Question about HP LaserJet 4250n Printer
51.20 error message on HP laserjet 4250n printer
I have been getting a 51.20 error message on my printer. It tells me to turn it off and then back on again. I have done that and it still won't work. Also, I just replaced the fusor because that is what the error message is suppose to be. Is there something else I should be doing? Thanks.
  • HP Master
  • 4,338 Answers
It is an error with the laser scanner unit
1 Press ( SELECT button) to continue.
2 Turn the printer off and then on.
3 Reseat the connectors between the
laser/scanner and dc controller
PCA (J83 and J84).
4 Replace the laser/scanner assembly.
See Laser/scanner assembly.
5 Replace the dc controller PCA. See
Dc controller PCA.
If nothing from above works and the printer is no longer in warranty, it is possible if the printer is being used in a very dirty or dusty enviornment that the lens and optics of the laser/scanner are so full of debris that the beam detect error occurs. You can remove the top cover and the big black box in the center is the laser scanner assembly. Remove the screws securing the top cover of the laser scanner and remove and clean up all the optics to include the main mirror in the front. I usually use a damp q tip and for the mirror I slide up from toner cartrdige shutter area and observe from the top as it cleans the mirror. Removing the complete assembly on this model is not easy since there are a couple of cables going to the dc controller which are difficult to remove so removing the top of the assembly is easier.
Here is the service manual:
http://www.feedroller.com/Store/Service%20Manual/LaserJet%204250-4350%20(%204200-4300)%20sm.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 26, 2009
    New Friend:
Hi i m virendra yadav hp engineer hp 4250 printer 51.20 error , this error fuser, dc, Replace
Posted on May 05, 2014
3 Suggested Answers
NotAsUsual
  • 43 Answers
SOURCE: hp laserjet 4250n paper jam in 13.01.00
According to the manual: "A 13.01.00 error message indicates that the media did not arrive at the pre-feed sensor (PS102) within the specified time." That usually means that the rollers fail to pickup the paper from Tray 2. Usually, cleaning the paper feed roller in the 500 sheet tray should fix this. While blowing out dust, you may have coated this roller with paper dust. A quick way to double check this is to power cycle the printer & try to print from Tray 1, the MP feeder tray (unless Tray1 has rarely or never been used...it might be a little tempermental as well). Regardless, this error is very common & is usually fixed by cleaning. Depending on usage, this roller is considered a customer replacable item (Part # RM1-0037-000CN) with a life expectancy of more than 200,000 pages. There are 3 of that type roller in the printer, but the one in the tray is usually the 1st one to fail. Hope this helps!
Posted on Jun 02, 2008
  • 109 Answers
SOURCE: Sir, We have a hp laserjet 4250n printer since
Replace the fuser unit (they last about 75K pages in my experience)
1. Power down the printer and unplug it
2. Remove the fuser from the back side of the printer
3. Replace the fuser unit with a new one
4. Turn the printer back on
Posted on Dec 24, 2009
How to clear error code 49.4c02 error on HP laserjet P3015
Cancell all print jobs in the print que.. shut down computer disconnect USB or Network cabes to printer... turn printer off then back on wait till printer comes to READY then reconnect USB or Network cables ... turn computer back on and print again
Apr 02, 2014 | HP LaserJet 4250n Printer
49.ff95 service error HP LASERJET 4250N
I would start by removing the old driver, and make sure the print Que is empty.
Did you upgrade the firmware? If not I would.
Dec 20, 2011 | HP LaserJet 4250n Printer
My HP laser jet 4250n printer turns on but the display screen is blank --there is no message. the ready light, data light and attention light all come on
Could be bad Control Panel or bad Formatter.Start with the Control Panel, it's cheaper.1st make sure the cable is attached to it.
Sep 29, 2011 | HP LaserJet 4250n Printer
Dec 24, 2009 | HP LaserJet 4250n Printer
How do i clear an 49.4C18 error message on a HP LaserJet 4250n?
Any of the 49 errors are from the formatter board, you may need new memory, or a new board. The machine doesn't reset from this error without a new board.
Aug 11, 2009 | HP LaserJet 4250n Printer
50.4 FUSER ERROR ON HP LASERJET 4250n
I am willing to bet that you may have a faulty thermistor in your fuser asssembly, I wouldn't bother replacing the thermistor, your best bet is to just replace the fuser assembly and this should resolve your issue, so replace the fuser or call someone to do it for you. This should resolve your issue.
Mar 31, 2009 | HP LaserJet 4250n Printer
Setting margins on printer
Well, by now you may have found the solution, however, make sure that in MS WORD under File > Page Setup > A4 is selected, and if you still this prompt (error), just click on OK and proceed with printing.
The Laserjet Printers are capable to print upto 5mms from the edge of the border.
Regards,
Nikhil
Mar 17, 2009 | HP LaserJet 4250n Printer
Printing Problem
GO ON LINE AND TYPE INTHE FOLLOWING INFORMATION; EXAMPLE:
HP LASERJET 4250N PRINTER ERROR MESSAGE KERNEL
ENTER
"" "" "" ILLEGALOPERTORSEQUENCE
ENTER
HP LASERJET 4250N ENDCHAR ERROR
ENTER
HP LASERJET 4250N PRINTER POSITION 24 ERROR
ENTER
HP LASERJET 4250N ERROR MESSAGE [ CODE # ]
ENTER
ROD THE CANDYMANGANDY
Dec 20, 2008 | HP LaserJet 4250n Printer
HP Laserjet 4250n printer error 59.00
Replace the main motor assembly. A qualified tech will need to do this.
Dec 08, 2006 | HP LaserJet 4250n Printer
HP LaserJet 4250n Printer Logo
6,758 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
