Question about Danby 22 in. DDW399 Free-standing Dishwasher
Need a replacement quick connect or unicoupler. A universal one is fine and I can just adapt my dishwasher hose to fit it
Where can I buy a new unicoupler? (the plastic quick connect that connects the dishwasher hoses to the faucet). Mne fell apart and I lost the ball bearings, please help
bigg t
  • 640 Answers
SOURCE: Lost faucet adapter, where to buy new one?! HELP!
home depot or lowes sells universal adapters.
Posted on Aug 27, 2007
  • 184 Answers
SOURCE: The plastic connector separates from the metal faucet attachment when I turn on the water (PS I have the Danby 496)
IF IT IS NEW, PARTS SHOULD HAVE A 1 YEAR WARRANTY.
GO BACK TO THE PLACE YOU PURCHASED IT AND HAVE THEM ORDER A NEW CONNECTOR. IT SHOULD COME WITH
THE HOSES AND ALL YOU HAVE TO DO IS UNSCREW THE
HOSES FROM THE BACK OF THE DISWASHER AND INSTALL THE NEW ONES. IF IT IS OUT OF WARRANTY, MAKE SURE ALL OF THE SCREWS ARE TIGHT IN THE CONNECTOR. OTHERWISE, REPLACE THE CONNECTOR.
Posted on Mar 27, 2008
SOURCE: connector hose
the water pressure is too high in the intake for your kit. use a higher grade kit or reduce the pressure .
Posted on Jun 08, 2008
  • 10 Answers
SOURCE: Portable Dishwasher Faucet Adapter Comes Apart
I'm glad to hear that solved the problem. I hope the new adapter comes quickly.
Posted on Jun 16, 2009
  • 44 Answers
SOURCE: The adapter on my maytag portable dishwasher comes
If you just replaced the connector and it won't stay on, replace the adaptor on the faucet.
Posted on Mar 24, 2010
Hose/ Adapters for older Maytag Portable Dishwasher
The sink faucet may have to be modified by installing an adapter.
Jun 22, 2017 | Maytag Dishwashers
Why does my locking collar from my unicouple hose not fit on my kitchen sink faucet/
Go to a plumbing store where the contractors
go & get the correct adaptor
Sep 28, 2014 | Plumbing
Is there a part that attaches the unicouple to to
yes there is a common part you can pick up at any hardware store. just replace this adapter with your sink airiator.
Mar 01, 2010 | Dishwashers
Danby portable dishwasher 1805W hose too short. Where I can find a extension hose.
First cut the hoses off near where they would connect to the plastic quick adapter. Leave a little slack at 2-3 inches between where you cut and the metal clamp.
Take those two pieces you just cut off to home depot or lowes. Afterwards you can chuck them if you don't want them (I did read below). Take the metal faucet adapter with you too.
For the water supply hose (this is the smaller one) need a Hose barb adapter 3/8 Barb x 3/8 FIP
You need a clamp for this.
Get a plastic hose the length you want and the right barb to fit the drain hose and your new hose. You need two clamps. Also you might consider hooking it up to an external water pump depending on your situation. If the hose is long or has to go up above 36 inches then you may need a pump.
Then you want a standard dishwasher connecting kit. They have them from 4-6 feet, they come with a 3/8 brass fitting make sure you get that.
You also need plumbing teflon.
I also wanted to replace the faucet connector because the plastic one it came with leaked all over the place. I got a quick snap that goes to a garden hose. It fits the metal faucet adapter that came with the dishwasher. . I had to get a few connectors to go from the garden hose adapter to the standard dishwasher hose.
Installation. Take the clamp for the supply hose and put it on the hose connected to the dishwasher. Put insert the barb and tighten the clamp.
Put teflon on the 3/8 male connector that came with your standard dishwasher kit. Connect it to the Barb adapter you just installed. Connect your standard dishwasher hose.
Connect the other end. Its pretty straight forward just don't forget to put teflon on any of the thick threads.
From this you can pretty much figure out the rest with the drain hose.
If I were to do it again I probably wouldn't have used the standard dishwasher kit. I would have gotten a cheap plastic tube and connected it. Also if you're happy with the plastic adapter they gave you save the plastic connectors you cut off and you can use another 3/8 barb adapter to connect it to the other end of your extension hose either a simple plastic tube or the standard dishwasher connector.
Dec 04, 2008 | Dishwashers
Hotpoint dishwasher
Did you have a dishwasher before? If so, you must have had a sink tail piece with a dishwasher drain coming off the side. For the connection, you may have to get an adapter to fit the end of the dishwasher drain hose to the sink tail piece. Take all pieces to hardware store if necessary to get an adapter which fits. After you connect the drain hose, make sure that the drain hose has a "high loop", meaning that the hose curls up at least 6 inches above the connection point before it goes down again. This is important to keep sink waste from getting back into the diswasher hose if the sink drain backs up.
Feb 14, 2008 | Dishwashers
Repairing the unicouple
I ordered it from a local appliance repair shop. It is a unic.repair kit and has the following numbers on the package. B21902X/1 and WD35M27 It cost about $25 CDN.
Sep 12, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Danby 22 in. DDW399 Free-standing Dishwasher Logo
1,331 people viewed this question
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Andrew Taylor
Andrew Taylor
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
