Question about Beyond Micro (BM120MD3U2) 120 GB USB 2.0 Hard Drive
Wont boot or make noise but lights are on
I have a boyond micro mobile disk i believe 120g but for this problem that most likely won matter ... for some reason it wont boot ..when turned on the green and red led lights on the front come on but i can hear that the drive will not start spinning inside the drive itself just sits there in silence all the wile not connecting to my computer ... some very important info is on the drive so plz any help or any advise on where t go for more help will be very helpful ..thank you
  • 181 Answers
Remove it from the case and put it straight into your computer using a spare power plug and cable. to see if you are doing it right check one of the other hard drives in the tower switch on and see if there is any diffrents if not then i am sorry to tell you it is caput
Posted on May 29, 2009
I have tikking noise from both spekers,
hi how can i get amanual for a micro component system UX-P5R
Nov 22, 2013 | Philips WACS700 Shelf System
120G hard disk doesn't work on p4m266a mother board
The hard disk maybe faulty especially if the BIOS cannot detect the hard disk.
Try connecting the hard disk into an USB hard drive adapter and then plug it into the USB port of a working computer. If this computer cannot detect the USB hard drive adapter as an external storage device then this hard drive is faulty.
Oct 29, 2012 | Computers & Internet
Acer aspire 5355 won't boot up
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Sep 03, 2012 | Computers & Internet
Tecra r840 wont start (Won't even go to boot menu)
Try reseating the RAM module/s. If it still does not boot up then then RAM could be faulty, remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Mar 12, 2012 | Toshiba Tecra Computers & Internet
Sandisk ultra sdhc card won't record in my canon digital camera. i get a memory card error
All you have to do is
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Insert micro SD
3. Open EASEUS Data Recovery, choose Complete Recovery - Next
4. Select the drive micro SD - Next
5. Save the data to the hard disk (max. 1GB)
6. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4, 5)
After all data is secure, do the process repair micro SD
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, for Win XP
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe - select Install.
3. Insert micro SD
4. Then, open the program "HP Drive Key Boot Utility" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
5. Remove the micro SD from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, for Win Vista or Seven
2. Then, double click the file cp006049.exe - select Extract
3. Insert micro SD
4. Then, double click file hpdkbu.exe - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Insert micro SD
3. Open program HDD Low Level Format Tool, select micro SD - continue
4. Click S.M.A.R.T - click Get Smart Attributes
5. Click LOW LEVEL FORMAT - click Format this device
6. Wait until the process is complete - press OK
7. Remove the micro SD from the USB port, then insert it again.
8. Quick format micro SD (FAT file system)
9. Restore all data, to the micro SD.
I hope this information helps.
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
Acer 5534 won't go into recovery mode using boot disk. I get a disk read error, press ctrl+alt+del then reboots to black screen.
Sounds like you have a bad hard drive. Are there any noises coming from the pc when performing the recovery? Was it doing this previously? Most disk read errors point to the hard drive.
Aug 23, 2011 | Computers & Internet
Wont read any of my games or movies
Have you tried cleaning your disks with microfiber cloth? It may help believe it or not! even though your disk looks brand new and clean, it may have micro dust, etc on it which the all sensitive blu diode may have trouble reading. Good Luck.
Jan 10, 2010 | Sony Playstation 3 (PS3) Console
RCA RS 1285 5 disk audio system won t show or play
When you turn on the unit the cd draw seams to open. I hear it making a noise like if it is trying to get ready to play. When you shut the draw it won't play, change tracts, or the disc thing to put in more disc wont work. Someone please help me
May 01, 2009 | RCA Audio Players & Recorders
Windows XP Media - Service Pack 3 download, Wont startup after download shut down.
Keep the battery unplugged but make sure you have the power cord still plugged in, and when you see the toshiba screen press F8 i believe or F1. In there you need to change to the boot order so that the CDrom boots first if you want to try and restore from CD
Jan 28, 2009 | Computers & Internet
My external hard disk drive lights up but wont boot up
this will be a hardware problem, and needs to be taken back for waranty.
Jan 13, 2008 | Computers & Internet
Beyond Micro (BM120MD3U2) 120 GB USB 2.0 Hard Drive Logo
220 people viewed this question
Top Beyond Micro Computers & Internet Experts
David Payne
David Payne
Are you a Beyond Micro Computer and Internet Expert? Answer questions, earn points and help others
