Had been using it. Turn it off with the remote. The machine turn off like normal, then started up again. After several repeated attempts to turn it off, including the power button on the set it self, I pull the plug. Now it shows no power at all when plugged back in. I was getting a "Please Wait" message in the display and the DVR kept cycling on and off. I finally unplugged it. When I tried to plug it back in again there was no display at all. Anyone got an answer for this yet?
The power supply board on the DMR-E85H has problems. The earlier boards suffered from leaking capacitors and the later boards from voltage regulator problems. If your machine is now dead, the fuse on the power supply board has also blown.Go to the following links for details and photos on how to fix:Replacing capacitors:http://www.fixya.com/support/t216825-dvd_recorder_frozen_please_wait_displayReplacing the voltage regulator:http://www.rbjtech.net/electrical/e85/e85.htm#0Hope this helps. My machine had the later ps board and the voltage regulator replacement worked perfectly.
Which is the correct service manual for Panasonic DMR-E85H sold in the U.S.? DMR-E85HEB DMR-E85HEE...
(More)
Which is the correct service manual for Panasonic DMR-E85H sold in the U.S.? DMR-E85HEB DMR-E85HEE DMR-E85HEG DMR-E85HEP DMR-E85HGCS DMR-E85HGN DMR-E85HP DMR-E85HPC which manual do I need for the U.S.?
please wait message appears and remains on display screen, unit does not respond to manual or remote...
(More)
please wait message appears and remains on display screen, unit does not respond to manual or remote commands. the unit has not been used in about 5 months and has been unplugged during this time
