Question about Mitsubishi WS-55311 55" Rear Projection Television
Mitsubishi WS-55311 flashing screen
Until now this TV was working perfectly. Recently, from any input setting it will suddenly flash a blank screen (all black) in a pulsing manner but in irregular increments in the middle of watching TV, playing XBOX or even with just a blue screen. When this even happens neither the remote nor the TV operating panel function. One time the volume just spiked up to full blast without me touching anything. I checked all connections and they are secure.
tride this but didn't work
First thing to try is to press the reset button on the front of the TV. This forces a system reset.
                                             can anyone help!
  • 1 more comment
  • Anonymous Dec 17, 2007
    I have the exact same problem as descrived by bud162's with the same type of tv. When the problem starts to happen I turn the power off and wait a while before I turn the tv on again. When I turn the power on, it might be OK and work for the rest of the day, but other times the screen is still flashing so I just turn it off.
    Any other suggestions out there?
  • wideman Feb 02, 2008
    I just started have the exact same problem today. Did anyone ever find a resolution to this problem?
    Many thanks for any answers!!!
  • donniebrady Mar 09, 2009
    SAME issue.  blue screen or inputs plugged in, i get audio flashing off/on/off.  problem persists even after i unplug ALL input sources, leaving only the power cord plugged in.  audio works JUST FINE through my surround sound.
  • 927 Answers
First suggestion is to unplug your unit for 24 hours, if does not correct your concerns, you may have fluid leakage from the tubes onto the pc boards. Make sure you have proper air venting around the tv. If problem persist call factory authorized dealer in your area. good luck
Posted on Apr 02, 2008
VX37L Screen Suddenly Went Blank, Now No Image, Sound Only on Cable Input, VIZIO Logo Lights Up
turn on the set, grab a bright flash light and dim the lights in the room. Shine the flash light on the screen, if you see a faint picture on the screen, you are dealing with a backlight problem. There are several things that can cause this. One, a bad backlight inverter, two, faulty 24vdc power supply, three, bad main board, or a bad faulty backlamp.
May 10, 2013 | Vizio VX37L Television
I recently moved, and when I had my cable TV set up, my 42" LCD had the green light indicator telling me that the television was on, but the screen was blank (no "snow" or input display) and...
Try changing your input choices until you get a picture. This usually means that the tv is on and functioning properly but the input method you have chosen is not the right one. what I mean by input choices are aux, cable, input one or two ect. check to see where the antenna is connected to your tv by which input method you are using on the back of the tv. Then change that input method to match by clicking the button on the remote that changes it.
Aug 17, 2011 | LG 42LC2D 42 in. LCD HDTV
My TV screen appears for a second then turns black, then a few seconds later appears again and the turns black again. The channel sound is perfectly fine. My Cable company tried everthing and it still...
If the tv isn't fully shutting down. but just flashing on and off then it
sounds like a backlight supply fault.
All LCD screens have what can only be described as micro flouro lights inside the screen module.
it is possible that the power supply is faulty causing them to flash on and off every now and then. or the tubes themselves are damaged.
to confirm this..
Lay the tv down flat on its back and power up in a well lit room
get down close to the screen and look across it at a acute angle
now if the black screen looks like it is still displaying an image then it's definatley your backlights!
in which case it could be a simple fault in the power supply.
so if your feeling confident in yourself i can talk you through what to look for in the supply..but try this first and get back to me.
hope this helps,ben :-)
Jan 06, 2011 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Television goes blank without warning for undetermined time
Power supply board have problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 02, 2010 | LG 32LC2D Television
I have a hitachi rptv model #43FWX20B and the picture has a red tint to it. Opened back up and red green and blue bulbs light up. red bulb stays bright while blue and green go dim to bright as tv plays....
Howdy;
Since you don't have any white lines with the red screen/picture I would say that the red bulb (CRT) is conducting too much. There is an adjustment control for that. The 'sceen' control is behind the speaker cover and service cover. Turn red screen control slightly to the left until you get a good black and white picture.
Good Luck, Big Irish.
Nov 22, 2009 | Hitachi 43FWX20B 43" Rear Projection...
Sony KP-65WV700 DVI-HDTV Issue
Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
From here:
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Nov 12, 2008 | Sony KP-57WV600 57" Rear Projection...
Tv problem rca F19431
INTEGRADO DE AUDIO RCA F19431
Jun 07, 2008 | RCA F19431 19" TV
While taking smap just blank dark black snaps are coming
This definitely sounds like a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
Here's the official advisory for Asia. You should search www.canon.com to find the local repair center in Bangladesh:
http://www.canon-asia.com/index.jsp?fuseaction=support&prod_type=image-phenomena_notice
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Dec 05, 2007 | Canon PowerShot A95 Digital Camera
Mitsubishi WS-55311, 4 yrs old, flashing screen on all inputs
Feb 03, 2007 | Mitsubishi WS-55311 55" Rear Projection...
Open Questions:
See all Mitsubishi WS-55311 55" Rear Projection Television Questions
Mitsubishi WS-55311 55" Rear Projection Television Logo
1,032 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
