Question about Sony CDX-M600 CD Changer
Cant pick up any radio stations after battery was changed
I have this unit( Sony CDX-M600) in a truck that sat about a year and a half. It was working fine when I parked it. Now it will only play CDs it will not pick up any FM stations at all. I checked to make sure nothing had chewed into the antenna wire and even plugged a different antenna with no luck. Any ideas short of buying a new one? CD WORKS FINE.NO SOUND FOR RADIO STATIONS APPEARING TO COME IN NORMAL ON DISPLAY..HELP!
    Problem Solver:
  • 10 Answers
Since you disconnect the battery, and CD WILL play, a code is not needed. They radio plug at the back of the stereo, might have came out. Check to see if this is securely connected to the stereo. Also check the radio wire at the back of the stereo to make sure there is no break. Some causes of the radio not fucntionly properly are the wire is not connected, the wire is damaged, antennas is damaged or the antenna is no good. The antennas rarely goes. Good luck.
Posted on Jul 15, 2017
    Top Expert:
  • Sony Master
  • 49,228 Answers
Probably need the anti-theft code to get the radio working again
  • 2039 Answers
SOURCE: Sony CDX-GT360S NO AM OR SHORTWAVE RECEIVE
am fm receiption not the same most likely antenna make sure the antenna wire fit tightly in radio cheers
Posted on Jan 14, 2008
SOURCE: CDX changer has power but doesn't want to eject after flat battery
i resolved this myself in the end.
I unplugged the audio & power cables whilst the stereo and engine was running.
Then plugged back in.
I turned the engine off and stereo off as well.
I then unplugged audio and power again from the back of the CDX, left it unplugged for 10 minutes whilst the engine was still off.
I then plugged the leads back in and turned the engine on. the stereo recognised the CDX, but stayed on displaying "CD Checking". I switched to radio for 20 seconds, turned back to CDX and it selected CD 1 and has been good ever since.
I'm rather pleased with myself!
Steve
Posted on May 15, 2008
SOURCE: Sony CDX-GT310. Installed by
Called a shop in VA and their opinion was that the tuner section of the unit failed. Cost of the part, $80. Then, labor and shipping. I can buy the new model (GT320) for about $95. I opted for buying a new unit.
Posted on Aug 12, 2008
  • 597 Answers
SOURCE: Sony CDX-M600R car radio CD: Radio does not work,
Don't know if you have an external antenna or one mounted in windshield but you should be able to find the coaxial heading towards the back of the radio. Make sure that it is plugged into the radio.
Posted on Jun 01, 2009
rteemon
  • 578 Answers
SOURCE: I want to replace a Sony CDX-C5005 radio/cd with Sony CDX-M10.
you can try but the connection may be different
Posted on Jun 26, 2009
Dimensions of CDx m600
Do you need the mounting dimensions or the unit size of the Sony Xplod CDX-M600? The unit dimensions are 7 1/8" x 2" x 7 1/4". The mounting dimensions are 7 1/4" x 2 1/8" x 6 1/2". (This is width x height x depth.)
Both are available in the manual on the specifications page. The manual is available from Crutchfield on the product page: http://www.crutchfield.com/S-K2FMmapLnGu/p_158CDXM600/Sony-Xplod-CDX-M600.html . The direct link to the manual is http://pdf.crutchfieldonline.com/ImageBank/v20000410114500/Manuals/158/158CDXM600.PDF . See page 35 in the right hand column.
I hope this helps.
Nov 27, 2016 | Car Audio & Video
Sony cdx m600 wiring diagram
See the wiring diagram on the final page of this installation manual: http://www.docs.sony.com/release/CDXM600install.pdf
Sep 24, 2013 | Sony CDX-M600 CD Changer
Sony CDX-GT320 FM / AM / XM Radio / Sirius Receiver missing sat option?
Check the connections between the head unit and the XM tuner. If the connections are good check for power and ground.
Oct 14, 2012 | Sony CDX-GT320 FM / AM / XM Radio / Sirius...
Hi, my problem is that each time I turn off the ignition I lose all my radio settings (i.e. the station pre-sets). My Sony is a CDX-L400X. I was wondering if there is an internal battery (like a button...
Hi, the problem is likely in the wiring or possibly a burned fuse. There is a separate wire to the radio that is always hot and keeps the station and clock settings while the key is off. If you tell me the car model and year, I may be able to tell you which wire and fuse to check. Was this working originally or has it never worked?
Aug 19, 2011 | Sony CDX-L400X CD Player
I hooked up my Sony cdx m-600, all works fine but radio does not work. at all. Why?
make sure the unit is hooked to the antenna correctly. This unit will not play the radio and will disable the static noise on the radio. So ensure the antenna is properly hooked in. For more info on how to use the deck click here for the manual. got this directly off sony's website for model cdx m-600. So let me know if that it is properly hooked up and we can figure out where to go from there.
Aug 31, 2010 | Sony CDX-M600 CD Changer
RDS failure?
some stereos you have to input the name of the station yourself.
May 05, 2010 | Sony CDX-GT310 CD Player
Can you change the radio stations without the remote?
Yes. This is a link to Sony for your CDX-CA900X operating instructions. Look on pages 13 & 14 for changing radio station w/o remote.
http://www.docs.sony.com/release/CDXCA900X.pdf
Nov 27, 2009 | Sony CDX-CA900X CD Player
Radio stations fuzzy and not coming in anymore - Sony CDX-GT310
Could be a bad connection in between radio and antenna . Check that first . If that doesn't work try a film strip antenna
Jul 24, 2009 | Sony CDX-GT310 CD Player
Sony CDX-M600R car radio CD: Radio does not work, CD player OK and all other funtions OK. When in radio mode can hear white noise but no transmitions. I have the same problem. No sound on AM section and FM...
Jun 01, 2009 | Sony CDX-M600 CD Changer
Open Questions:
Sony CDX-M600 CD Changer Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
