Question about Whirlpool Dryers
Whirlpool dryer timer clicks but doesn't turn the dial.
Of course the dryer will not turn off. Any help appreciated
  • 1 more comment
  • gnaas1 May 26, 2009
    I was hoping it was something else, maybe the clip? It does make a clicking noise. Timer is $75 :(
    it's on auto dry.
    Thanks I'll give it a try.
  • Whirlpool Master
  • 3,361 Answers
Bad timer. Replace it.
Posted on May 26, 2009
  • steve
    steve May 26, 2009
    Is this on Auto dry or timed dry?
  • steve
    steve May 26, 2009
    Auto dry will click and not move or move very slowly.
    If your clothes are drying in under 1 hour you are OK.
    If It does not advance to the end cycle you may have a defective auto dry sensor.
    Reach inside the front panel and locate the auto dry sensor and clean it with rubbing alcohol and try it again.
Dryer working fine. Then go to use it and nothing. does not turn on. No noise. No thrown breaker. a little bit of noise(clicking) from dial (timer) when turned on. On some settings but not all.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 12, 2011 | Whirlpool LER5644J Electric Dryer
Dryer drum won't rotate
if there is no air coming out of your vent on back of dryer then it would be likely your motor has gone out.
Jun 24, 2009 | Dryers
Whirlpool Dryer Drum Won't Rotate
sounds like your drum belt has broke. remove two phillips screws at lint screen. pull top towards you then up. you will expose drum.
Hi, It sounds like the timer is going bad. If you remove the rear panel and locate the two black leads that go to the timer motor, Check and see if it is getting 120V. If there is voltage to the timer motor and it isn't advacing, you need to replace the timer.
I hope this helps you. please let me know if I can assist you further.
Thanks
Vic
May 31, 2009 | Kenmore 62602 Electric Dryer
Dryer drys but the timer dial does not turn to stop automatic
Hi, You will need to change the timer. The timer motor has gone bad. You can test it by removing the back cover on the control panel and test the two wires going to the timer motor to see if it is getting 120V. If it is getting voltage, it should turn.
Please let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | Whirlpool LER5636P Electric Dryer
I have a 5 year old Whirlpool Electric Dryer, Model #LER7648KT2. The Dryer won't start. I have checked the door switch, start button switch and visible thermo switches or thermostats with an ohm meter...
There are usually 2 thermal fuses in dryer circuits. One is on the heater housing and will blow in an overtemp condition around 310-350F.
The other is on the blower or exhaust housing and will blow around 200F
Make absolutely sure the 2nd one is continuous and not intermittently functional. This will definitely stop the motor from functioning
Below is a diagram for an older model (LER4634). Your dryer has some additional terminals probably because it has additional drying cycle options.
The diagram may be more readable when copied and pasted into a plain text editor such as Notepad or another editor with non-proportional fonts
Switch Terminals
|TM |TM |BK |BK |BK |
|WB |OR |BU |BU |R |
|-- |-- |V |-- |-- |
|O |X |O |X |X |Auto - High Heat
|O |X |X |X |X |Auto - Low Heat
|<> |<> |~ |X |O |Cool Down / Fluff
|O |X |O |O |O |End of Cycle
|X |O |O |X |X |Timed - High Heat
|X |O |X |X |X |Timed - Low Heat
Legend:
O = Open (Infinite Resistance)
X = Closed (Continuous)
<> = Either (But not Both)
~ = Doesn't Matter
NA = Not Applicable
Switch Terminals:
TM - Timer Motor (Different Models may use different colors)
WB - Black/White
OR - Orange
BK - Black
BU - Blue
V - Violet/Purple
R - Red
Example: For the Auto - High Heat Dry cycle, the following terminals are continuous:
Terminals
<TM - OR>
<BK - BU>
<BK - R>
(of course since BK-BU is continuous and BK-R is continuous, then BU-R is also continuous.
This should allow you to test at least some of the cycles your timer switch has
I have a general schematic in PDF for whirlpool for gas and electric, but did not see an option to add an attachment to this message.
Hope this helps or point you in the right direction.
Apr 21, 2009 | Dryers
Whirlpool Dryer GEQ9800LW0 won't turn on
Hi!!! it seems that you have a bad thermal fuze located near the blower..change the thermal fuze and you should be okay..Good luck..
Jan 04, 2009 | Whirlpool GEW9200L Electric Dryer
Dryer won't start, Simpson Eziloader 4kg
Yes, the knobs don't like to be turned counterclockwise. Spin the knob clockwise to reinstall tightly, then move to set a dry time. Make sure half load button is pressed.
Jan 24, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
97 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
