Question about Miele S514 Solaris Bagged Canister Vacuum
Miele S514 will not come on
My wife used the vacuum in half the house and it just quit working. I have tried plugging in to several outlets to no avail. I have also tried pulling the cord out and rewinding several time also no luck. Any suggestions?
  • 438 Answers
Greetings,
This definitely sound like a cord reel issue to me. This is really the only problem that I ever see on a Miele vacuum cleaner. 9 times out of 10 the cord reel needs to be changed. If you purchase the cord from us, and it's not the problem you may return it up to 60 days later for a full refund, that's how confident I am that is what's wrong with your machine.
Ok, so you need to replace the cord reel on a Miele S514 Solaris, no problem! I'll attempt to try and walk you through this repair with a detailed explanation of it, and along with some pictures to help you. You'll first want to buy the new Miele S500 series cord reel
So once you have the cord reel, you'll need either a Phillips head screw driver for the older S514 models, or a T20 Torx Screwdriver for the newer S514 model vacuums. The picture below is actually of the Miele S518 Cat & Dog series, but for this repair the procedure and parts are identical to the S514. You'll need to remove the hose, wand, and power nozzle from the vacuum cleaner before you begin.
The first thing you'll wand to do is open up the bag housing, and remove the vacuum bag, as well as the exhaust filter which may be either the Cloth Super Air Clean Filter, or the HEPA Filter catridge which is blue in color. If you're using the Super Air Clean filter, remove the filter, and then remove the bracket that secures the filter in place as well. Simply pull straight up on the bracket and it will come out.
Once the bag and the filter have been removed, you'll need to take off the entire tool lid. While the vacuum cleaner is open so that you can see into the compartment where the bag just was, you need to pry two arms from the tool lid off of the main body housing. Simply put a screwdriver behind one of the blue arms, and pry inwards. Here's a picture of what this looks like;
Once you have removed both of these clasps, the tool lid will pull straight upwards and off, leaving you with only the bottom part of the canister. This is how the vacuum cleaner should look now;
Now you'll need to remove the black speed control box from the canister. There is one screw in the front of the black speed control box that needs to be removed. After the screw has been removed, turn the vacuum cleaner around so that the back of the machine where the cord reel goes into the vacuum is now facing you. If you look where the black speed control box meets the bottom part of the canister, you can see two clips that you'll need to release before the variable speed control box can be removed. Simply put a screw driver and push in on the clip while lifting the black speed control box at the same time. Here's where the clips are located on tMiele S514 will not come on - c4f57b8.jpgbr />
Ok, now that the speed control box has been removed, it's time to separate the colored plastic from the base of the vacuum cleaner. There are 7 screws that need to be removed in order to get these housings separated. I have circled the locaMiele S514 will not come on - d7e09aa.jpgh screw in the picture below;
After removing all 7 screws, you can then simply pull upwards on the colored plastic housing, and remove the housing from the base of the vacuum cleaner so that the motor and cord reel are exposed. Once you have exposed the cord reel, you'll need to remove the internal wires (white wire is in the higher posistion, and to the left of the lower right side black wire), as well as the rubber hose part. The rubber hose part simply pulls off, just like the wire terminals do. After removing these parts, you'll need to remove one more screw with youMiele S514 will not come on - 707ba1e.jpgver. Here's the picture of which screw needs to be removed;
After the final screw has been removed, you'll have to remove the rectangular shaped wire harness that sits at the top of the cord reel. Pay close attention to how this wire harness is correctly seated which will save some aggravation when putting the vacuum Miele S514 will not come on - 9dd734e.jpger. Here's a picture of the wire harness that needs to be removed from the old cord reel;
Once the wire harness has been completely removed from the old cord reel, you may simply pull up on the cord reel and remove it. The new cord reel will come completely assembled, with all the parts and compontents that your faulty cord reel had. You simply need to line up the screw hole on the new cord reel with the hole in the bottom of the base of the vacuum. When installing the new cord reel be very careful that you don't pinch any of the wires down by putting the cord reel on top of them. The wires have a specific place they go, and you'll be able to see the correct path for these wires when paying close attention. Also remember to install the rubber tube back onto the new cord reel as well. Once the new cord reel has been installed, and screwed down, pull the plug out a little ways, and guide the plug through the colored top housing first, then screw the 7 screws that hold the upper housing to the lower housing back into to secure these housings together.
