Question about Logitech Keyboard
Memory dumpping my computer turned off after 3 or 5 minutes and a blue screen appears to indicate that the memory now is dumpping then the computer is rebooted.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 48 Answers
That is usually called a fatal error. It's not really fatal but you need to fix it. Download ccleaner and regscrub xp both for free and run them to clean your system up. It should run much quicker after that.
Posted on Oct 24, 2007
Physical memory dumping when l start to play gta
providing the actual dump message will greatly increase the chances of a correct diagnostic of the problem. (yes the message actually tells us why it goes to physical mem dump) other than that i'd check the fans and fins for dust buildup (causes overheating)
Nov 02, 2013 | Rockstar Games Video Game Consoles & Games
once your computer take an BOD or blue screen of *****. it is an indicator that one of you perepherals was damage. in that case you only have to option the memory cards or the HDD. if some point you dont experience a hard time in booting it is not the HDD. maybe your memory cards was in defective state. sometimes good sometimes bad. try to chkdsk first or scan your HDD for posible bad cluster. and make a test also in your memory using some stress memory tester
Aug 21, 2017 | Intel Motherboard
Blue screen physical memory dump?
This is called the Blue Screen of Death or BSoD, this usually happen if u plug in or insert any new hardware. If u have recently added any new hardware, try it out, after plugging off the newly inserted hardware.
Jul 28, 2010 | Microsoft Windows XP Professional With...
I am getting an error everytime after 5 minutes, w...
Could you please provide me the exact error message?
However to stop the system shutdown first follow these steps.
Disable automatic system restart.
1. Restart the computer and press the f8 key to open the Advanced Boot Options menu.
2. Select the Disable automatic restart on system failure option.
3. Restart the computer to accept this change.
Then go to safe mode
This problem occurs after a memory dump file (error log file) is written by Windows XP. Because the memory dump file flag not reset in Windows XP the memory dump file will contiue to be written every time Windows is restarted.
1. Restart the computer and immediately press f8 repeatedly. Use the arrow keys to select Safe Mode and then press enter .
2. Click Start , right-click Computer , and then select Properties .
3. Click Advanced system settings , grant permission to continue if prompted, and then click the Advanced tab.
4. On the Advanced tab, click Settings
  1. In the Virtual Memory section, click Change .
  2. For Paging file size for selected drive, click No Paging File , and then click Set .
  3. Click Yes after the following warning appears:
If the paging file on volume X: has an initial size of less than xx megabytes, then the system may not be able to create a debugging information file if a STOP error occurs. Continue anyway?
(X is the drive letter and xx is the amount of RAM installed on your computer minus 1 megabyte.)
  1. Click System Managed Size .
  2. Click OK four times to return to the Windows Desktop Screen and then restart.
For more information plz check the below doc from HP.
I hope this will definitely resolve your issue.
If not plz get back with the exact error message so I can give you better solution on this.
If you find this helpful then Plz vote for me..Dreamkam
May 21, 2010 | HP Pavilion dv6000z Notebook
Physical Dump of memory
Hi...
There are two thing you should try..
Check the memory.
Reinstall the OS.
Thanks
Kindly rate
Smith
Aug 13, 2009 | Dell Inspiron 1420 Notebook
Sir every time I open my PC there's a blue screen appearing then it shuts down but sometimes when I log in it's OK and if I open any program the blue screen appears again then will shut down. What would I...
Hello my friend, regarding your problem do you have installed program or driver software lately before this blue screen appear? i guess the problem here is more on the memory dumping of your computer. either the latest installed software is not functioning will or  u have a memory device problem either to much heat or cause by some circuit problem that made the memory device problematic. the worst case here is to replace memory but for now try to check first if the memory is running well and stay in its standard cooling temperature. Or you can reprogram your computer.
Jun 16, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Dell Dimension 4600 Blue Screen
Usually this blue screen appears due a hardware issue or drivers conflict.
1) Try to boot in safe mode (hit F8 after starting up) and select "Safe mode"
If you don't get access try doing this:
2) Run the OS CD and use the option Recover Console (R)
This will fix the problem.
3) If the problem continues, you will need to install the OS again.
Oct 07, 2008 | Computers & Internet
Disk Cleanup.
well..you sound as though there is too much on the disk..
Mar 29, 2008 | Dell Latitude CPI Notebook
Physical dumping memory...
Try to increase your virtual memory.  This may help you some.
Oct 27, 2007 | Computers & Internet
BEGINNING DUMP OF PHYSICAL MEMORY
Hi, Normally a blue screen of death (BSOD) with memory dump is indicative of a fault in the: Hardware- 1. Possibly memory; 2. video; or 3. motherboard. In some instances, Software- a. Drivers; or b. the Operating System itself. You may want to check the memory installed in your laptop. Some versions have them underneath the keyboard while most would have it at the bottom covered by a lid/plate secured with 1 or 2 small screws. The memory will spring out if you unlock the two side clips. You need to clean the little gold contacts with a pencil eraser. Re-insert back securely and try again. If the above does not correct the BSOD, you may need to replace them. Hope this be of some help/idea. Post back how things turn out or should you need additional information. Good luck and kind regards.
Oct 04, 2007 | Compaq Evo N110 Notebook
Logitech Keyboard Logo
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
