Question about Canon ZR100 Mini DV Digital Camcorder
Lcd display malfunctioning
The lcd screen keeps going in and out depending on the position of the screeen.  obviously it is having trouble keeping the connection.  should i chuck the camera or is this an easy fix.
    Problem Solver:
  • 7 Answers
It's the flexi connection from camera body to the screen that is at fault. Sometimes it touches connection depending on the position of the screen. It will gradually get worse and flexi ribbon cables are not really reparable. A new flexi is the only answer... Or say goodbye to it and treat yourself to the latest new model.
Posted on Oct 06, 2014
    Problem Solver:
  • 10 Answers
PROBLEM SHOULD BE WITH FLEXIBLE CONNECTOR WHICH CONNECTS CAMERA & LCD INSIDE TAKE IT TO A FIXER
Posted on Jan 09, 2008
Laptop cover / display hinges locked in full open position
Glad you found the solution because I had never heard of the lcd locking.
Apr 02, 2012 | Dell Vostro 1000 Laptop Computer (AMD...
LG E500 starting with white screen
Yeah, the problem is the screen more than likely. I would bet you have a loose cable on the lcd screen.You'll have to take the lcd screen apart to get to the cable that is on the back of it at the top. unplug it and plug it back in and secure it with a piece of tape where the connections meet. Unplug the other end of the cable and plug it back. Also unplug the two cables that go into the LCD Inverter that sits under the LCD Screen at the bottom, then plug them back.
Before you take the screen apart, try plugging an external monitor on the laptop just to verify that the video card is good. The display should show up on the external monitor.
Apr 01, 2012 | LG Computers & Internet
My 42 inch LG tv keeps going very dark on 1 side of screeen. Any solutions?
This problem is most likely caused by the T-CON board. It could be a bad connection of the cable from the LCD to the T-CON board. or the T-CON board could be bad. Sometimes you can disconnect and reconnect the flat cable(s) to the T-CON board and solve the problem. Else you can replace the T-CON board.
The T-CON board is the board that drives the picture to the LCD screen.
Mar 01, 2011 | LG Televison & Video
The display fades out unless I press on the plastic molding around the top of the screen. If I keep pressure there, the display works, but if I let go, the screen fades. What's the problem?
There is a loose connection inside your lcd monitor. This is not a user-serviceable case. Proceed to your local service center. Pressing or applying pressure to your monitor may cause some more trouble and defect to your laptop. Goodluck.
TedMac
Sep 19, 2010 | Gateway T-1631 PC Notebook
Is there a way to replace the screeen in a micron notebook?
http://cgi.ebay.com/MPC-Micron-Transport-T3000-LCD-Screen-Display-Set-/160368072296?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item2556ae9668
I believe this is the one ...and In generalany lsc screen that will fit inside will do ..but the fitting has to pe perfect and the ribbon to be able to match ..this one I guess is teh original and it came with the all not just the lcd ..all you have to do is mount the ribbon on the board ..and the hinges..
Apr 23, 2010 | MPC Computers TransPort T3000 Notebook
When I start my computer the display screen is red, but if I press down on the top of the display screen. It goes back to the blue start up color. What would the problem be and cost to correct?
The LCD is going bad, the replacement cost is about 200$ a ballpark figure keep in mind, first bring it to a repair shop and get a estimate, i usually don't charge for this. But this will depends on that specific shop that you bring it to. Good luck.
Sep 21, 2009 | Dell Inspiron 4100 Notebook
Blank screen
dust in the game console clean with wet q-tip the game and the ds
Apr 09, 2009 | Nintendo DS Lite Console
Laptop screen keeps going fuzzy!
The display connector contact on the motherboard is loose. If you can open the casing, you'll see a ribbon cable from the LCD part connecting to the motherboard. The connector is usually rectangular and connects downwards. Try pressing it in firmly.
Mar 30, 2009 | Computers & Internet
Sony SDM HS74P Screen Stays on for approx 15 seconds then shuts off but power light is still on?
PWI17LS285A, ACTUALLY THE CAPACITORS DOES NOT KEEP ENOUGH CHARGE TO KEEP THE LCD WORK...
so the big capicitor needs to replaced? 100µF 450V
Jul 07, 2008 | Sony SDM-HS74P/S 17" LCD Monitor
Screen and button malfunction
Rhondie3 - the flexcable and the LCD needs to be replaced.
JAY JAY33 - replace the LCD on the phone
Jun 26, 2008 | Motorola Mobility RAZR V3
Canon ZR100 Mini DV Digital Camcorder Logo
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
