Question about IBM ThinkPad T43p Notebook
Laptop monitor disconnect
Hi
I (stupidly!) stretched the monitor of my IBM/Thinkpad T43 model too far backwards and it seems to be disconnected. Is there a way I can reconnect it? I can't see how to open the junction between the unit and the monitor. Does it come apart at all?
With Thanks,
PAVB
    Genius:
  • 1,601 Answers
You may of broken or disconnected the ribbon cable inside the screen to the motherboard. you have to do some major work taking it apart. I would go to the manufacturer website to see if there is a how to there. Once it is apart you will see the problem.
Posted on Oct 21, 2007
SOURCE:
Hi, how to resolve ibm thinkpad t43p on startup with black screen
It could be a faulty battery. Remove the battery & try to power up the laptop.
If the laptop did not power up after removing the battery, then notice the power receptacle where you plug the power adapter's cord to the laptop. While plugging the power cord in, notice if there is a spark occurring at the power receptacle. If the spark occurs, then disconnect internal drives & connectors one at a time until subsystem with short is identified. If power input still a short with bare motherboard, replace the motherboard. If the spark did not occur, then inspect the boards for burnt or melted components, cold solder on DC jack, open connections, or unseated cards.
Feb 10, 2011 | IBM ThinkPad T43 Notebook
Ask for Ibm Thinkpad T43 battery Price?
go to : Canada battery on-line shop,sell Laptop battery, Digital Camera Battery (DC ...... Welcome to buy ThinkPad T42, replacement laptop battery for IBM ThinkPad ...
https://www.linkme.com.au/groups/public
Jul 20, 2010 | IBM ThinkPad T42 Notebook
I need sound driver for IBM laptop T43
Use the link below to download a driver of your thinkpad T43. Click the file link 1ya210ww.exe.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-58599
Feb 07, 2010 | IBM ThinkPad T43 Notebook
How do I turn on the wireless on an IBM ThinkPad 2628 A20m Thanks in advance
To turn on the wireless on IBM Think Pad 2628 A20m you can try the below options
IBM
IBM General - Some models have the wireless slide button on the side of the laptop.
IBM DV series - use the antenna-like button found on the upper section of your keyboard.
IBM R40 - Use the Fn+F5 key-combo.
IBM Thinkpad (General) - Most have software switch or button on Left hand side.
IBM Thinkpad (model not further identified) wireless switch on Front edge of case.
IBM T43/X32 - Fn+F5 -Click "Turn On"
IBM ZD series use the antenna-like button just below the “Lock” key.
Let me know fi this will help
Dec 04, 2009 | IBM ThinkPad A21m 2628 Notebook
No sound from IBM ThinkPad T43
Hello Russell ince,
Please ensure that you have downloaded al applicable updates from the manufacturers website. Link provided.
http://www-307.ibm.com/pc/support/site.wss/MIGR-58597.html
Download the Audio drivers only at this time.
Jul 07, 2009 | Lenovo IBM ThinkPad T43 Notebook PC -...
I want remove & fix the new key board 4 my IBM T43 lap top , Kindly send me any demo how to remove & fix the key board
Hi there here is the instructions for replacing the keyboard of your laptop.Please note: dont forget to take the saftey precautions before opening your laptop.Like disconnect the powercord then remove the battery.
http://www.ehow.com/how_2093745_replace-ibm-thinkpad-keyboard.html
May 12, 2009 | IBM ThinkPad T20 2647 Notebook
"Power Surge on Hub Port
That series of laptop has a problem with it's battery which causes malfunction...
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=BATT-LENOVO
Moreover, make sure you have current BIOS and driver updates for you laptop, not all manufactures offer complete firmware updates like Lenovo; take advantage of it.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-58597
Nov 27, 2008 | IBM ThinkPad T43 Notebook
Laptop ibm t43 does't turn on if it's not plugged in
This generally indicates that you have a short in the battery, or that one of the fail safes in the battery has kicked in. A new battery will correct the issue.
Aug 07, 2008 | IBM ThinkPad T43 Notebook
IBM Thinkpad T43 Memory
ok listen listen the answer is this the other memory is right under the keyboard. turn the lappy upside down the screws that hold the keyboard in are the ones mark with two triangle then open the lappy like you would normally for operation use a screw driver flat head is good put it between the bottom left or right corner better yet put it in line withe the down arrow key push the keyboard up as though you are pushing the function key closerto the top then pluck up the keyboard gently as you would a tin of paint gently a cable is there that connect the keyboard to the motherboard disconnect install the memory then work the steps backward
Apr 14, 2008 | IBM ThinkPad T43 Notebook
Using IBM T34 with docking station and external monitor
hi all u need is to adjust the power management settings in the control panel, let me know
Jan 02, 2008 | IBM ThinkPad T43 Notebook
IBM ThinkPad T43p Notebook Logo
80 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
