Question about LaCie Electron 19" CRT Monitor
Large VGA plug, smaller input on both IMacs'
Have IMac G5 and IMac G4 want to conect to Monitor La Cie 19" blueIII ?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 116 Answers
DVi to VGA adapter
Posted on May 27, 2009
My imacs screen wont show up what do i do?
get an external monitor and the correct dvi adapter and plug it in to te back and turn it m Make sure that in the >System Preferences>Displays you have mirroring turned on then you should be able to a least use your mac. My sister had the same problem this solved it somewhat She hides the iMAC behind the new screen. Only other solution would be to take the iMAc in and probably have the display board replaced which would cost you more than the new screen. You will still have the new screen to put on a new computer and use it as a second display.
I have two 24 inch displays on my computer
Oct 21, 2012 | Apple iMac G5 Desktop
Replacing hard drive
Hard to say without the model number. This site has guide for all the g4 iMacs http://www.ifixit.com/Device/iMac_G4
Oct 11, 2012 | Apple iMac G4 Desktop
My Apple iMac G5 Mac Desktop can't start, it is giving me a white screen and an apple logo in the middle. Help me out
You will need to acquire and install a new power supply. I would suggest having a professional do it, being the iMacs are difficult to work on and not for the novice.
Feb 22, 2012 | Apple iMac G5 Desktop
I have an iMac G5 2Ghz that when it start up you can only see video for a few seconds. I connected an external monitor and my iMac works fine but with its on LCD there is no video. I check the logic board...
Sir,
The iMac G5 and iMac G5 (Ambient Light Sensor) computers have a video out port located on the back of the computer, which will mirror video. Video mirroring means you can see the same image that is on the iMac G5's flat-panel display on an external monitor, television, or projector.
Using the video out port, you can mirror video with a compatible VGA display using the Apple VGA Display Adapter.
You can also use the video mirroring feature with a television or projector that has S-video or composite video connectors when you use the Apple Video Adapter.
Both the Apple VGA Display Adapter (M8639G/A) and the Apple Video Adapter (M9109G/A) are available separately, and are needed if you want to use your iMac with a VGA monitor cable, S-video cable, or composite video cable.
The video mirroring feature is "plug and play". Simply connect a VGA display, television, or projector to the appropriate adapter (see above), then connect the adapter to the video out port located on the back of the computer.
When you connect the adapter to the computer, the screen may refresh momentarily as the computer prepares itself for the new video output. The computer tries to match the resolution of the built-in and external display. If there is no match, the computer changes both screen resolutions and may black out areas on the built-in display in order to match the capabilities of the external display.
Important: To ensure that your iMac G5 automatically detects the external display or projector, be sure you plug the adapter into the external display or projector before you plug it into the iMac G5.
You can switch resolutions and frequencies for both the iMac G5 flat-panel display and the external display, television, or projector using Displays preferences.
Want to watch a DVD movie disc on a television that's connected to your iMac G5? Select a 720 x 480 NTSC (in the United States) or 720 x 576 PAL (in Europe and other regions) resolution in Displays preferences.
Tip: Because of the display limitations of most televisions, the images displayed on a television screen are usually not as high quality as those on the built-in display or an external monitor.
Thanks
Good Luck
Aug 21, 2009 | Apple iMac G5 Desktop
Is imac g5 17" lcd compatible with imac intel core duo
Possibly, the newer G5 Imacs feature Intel 2 Core Duo Processers. While older generations, do not support Intel Core Duo or Intel 2 Core Duo Processers.
Jul 09, 2009 | Apple iMac 17" MA199LLA Desktop
Thanks for the help!
That sounds like it would fix it. Have you recently updated the memory in the imac? It may be incompatable. Otherwise it may simply have become faulty over time.
Please make sure that before you open up your imac, you're not voiding your warrenty. I know that the aluminium imacs allow this, but i dont think the G4 versions do.
Hope this helps,
Nathan.
Apr 13, 2009 | Apple iMac G4 Desktop
IMac G5
you need to contact apple support for the same
Jun 23, 2008 | Apple iMac G5 Desktop
Airport Extreme 802.11g
At this point you are much better off installing a USB wireless antennae than spending money on an Airport card, cracking open the iMac, and installing it.
USB wireless adapters are cheap, plentiful, and have more capabilities than the generation of Airport cards that were made for G5 iMacs.
Apr 14, 2008 | Apple iMac G5 Desktop
La Cie External Hard Drive 160 gig
A clicking noise from a harddrive is defenenly NOT a good thing. It usually means that the harddrive is going bad.
Nov 17, 2007 | Computers & Internet
sounds like hd is getting hot via firewire try and use the usb lead if same problem then get your files off quick and repace drive any thing above 80 gig will get hot in use that's why I use harddrive coolers on my large 300gig 400gig internal and only use my 250 gigs and 160 gig only when i need the files off they are turned off all time
Jun 07, 2007 | LaCie (300740) 160 GB Hard Drive
LaCie Electron 19" CRT Monitor Logo
157 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
