Question about Marvin 3150 Mid-Size Heater
No heat or fan operation
Model 3150 heater power light is on 750 and 1500 and fan light do not,come on.. What could the problem be heater only used 1 season
is there a repair center anywhere?
    President:
  • 1,922 Answers
24/7 Appliance Repair @ (608)214-5632 we are located in southern wisconsin, Thank You
Posted on Aug 27, 2009
Why no power to pump?
[PDF]residential hybrid electric heat pump water - AO Smith Water ...
www.hotwater.com/.../hybrid-electric-heat-pump-service-handbook-(32...
... MAINTENANCE -. OPERATION & SERVICE - TROUBLESHOOTING ..... Tools for servicing residential electric heat pump water heater models: • Container (to ...
How to troubleshoot electric water heater - Water Heater Timer
waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-...
How to troubleshoot electric water heater. ... 2) Heat pump electric water heater has fan and compressor and will make sound when operating Read 3) Clean ...
Jan 01, 2016 | Water Heaters
Maintenance
I do not think it was intended to let user to disassemble and reassemble the unit. But if you are patient and careful, you can probably do it with great caution because it is a heating device. You do want to do anything wrong to cause fire if you damage anything.
Jan 13, 2012 | Marvin W.B. 3150 Convector Heater/Fan
Hiiiii..... I have samsung Thermostat AC, But i dont know how to use the warmer / heater for the same. I dont know about the model number but its one of the old AC written thermostat. Now help me out how...
Symbolsin remote: To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat"
Now symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.
Jan 03, 2011 | Samsung AW1203B Air Conditioner
PUH680 Heater Just Bought - Questions
The 1 setting is a 750watt setting and the 2 is a 1500watt or twice the heat...the light will always be on when you have power...the fan will go on if there is a call for heat and if the room if fairly warm it will be all the way to the top..does the company charge for assistance??? never heard of such a thing...
heatman101
Apr 23, 2010 | Patton PUH680-U Utility Heater
Hunter Thermostat fan won't turn off
Hi and welcome to FixYa,
Initially, I am inclined to suspect 3 possibilities:
  • sticking relay contacts (if used) (a possibility, least likely);
  • dusty thermal sensor/switch for the fan (likely);
  • time delay. design feature, will power down the fan only after a certain period that the heater has turned off. This is to dissipate residual heat not only on the heater but on the immediate surroundings of the heater element (most likely).
Good luck and Thank you for using FixYa.
Jan 01, 2009 | Hunter Fan Company 5/1/1 Programmable...
MY HEATER FELL OER BACKWARD AND NOW ITY WONT HEAT . THE FAN WONT COME ON...NOTHING. WHAT?
Just needs a little TLC: We just bought this heater at Goodwill and it's still in very good condition. The fan wasn't working either, but there was definitely heat. So we took it home and took it apart just to the point where we could give the fan a good q-tip/tweezers cleaning (lots of dust was in there) and then used Penzoil motor high temp grease via a toothpick on the spinning fan axle and voila! The fan works now and doesn't make anymore noise either. Just a note: this is a tedious task that requires an extra hand to help hold things in place since you can't take the fan out completely.
Nov 20, 2008 | Marvin W.B. 3150 Convector Heater/Fan
Marvin Model 3150 Electric Portable Room Heater
No I DID NOT GET A PHONE NUMBER TO CONTACT MARVIN MFG AND THE LINE IS BUSY. I DID NOT FIND THIS SERVICE, FIXYA, HELPFUL AT ALL.
I am not going to pay $29. or whatever for Expert Advice when you can't even give me a proper phone number to call the company. The heater didn't even cost that much. I can throw it out and buy a new one. What I ask for was not Advice but a PROPER PHONE NUMBER for Marvin Manufacturing and you could not even supply that.
May 21, 2008 | Marvin Portable Electric Radiator Heater
Honeywell Surround HZ2200 / HZ2204 /
A link to an Adobe (Acrobat) Reader format (.pdf) owner's manual for Honeywell® (Mini Tower) SURROUND HEAT™ HEATER FAN Models HZ-2200 (charcoal) and HZ-2204 (white) is here.
Some text from the manual:
SET UP
• The Surround Heat™ Heater is designed to
disperse heat in either a 360° range or in one direction only.
• To select the desired heating mode, slide the Direction Control switch, located
on the top of the heater, to the position of your choice:
– to the right (full circle) for 360° Heating
– to the left (half circle) for forward only heating (One Direction
Heating)
OPERATING INSTRUCTIONS
Select the appropriate heat dispersion mode. (See
Set-Up instructions.)
• With the Power knob in the OFF position, plug the
heater into a polarized 120V outlet.
• Turn the Thermostat control fully clockwise to the
HIGH setting.
• Turn the heater on using the Child Resistant switch
(Power knob). To operate the switch, push down
the two sides of the Power knob while turning it
clockwise to the desired position. The power
light will illuminate. The Child Resistant switch helps
ensure that the heater can not be turned on accidentally.
• When the room reaches a comfortable temperature, slowly turn the Thermostat
control counter-clockwise until the heater goes off. This is the point at which the
Thermostat setting equals the room temperature. At this setting, the Thermostat
will automatically turn the heater on and off to maintain this selected temperature.
• Push down and turn the Power knob to OFF and unplug the heater when you
are finished using it.
Nov 04, 2007 | Honeywell Surround HZ2200 / HZ2204 /...
Heater is getting power, but will not work
I guess of heater element are open and this can cause the fan from not working because both of them are on the same wiring
Jan 26, 2007 | Marvin 3150 Mid-Size Heater
Marvin 3150 Mid-Size Heater Logo
191 people viewed this question
Top Marvin Heating & Cooling Experts
Daniel Gasser
Level 1 Expert
Paul Carew
Are you a Marvin Heating and Cooling Expert? Answer questions, earn points and help others
