Question about Brother GX-6750 Typewriter
GX6750 Typing wrong letters
My typewriter is typing the wrong letters/numbers. I have reset over and over again to no avail. Do I need to replace the daisy wheel? Please help. Thanks, Linda
  • 1 more comment
  • Anonymous Nov 28, 2007
    still doing it
  • american123 Dec 10, 2007
    How do I install a daisywheel
  • quicktype Feb 27, 2008
    Can you help urgently! My AX100 Typewriter, (always proved reliable and no reason to do this now), has suddenly 'locked me out' - it sometimes types the completely wrong letters I have typed, but I can sort that. This time, I must have pressed a 'code' inadvertently, but nothing at all is coming up. The hammer is not striking the daisy wheel at all. Can you advise. thanks, Julie.
    Problem Solver:
  • 19 Answers
Linda,first of all,does the daisy wheel spin when the typewriter is first turned on? if it does,then you will feel assured that it is installed properly. Next, refer to your manual to key board settings. It will indicate that there are settings for normal standard English keyboard and somehow that setting may have been changed. It would be also be important to check the daisy wheel to see if it is compatible with standard English keyboard...Cheers, John
Posted on Oct 21, 2007
After typing a few words the typewriter starts to type all sorts of characters and symbols . If I reset it or turn it off, it will start out typing the correct letters for a few words again but then it...
Remove the printwheel and look for bent or broken spokes, look for debris in the P/W area, try it without the correction tape, if you have the wrong type tape or it is twisted there will be a problem.
DickyO
Aug 30, 2011 | Brother GX-6750 Typewriter
My Brother GX6750 is the wrong typing letters
Printwheel in wrong. release the printwheel, make sure the pin is aligned with the slot on the hub and snap it back in. The printwheel should spin, then home out to the left margin, then it should be ok. Check to make sure no pedals on the printwheel are bent.
Mar 02, 2011 | Brother GX-6750 Typewriter
WHEN TYPING A HALF SPACE IS SKIPPED OCCASIONALLY AND WILL NOT CORRECT THE LETTER TYPED, IS THE LETTER WHEEL REPLACABLE?
To answer your question yes the print wheel can be changed, BUT that is not your problem. The machine needs to be reset or the reset tab needs adjusting.
Background;
When you turn on the machine the print head moves to the right side, the print wheel spins, and the ribbon jumps up and down, that is the machine resetting its self.
I would
  1. Power it off and then turn it back on and test to again.
  2. If it's still typing the wrong or unreadable letters then turn off the power open the lid. On the bottom of the case there is a metal frame on the right side of the frame you will see a small metal tab pointing towards the print head.
    1. (When the machine resets its self, it uses that tab as a reference.)
  3. That tab is easily bent which causes the reset to be wrong. Most people can bend it by hand, DON'T use a pliers! The tab can break off completely. It doesn
Nov 30, 2010 | Brother EM-430 Typewriter
I OPERATE A BROTHER GX6750 TYPEWRITER. i NEED TO CLOSELY COMPACT MY NUMBERS TO FIT A TYPE SPACE. HOW DO I ACHIEVE CLOSE TYPING? THANKS
There is either a slide switch labeled 10, 12 & 15 or a botton you press that changes indicator lamps to those numbers. Go to 15
(15 letters per inch} tou may also want to get a 15 pitch printwheel.
DickyO
Jul 30, 2010 | Brother GX-6750 Typewriter
Not typing correct letters
Major fault. Daisy-wheel sensor is losing position.
Probably a a motherboard fault, and beyond economic repair. Sorry.
Apr 12, 2010 | Brother SX-4000 Typewriter
Printing different letters
take to a repair shop or get a new one, no easy fix for this
Aug 21, 2008 | Brother GX-6750 Typewriter
Brother EM530 Typing Wrong Letters
Hi there. Take out the printwheel and see if any of the spokes are bent. That would cause wrong letters. . Also if the print solenoid(piston) does not go in and out freely. Lawrence
Aug 06, 2008 | Brother ML-500 Typewriter
Printing wrong letters and numbers
Typing wrong letters.
Please help immediately
Apr 28, 2008 | Brother GX-6750 Typewriter
Brother GX-6750 Typewriter Logo
903 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
