Question about Maytag Neptune FAV6800AW Top Load Washer
Fails to lock
Back story:
Changed to clutch and everything worked fine. Thanks for all who offered advise. Left the front panel off for about 6 loads just to be sure everything was OK. No problem.
Left for vacation, and the kids came home from college. They tried to put the front panel on, and broke the tips off of the two lid latches. Solenoids still operate.
Now, when you start a cycle, the latches click a few times then fail to say "locked". If you cycle power and repeat, I get a FL code.
Magnet for reed switch is in place and attracts the screwdriver OK.
I really do not care if the unit just thinks the lid is latched, (even though with the shortened latch arms it does not), as long as it operates OK.
Got any ideas?
  • 335 Answers
Joe,
You are going to have to replace that left lid lock, Left Lid Lock. You don’t need to replace the right just unplug. Here is what is happen. The left lid lock and right lid lock “Lid is Locked” signaling are in parallel going back to the control board that is why you need to pull the plug on the right lid lock after replacing the left lid lock. The lid locks are designed to latch into the lid only a small amount with them broken off the mechanism over shoots and a signaling slide switch contact signals the control board the lid is not locked “FL” code.
The left lid lock assembly is the important one with its dual signaling function, Reed relay and lid magnet to signal the lid is closed and the “Lid Is Locked” signaling. If you don’t replace the right lid lock (I would not) tape up the plug and try to secure the wiring harness to prevent the wires from chafing. I think you have the manual and Sears Parts direct info from my previous post but just in case; The Service Manual for reference. Sears Parts Direct for reference.
Posted on May 27, 2009
Start button will not work as well as the blinkers on both sides
Hi Bigcountry42, 1992 and later Touring Models, fuel pump fuses and relays will be behind the right side panel, starter and ignition relays will be under the seat behind the battery, everything else will be behind the left side panel to access fuses pull back on the front two locking tabs and slide the cover up. Good luck and have nice day.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Aug 31, 2012 | 2003 Harley Davidson FLSTFI Fat Boy
I have Harmon Kardon AV140 connected to 6 Klipsch speakers. All of sudden I know longer have any sound coming out of my front speakers. Everything was working fine a few days ago. Did we hit a button in...
Only the front speakers failing? All others ok?
There is NO configuration that would have NO front speakers.
Go back to basics, open the manual and use test tones for speaker verification.
Mar 17, 2011 | Harman Kardon AVR 140 Receiver
1.Front passenger door lock will not lock remotely or with internal power door lock switch. I can only lock it manually. All other locks work fine. 2. Ambient overhead temp control panel has stopped...
I can help with #2
These consoles are notorious for going bad. You can get a new one at the dealership for $250 (!!!), grab one from a wrecker, or I offer a repair solution with a lifetime guarantee. Check out www.autoclockrepair.com I have removal instructions and info there. Please let me know if I can be of further help, thanks!
Jan 18, 2011 | 2007 Toyota Tacoma
'05 Frontier w/ 6-speed manual transmission. Push the clutch straight in and truck will not start. Push the clutch in and hard to the left the truck will start just fine. No problems with starter,...
It's called the clutch switch and it's supposed to only allow current to the starter when the clutch pedal is depressed all the way down, releasing the clutch. It's bolted in front of the clutch pedal. Yours must be bad or shifted to the left somehow. Have it checked, then repositioned or replaced.
Nov 04, 2010 | 2005 Nissan Frontier
Maytag neptune MAH8700AWW washer will not complete the spin cycle. It spins both directions but never goes past 6 minutes on the display. Eventually you get the "DC" error. It does this with or without...
If the clutch fails the first thing noticed is a UC or DC error displayed and there is no drain or spin.
If you are seeing the above error and having a problem with spin and drain then the most likely cause of this is the clutch. The clutch fails to lock down the spinners and the basket is unable to go into spin and without a 90 RPM there is no drain.
Replace the clutch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question(&^%
Sep 15, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Xerox phasor 8400 - fault 37,004,40:157517"
Hi I can gave you some error codes but this all I can do hope it be of help to you.
8,009.4x:CAP_FAULT_MP_NO_ CLUTCH_STALL:
  • The media path motor has stalled while moving without the clutch engaged.
33,001.4x - TM_DEV_FAULT_MPT_WIDTH_VALUE_TOO_LOW
  • Tray 1 status:
1. Check the wiring and connectors from the front door to the I/O board.
2. Run the Test Tray 1 Width Sensors.
3. If the test fails replace the front door.
4. Replace the I/O board.
08.055.44:
  • The media path drive module has stalled while engaging the head tilt.
37,008.44:
  • The Preheat preheater is not drawing the expected power from the supply.
Run the Preheat Heater test, check the wiring. If test fails and no apparently problem is evident, replace the preheater.
05,002.42:
  • Problems with the Y-axis. It could be the belt,motor or the drum.
7,008.4x: PM_FAULT_HEADTILT_NOT_ ENGAGED
  • The printhead tilt is not engaged, so it didn't tilt back properly or the printhead is stuck in the tilted position by the tilt lock arms. The process motor gear train getting out of sync can also cause this error.
1. Try rebooting the printer.
2. Check for an obstruction or damage in the process gearbox.
3. Ensure the gears are correctly aligned and homed. If faulty replace the process gearbox
assembly.
4. Run the Tilt Axis Drive test to test the headtilt.
5. Run the Head Maintenance Wiper Clutch test. If the test fails, replace the wiper drive clutch.
6. Run the Wiper Axis Drive test.
7. Replace the exit assembly.
7,010.4x: PM_FAULT_HEADTILT_HOME_ERROR
  • The printhead is stuck in the tilt position by the tilt arms. The process motor gearbox being out of sync can also cause this error.
1. Reboot the printer.
2. Verify the lock arms rotate correctly.
3. Check for spilled ink around the printhead.
4. Check the process motor gears for damage. Ensure the process gears are correctly aligned and homed.
5. Verify the process gear box, process shaft, and drive module shaft are at home position.
6. Verify the headtilt gear will engage, see the home positioning procedure on page. You can manually engage the headtilt gear.
7. Run the Tilt Axis Drive test.
8. Run the Process Motor test.
9. Run the Head Maintenance Clutch test, if the test fails replace the clutch.
10.Run Wiper Drive test. If this fails inspect the wiper drive system.
All The Best: Pineworks
Jan 05, 2010 | Xerox Phaser 8400 Laser Printer
Error 08,045,43:42128
Hi Here are some codes for you
  • Tray 1 status:
08.055.44:
37,008.44:
05,002.42:
assembly.
All Best: Pineworks
Jan 04, 2010 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400 first page blurry
  • Tray 1 status:
08.055.44:
37,008.44:
05,002.42:
assembly.
Aug 26, 2009 | Xerox Phaser 8400 Laser Printer
MY WASHER DOESN'T SPIN CLOTH OUT
99% of all problems are a clogged filter and pump
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 06, 2009 | Frigidaire GLTF2940ES Front Load Washer
No clutch pedal pressure
if you have an adjustable pedal try that and if it still doesnt fix then youll have to replace all the O rings, that dont work then just go to a garage cause it will be cheaper dude then tryin everything
May 11, 2009 | 1984 Toyota Pickup Deluxe
Maytag Neptune FAV6800AW Top Load Washer Logo
706 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
