Question about Nintendo Wii Console
Wii Makes loud noise when disc put in. cleaned disc and still wont load. Message says unable to read disc.
    Problem Solver:
  • 12 Answers
Some loose connection inside or change your sound settings
Posted on Oct 22, 2007
Unable to read disc message. I put the game disc into the WII and it won't play. Keep getting a 'Unable to read disc message for any game disc that I try to insert.
This can be caused by a dirty laser in the drive. Try cleaning the laser with a q-tip and alcohol. If this does not fix the problem, the laser may need to be replaced. Contact Nintendo and see if the unit is still under warranty.
Mar 28, 2010 | Nintendo Wii Console
Wont read the disc. says to turn off and see manual. i did. i unpluged the back for 5 min like it said and it still wont work. also makes a loud noise when disc is inserted.
This is caused by a dirty laser or bad laser. try cleaning it with a q-tip and alcohol. If that doesn't work contact Nintendo and see if it is under warranty.
Feb 10, 2010 | Nintendo Wii Console
When a disk is inserted, an error message comes up saying that it is unable to read the disk. We tried a disk cleaner which didn't seem to help. Any suggestions?
I would recommend that you take the console to a game store and get them to have a look at it, it sounds like there might be a fault with the CD drive or the laser not reading the discs properly
Apr 13, 2009 | Nintendo Wii Console
Not reading disc
If Wii gives Disc Read Error, First step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives Information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Dec 30, 2008 | Nintendo Wii Console
Unable to read disc
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
188
Dec 25, 2008 | Nintendo Wii Console
Wii "unable to read disc"
If Wii gives Unreadable disc, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Dec 04, 2008 | Nintendo Wii Console
To install wii fit
    "Unable to read the disc" / "Disc could not be read" / "Eject the Game Disc" Error Message.
    If you are getting one of the above error messages:
    • If your console is placed vertically, the disc label will face to the right.
    • If your console is placed horizontally, the disc label will face upwards
  • If you know you are inserting the Game Disc correctly, but are still have the same problem with only one game (or if you only have one game), try cleaning the Game Disc by following the disc cleaning procedures
  • If after reading the above information you are still unable to play a game disc, please call 1-800-255-3700 to discuss available options.
Aug 13, 2008 | Nintendo Wii Console
Could be a damaged disk (check closely), a bad disk (did it work before) or your lens could be going out (which makes it unable to read the disk). Have you tried putting another disk in to see if you get the same problem?
Jul 19, 2008 | Nintendo Wii Console
Nintendo wii console
Try setting the console horizontal. That solved my disc read errors.
Apr 08, 2008 | Nintendo Wii Console
Unable to read wii discs
I had the same problem, I take it you have a modded wii(chipped), if you use a backup disc it is of a lower quality then original discs, the wii gets read errors without you noticing and tries to read those disc areas again sometimes suceeding and the gaming goes on, sometimes it fails, and a disc read error occurs. Over time the dvd assembly will take some damage it will loose it rigidity it once had and the wii stops reading discs. The problem gets worse if you have standing up, so first thing si to flip it down and try. Otherwise you (or someone you trust) will have to open the wii and adjust the lens sled so it wont flap as much up and down. Hope this helps..
Oct 01, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
190 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
