Question about Dryers
Dryer makes a click sound but will not start
Dryer clicks but will not start
  • 56 Answers
Sounds like you blew a thermal fuse depends on the brand and if it is check your dryer vent a plugged up vent will cause long drying times.
Posted on May 29, 2009
Michael Pryor I got a dryer model number.WED7500VW, is not turning on door switch onewire Was burn....
The door switch activates when the dryer door is closed. On most dryers, the door switch makes an audible clicking sound when it activates. To determine if the door switch is working, try starting your dryer and then listen for the "click." If the door switch makes a clicking sound, it is probably not defective. If you don't hear a click, use a multimeter to use the door switch for continuity. If the switch does not have continuity, replace it.
Aug 30, 2016 | Dryers
Dryer won't start.makes a click sound when I press start
It sounds as if there is a disconnect somewhere. Is this still under a warranty? If you're unsure, call and find out. If it isn't, they may be able to tell you what options you can try or how much to replace.
Sep 18, 2014 | Washing Machines
Why will my dryer not start, but makes a clicking sound?
If the motor runs and the drum doesn't turn the belt may be worn or broken...or you may have a faulty idler
Regards,
Dennis
Aug 15, 2014 | GE Dryers
Kitchenaid dryer model kgys750jq0 wont start
The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Many types of door switch will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive. Here is the switch to order if it is bad.
The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset. Here is the fuse to order in case it is bad.
Post back your findings and I will post the repair video for the repair.
Nov 07, 2012 | Dryers
Kenmore electric dryer model 110.60942990 wont start
the motor could be clogged up with lint take apart and vac out let me know if you need more help
Dec 12, 2011 | Dryers
When turning on dryer it makes a buzz sound and clicking sound and them smell of smoke. It doesn't come own just the sounds.
take apart and check the motor here is a website that will help, Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Dec 26, 2010 | Kenmore Dryers
Whrilpool dryer wont start set selector press start and all lights blink and dryer makes clicking nosie from apprears bottom rear
Sounds like something you will need a repair man for.Unless you are mechanically inclined it sounds like it's electrical.
Oct 20, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer clicks when start button pushed but does not start.
A quarter was lodged on the thermal fuse , located below the lint screen on the blower exhaust housing, on our dryer. Remove the front lower panel , 2 screw, and you'll see 2 fuses. I suspect that our control board is burnt.
Aug 05, 2008 | Whirlpool GEW9200L Electric Dryer
Dryers Logo
142 people viewed this question
Top Dryers Experts
