a link after I have posted it to fixya.
Press the [MODE] key to access the mode comfiguration screen . Set angle unit to to radian (see above) Enter angle value in Decimal degrees only, use the [2nd][ANGLE] key sequence to have access to the degree symbol. The degree symbol must imperatively appear at the end of the angle value.
Here are some examples If you use angle values in DMS, it will not be converted to radians, but to decimal degrees. If you omit the degree symbol there is no conversion.
Use the Shift key or the Alpha key to type letters. If there are two symbols near a key,on the body of the calculator, the symbol to the left is accessed with SHIFT, the one to the right with ALPHA. On certain calculators symbols are color-coded.
Solution#1: Accidentally pressing Sft+Numlock key combination will activate & inactivates ten key pad. (You'll see light enabled in padlock symbol with a number in it [i.e.beside ALL CAPS symbol on your lap monitor]).
Use: "ShiftKey+NumLock" (NumbLock Key: 2nd panel from Top right on keyboard)