That's about all there is to that repair! Please feel free to request a repair clarification if you have any questions about the repair that I can help you with, I'm always more then happy to help.
If this repair guide was helpful to you, please click the thumbs up icon in the bottom right part of this solution to rate it has helpful.
Thank you so much,
Chris Jones
GoVacuum.com
Posted on Mar 21, 2010
Hi, I have a Miele S5120 that is about 4 yrs old. Yesterday it just started turning it self on & off for short bursts. Determined to finished the stairs I carried on, it finally stopped completely with a slight burning smell. I have tried your tip of pulling out the retracted power cord whilst turning on & off, in a socket that works, and also changed the fuse - to no avail. Could the motor have burnt out? Where do you suggest buying the power cord from, and how much are they? Hoping you can help. JO
Posted on Apr 19, 2010
Steam not coming out
I just took my wifes S3101 apart and found both inlet and outlet hoses clear, but nothing coming out of the boiler. I took the water side of the heater apart and found the outlet nipple clogged with dirt and sand. I'm from VA Beach and my wife uses tap water. After cleaning out the water side of the heater I had to drill out the outlet nipple, it was that plugged. Anyway, after that, I reassembled and it works fine. By the way, removing the casing screws was a lot of fun (not).
Nov 30, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
No suction once hose is plugged in. If I go to another recepticle it has plenty of suction until I plug the hose in. I just bought this house and the owner was unable to help with operating manuals due to...
If it's just the one outlet, then there's probably a clog in the pipe between that outlet and the main pipe. You may be able to clear it by plugging the hose into a working outlet, placing other end to non-working outlet, and turning vacuum on. This may provide enough suction to **** out the clog.
If not, you'll probably need to use a mini plumber's snake to try to remove it.
Sep 11, 2010 | Broan-NuTone CV353 Central Vacuum
Miele Red Star, small spark at outlet, no power to vacuum
The vacuum has a standard tube internal fuse. If you are lucky that is all it is. See the site http://www.sannerud.com/house/miele.html for instructions on how to open it up.
hope that helps
Jun 05, 2010 | Miele Red Star Bagged Canister Vacuum
My Sebo hoover trips the house mains sockets every time I switch it on, yet doesn't trip the kitchen mains. Have replaced filters/bag to reduce load but still no good. What should I be investigating in the...
It sounds like your vacuum is fine if it works when plugged in the kitchen outlet. It is tripping the breaker switch in the other room because the circuit is overloaded (too many things plugged in this circuit). Try unplugging some things in that room and try your vacuum again.
If it only trips when using one particular outlet, then the outlet should be replaced. I would recommend having an electrician check your wiring out.
Hope this helps
Feb 01, 2010 | Sebo Air Belt C2.1 Bagged Canister Vacuum
Will not turn on
Leave it unplugged for a half hour then try it. But it sounds like it may have received a power surge or several. This could have fried the motor. The motor may have to be replaced.
May 11, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Outlet does not engage unit
I would try to remove the inlet from the wall and tighten the screws that the low voltage wires connect to. If that doesn't work I would buy a new inlet. They are very easy to change out and relatively inexpensive. The inlets are readily available online.
Apr 28, 2009 | Electrolux Central Vacuum
BEAM Serenity Plus 2900 has shutdown
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. OK, there is a reset button on the unit but i think it could be that your vacuum could be clogged in the vacuum lines and that you should check all the inlets/outlets in your house with your vacuum hose - or get a vacuum cuff and go to each individual outlets and check the suction by feel - if the outlet is clogged you may have to call someone to unclogg it or by going to each oultlet the system may unclog it self -- or you can use a plumbers snake and be careful because the lines in a central vacuum are thinner than the walls in a plumbing situation or have it professionally unclogged by a priofessional. When you are using another vacuum to unclog the unit make sure the central vac is runing and to try to pull the clog apart from both directions. Below is a link to the factory for Beam and if you need a owners manuel for the Central Vac
http://www.beamvac.com/usa/
Sep 30, 2007 | Beam Industries 2900 Serenity Plus Central...
Miele S514 Solaris Bagged Canister Vacuum Logo
5,740 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
