Question about Innovage Shift3 MP3 Player
I need to find the 4.5v adapter that goes with this lantern
I cant find the 4.5V adapter for innovage 20 led lantern any help? http://www.overstock.com/Sports-Toys/Innovage-20-LED-Pivot-Lantern/1532401/product.html
I have an Innovage Outdoor TV/radio/lantern combination and the TV doesn't work. Just snow and static sound. Can't find a support number anywhere in the instructions booklet or on the box. Does the TV...
Obviously this tv needs an antenna. It should have inbuild one but it might have been damaged or signal is too week to receive picture and sound. Try to check on open space and scan frequencies
Sep 15, 2017 | Innovage Televison & Video
How to change the battery for my 4345 coleman lanterne
There are two adapters for that lantern; one for the house and one for 12volt. You simply connect one of the adapters and it will power the lamp and also charge it. Those two adapters came with the lamp; if you don't have them you can contact Coleman to purchase replacements.
Jul 29, 2014 | Coleman 8D Family Size LED Lantern -...
Can't get bottom off
No company web address is there a support number located on the manual? the info i found was a 9 volt adapter could be plugged, use a universal power supply that that has multiple plugs and features voltage change up to 12v and can change polarity of the plug
Nov 08, 2013 | Computers & Internet
Swissgear rechargable lantern won't light up, even though the green led light indicates it is fully charged
There are several different models of the Swiss Gear rechargeable lantern. On most though, you can remove the top portion of the lantern and check the lighting element inside. In most cases the elements can be removed and replaced. I have a dual filament lantern and from experience I know that every so often you may have to go buy a replacement light piece. If the lantern has been bumped or even just strapped to the outside of the pack while walking, it's possible for those elements to become loose and need repositioning or replacement so do check that. I'm sure that it should be unlikely your charger is malfunctioning unless you left it plugged in for some very extended period of time, in which case I would say the light would be more likely to burn out. But definitely try that and if that doesn't work the battery pack on the lantern itself may have an issue in which case you can always get a replacement.
Aug 29, 2012 | Camping, Backpacking & Hiking
I am trying to find a 120 Volt AC adaptor for my Swissgear lantern.
The adapter need to match the charge voltage requirements of the battery in the Swissgear lantern.
This voltage maybe written on a label on the lantern.
i suggest go to the shop where you purchased the lantern for the charge adapter.
Jun 02, 2012 | Computers & Internet
Ac power adapter
Both at Walmart and Radio Shack you can find universal adapters that allow you to change the connector and voltage to fit the device. Try one of these, you can usually pick one up for under $10.
Nov 26, 2007 | Computers & Internet
Innovage Shift3 MP3 Player Logo
70 people viewed this question
Top Innovage Audio Players & Recorders Experts
John
John
Daniel Dollive
Daniel Dollive
Johnny Massengill
Johnny Massengill
Are you an Innovage Audio Player and Recorder Expert? Answer questions, earn points and help others
