Question about Palm Treo 755p Smartphone
My palm treo 755p power cycles to the access powered screen
My treo 755p when powered on boots to the access powered screen and will not boot completely to the main menu screen.  Once the access powered screen shows up the phone will reboot to the screen again.  Can you help me?
  • Palm Master
  • 4,338 Answers
There are different types of resets that may cure this issue. Try them, starting from a soft reset.
http://forum.brighthand.com/showthread.php?t=13189
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on May 26, 2009
"access powered" after the "palm screen"...keeps doing the same thing over and over
you have to hardreset your phone it will wipeout your all the data. but it will work
1. Disconnect the Treo from a charger or USB cable.
2. Remove the battery cover and take out the battery.
3. Press and hold Power/Endwhile you insert the battery.
4. When the screen lights up with the logo appears, releasePower/End.
5. Press Up when the Erase all data? prompt appears.
6. Press Up to confirm the hard reset.
7. Go through the steps of setting up the device again by picking a language and calibrating the stylus.
Now your Treo 755p is hard reset.
Jun 22, 2010 | Palm Treo 755p Smartphone
Palm 755p Malfunction
When you see the first screen (the orange one) hold the UP button as the bar moves across the bottom of the screen. Let go right before the screen goes to the silver logo. If it continues and opens Prefs, then you need to delete the program causing it to reboot. If that doesn't work, do a Hard Reset. A Hard Reset will erase everything on your Treo, so only do it if you have to. Google how to and it will work perfect.
Feb 06, 2010 | Palm Treo 755p Smartphone
Palm treo 755p tried removing battery and still only says treo across the screen and reset button dont work
in order to perform a hard reset, you take out the battery. hold the power button and insert the battery.
release the power button when you got palm/access powered. it should prompt you to erase all data. press up to erase and finish setting the device. no need to reinstall the palm desktop software.
Nov 09, 2009 | Palm Treo 755p Smartphone
Hello, have a Palm 755p Treo screen just keeps flashing
There are multiple reasons for the phone to go into an endless loop.
Fix #1 - Soft Reset - Take out the battery. On the back of your phone, pop the cover off, remove battery, place battery back in and it will show each screen once and power on normally.
Fix #2 - Hard Reset - To do a hard reset, hold the power button while you replace the battery and then release it when the Palm logo appears.
Fix #3 - Hammer
Apr 09, 2009 | Palm Treo 755p Smartphone
Frozen Screen on Palm Treo 755p
mayb you can try to do a hard reset.
Take out your battery press and hold end call button ( don't release ) then put in your batery wait the loading finished and change to other screen then you release your from the end call button you pressing just now.If still can't work,no choice need to go back to you service center .
Dec 28, 2008 | Palm Treo 755p Smartphone
Treo 755 with epocrates
I found that when I moved epocrates off of the storage card and into main memory, it didn't have any boot problems any more...
Sep 09, 2008 | Palm Treo 755p Smartphone
I have same treo 755 problem, did you get it fixed?
I had the same problem, and here is how I fixed it. First, I hit the middle up/down key at the top as it was cycling between Access/Palm, and when it came to Palm, I turned it loose. This got it to go to the regular screen, but guess what....my phone would not work! So, I took it to the local Verizon dealer at Circuit City, and there I asked the guy if he would do a Hard Reset. He did, go the phone back up working again, but of course I lost EVERYTHING. Luckily, I had done a syn not too long before, and instead of telling the long story of what all happened there, I was able to get all the backed up info back onto my phone, and now everything is back to normal. This has happened to me twice (the first phone was replaced as defective, but it could have been fixed the same way). I love the Palm 755p, but be sure and sync as often as possible on your computer. It saves you from having to enter a ton of phone contacts back in manually!
Jul 16, 2008 | Palm Treo 755p Smartphone
Treo 755p phone audio stops working
try doing a hard reset just make sure you hotsync first so you can backup all your information. Always keep in mind the software you have loaded write it down and the website you got them from along with any registration codes. when doing a hard reset you will lose all the information and programs on the phone basically it will take you back to the way you first bought it.
How to Hard Reset a Treo 755 To perform a hard reset/clean wipe of a Treo 755, do the following:
1. Remove the battery cover from the back of the device.
2. Press and hold the power (red phone) button.
3. While holding the red power button remove and replace the battery from the device.
4. When you see the "Access Powered" screen on the device take you finger off of the power button. At this point, you'll be prompted to erase the device by pressing up on the directional pad.
Good Luck I hope this helps with your problem
May 27, 2008 | Palm Treo 755p Smartphone
Just got Verizon 755p - can the power stay on while charging?
Try StOIC (Stay On In Cradle):
http://mytreo.net/downloads/stoic-stay-on-in-cradle,221.html
It's free and it works - the screen will stay on whenever the Treo is connected to charging power (e.g., in the cradle).
Enjoy!
- IntelelctArsenal
Jan 18, 2008 | Palm Treo 755p Smartphone
Treo 755p will not boot up
u need a memmory card, then everything will be okay, the memory card is da key to the fone
Dec 09, 2007 | Palm Treo 755p Smartphone
Palm Treo 755p Smartphone Logo
622 people viewed this question
Top Palm Computers & Internet Experts
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
